Question about Dell Computers & Internet
Mouse freezes The freeze occurs when i use the wheel.
  • 3 Answers
This sounds most like a driver problem.
Make sure you have the correct driver for your particular mouse.
Do a web search for you model (on bottom of mouse usually), uninstall the current driver, install the new one, and then manually run Windows Update to make sure you have the latest (mouse drivers would be listed as Optional updates if available).
Posted on Oct 31, 2013
Touch screen keeps freezing
Does the screen also freeze if you are using a mouse instead of touching the screen? If the freezing still occurs, then the problem is NOT the touchscreen. If it works OK with the mouse then you may need to have the touchscreen repaired. If freezing occurs even with the mouse the cause may be one of several. Right-click on the Windows taskbar and select Task Manager. The task Manager box tells you if your processor is working very hard (any reading that continues to hover near 100% indicates some program or process is overworking your system. Task Manager also shows a list of processes and how much cpu % each process is using. Another possibility is that to run everything you want may require more RAM memory. In general, 4GB or RAM is enough, but if you're running a lot of programs/apps at the same time then you may wish to boost your total amount of RAM to 8GB or more.
Sep 25, 2014 | Lenovo IdeaPad Computers & Internet
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
MY DELL E520 FREEZES AFTER START UP
Is this a recent occurance? Try a System restore. Have you done ANY Driver updates? Any updates at all? Added any hardware? When you boot to safe mode it only loads minimal drivers.
Jan 28, 2013 | Dell Dimension E520 PC Desktop
Cursor freezing
Remove viruses.
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
G5 laser mouse freezing
Download the latest mouse driver from it's manufacturer's support website.
Jun 09, 2010 | Logitech G5 Laser Mouse Mice
Logitech mouse frozen up we changed batterys in
If the mouse is freezing up though the batteries are fully charged, here's what you need to do:
1. Try to use different batteries just to make sure that it's not a power issue.
2. Connect the wireless USB dongle into different USB ports of the computer.
3. Try to connect the USB dongle in different computer and try to use the mouse (to make sure that it's not a computer issue).
4. Make sure that there's no cordless phone, cell phone and other wireless devices that might interfere the wireless signal.
The Logitech wireless mouse is running on 2.4MHz frequency, same frequency as the other wireless devices. Any wireless device might cause the mouse to freeze.
If same problem occur, then it's a hardware problem. Contact Logitech and RMA the mouse.
Thank you and good luck!
Apr 18, 2010 | Logitech Cordless Mouse
Mouse freezes up periodically (several times per day)
Have you tried changing batteries?
or check the current drivers.
Apr 24, 2009 | Innovera IVR62100 Mouse
Why does my mouse freeze?
Possibly a bad mouse.  Either try another mouse on that same port or try that mouse on another computer.  If you want to, try that mouse on another USB port on your computer
Mar 07, 2009 | Logitech Wheel Mouse Optical
Mouse stops responding randomly
The issue may not necessarily be with the mouse. Are you able to use the keyboard once the mouse freezes? If you not even able to use the keyboard, there is some application installed on your computer or a virus due to which the mouse freezes. If, in case, the keyboard works even though the mouse is stuck, try changing the USB port or try a different mouse. Please revert back with any other observations. Good Luck
Mar 30, 2007 | Logitech Optical Wheel Mouse M-BT58...
Computers & Internet Logo
Alun Cox
