Question about Karcher 2500 PSI Pressure Washer
Removal of Excell EXHA2425 pressure washer pump cover
How to remove the pump cover in order to get to the pum?
3 Suggested Answers
  • 104 Answers
SOURCE: no pump pressure
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
Posted on May 23, 2009
digritz
  • 530 Answers
SOURCE: Sheering bolt between pump and engine
I will assume you are referring to the main bolt that runs through the center of the pump right?
Was your replacement bolt a grade 8? I know the original bolt should have been a grade 8. It requires quite a lot of torque to shear through a grade 8 bolt. I would make sure that all the mounting bolts are secure. Also make sure that any dampeners that are included at the mounting points are in place and in good condition. It may also help to loosen up all the mounting bolts and make sure that as you re-tighten them that nothing is out of line or binding.
Hope this helps.
Posted on Sep 02, 2009
Testimonial: "Thanks for the info. I will check on the alignment of the 4 mounting bolts and make sure that everything is tight the next time I fire it off. "
Excell 2400 exha2425 has no compression
take off the pump unit start the engine, and see if it runs good if it does then change your pump if not then you must have busted a piston ring you can take it to any auto mechanic to replace the ring.
Oct 09, 2014 | Garden
Excell pressure washer
What is your model #
http://www.ppe-pressure-washer-parts.com/excell-devilbiss-pressure-washer-replacement-pump-parts
Nov 03, 2013 | Homelite For Excell - Pressure Washer Pump...
How to replace wheels on Excell VR2522 pressure washer
Anon, The wheel is probably held on by a push nut/cap. The easy way to remove is to cut through the cap retainer with a dremel tool part way and pry off with screw driver, these caps are not normally reusable after removal, check hardware store for replacement.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DeVilbiss Excell VR2522 Type 0 Gas Pressure Washer Parts
Remove CM 1200 Lawn Mower Wheel Retainer Clip on Lawn Mower Wagon Carriage...
https://answers.yahoo.com/question/index?qid=20130208122204AAcj7mW
Jan 28, 2013 | Garden
I have an old briggs stratton 2001 power washer its hard to read model number it looks like EXYRB2321 or EXVRB2321 its 6 hp when i put in ether number at B&S sit they say no results i need a...
Excell pressure washers used a series of numbers such as yours. I believe that that number will be for pump or pressure washer as a whole unit. Check Excell web site for a match. If you are looking for the engine model number check the fan shroud or valve cover or tag on engine itself. Good luck
Sep 06, 2010 | Briggs & Stratton 020324 3700 PSI Pro...
Excell r 2522 presure washer pump rebuild
I like http://www.ppe-pressure-washer-parts.com/excell-vr2522-replacement-parts-pump See pump upgrade and compare to rebuilding. Another good site is www.pressure-washer-parts.com. Piston seals usual begin by overheating from excessive idling. You might add a thermostatic relief valve to help this.
Jul 25, 2010 | Honda Garden
My maytag washer leakes, all the water runs out on the floor.
Remove the rear access panel to check the source of the leak. The drain pump is most probably broken or the sump hose is damaged or detached from the tub.
Drain Pump Removal/Replacement Procedure (Maytag Neptune MAH5500B)
  1. Safety first. Unplug the machine.
  2. Remove the hose clamps and hoses from the pump.
  3. Disconnect the wiring harness from the pump and the pressure switch terminals.
  4. Rotate the pump assembly counterclockwise and remove it from the base of the washer.
  5. Remove the plastic bag covering the pressure switch.
  6. Press in the locking tabs on the back of the pressure switch and pivot the pressure switch off the pump bracket.
  7. Grasp the pressure switch and lift the nipple off the pump cap.
  8. Install the pressure switch on the new pump in reverse order of the removal steps.
  9. Install the new pump in reverse of the removal steps above.
Jan 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have excell 3700 pressure washer...the pump cover vibrated loose lost oil and cam melted.how do i get parts and change pum cam?
When you get down to it, purchacing oil end parts for a pressure washer is not cost effective.
The crank(cam) shaft runs about 280.00 dollars. The oil seals, new bearings, possibly new pistons and almost definatly new seals would be at least a hundred more. You can get a new pump for about 400 dollars and won't have to do all the work.
Dec 18, 2009 | Psi PowerBoss 20262 Pressure Washer
Hope this helps.
Sep 02, 2009 | Karcher 2500 PSI Pressure Washer
The tubing from the gasoline is not connected
Devilbliss / Excell pressure washers in this model number range use a Honda GC160 engine. Information on this engine can be found here:
http://www.excellpressurewasher.com/documents/pdf/gc160.pdf
This web site also has information about the pump and related parts just look for your model number. I find that pressure washer manuals have very little information about the engine. Small engine / mower repair shops in your area will be happy to give you free information about the where the fuel line attaches. Your engine has a black plastic fuel pump with hoses going to tank and carb. This fuel pump is powered by engine crank/vacuum purssure so there is a third hose from the fuel pump connected to the engine block. Good luck on your repair and email if you have a question or if you have a different engine than mentioned above.
May 09, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
90 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
