Question about Canon BJC 5100 InkJet Printer
How To Install Ink - Canon BJC 5100 InkJet Printer
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Follow the instructions beginning on page 4-9 of this manual: http://gdlp01.c-wss.com/gds/3/0900007403/01/BJC5100_user_manual.pdf
Posted on Jul 17, 2013
Brother printermfc j430w will not accept ink cartriages i just install. screen says" no ink cartriages and install ink cartriage and ink black
Maybe are empty. You can manually check them. Take them out and look at them from the side that goes in the machine. There is a transparent plastic which if you are holding the crtridge exactly as it goes in the machine, it should have liquid ink inside. If its empty at that specific position is empty
Mar 21, 2014 | Brother Sealed Mfc-j430w Wireless Printer...
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
      For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
I just purshased a lexmart pro 705..How do you install the ink???please help
Make sure you have a new ink cartridge or cartridges before you begin. You must install new cartridges immediately
after removing the old ones or the ink remaining in the printhead nozzles may dry out.
1 Turn on your printer.
2 Open the printer.
Note: The printhead moves to the cartridge installation position.
3 Press the release tab, and then remove the used ink cartridge or cartridges.
4 Install each ink cartridge. Use two hands to install the black cartridge.
Note: Install the new ink cartridges immediately after removing the protective cap to avoid exposing the ink to air.
5 Close the printer.
The setup guide is on theCD you received with the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | Lexmark Office Equipment & Supplies
Whats the meaning of error in canon e5 error?
"E5: The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur."
Jul 22, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Replaced the magenta cartrage. arror check Ink
The Error "Check INK U140"
Causes : Possible causes are as follows :
* The ink tank may not be installed properly (The lamp on the ink tank is off).
Install the appropriate ink tank.
* The ink tank not be compatible with this machine. (The lamp on the ink tank is off).
Install the appropriate Ink tank.
The machine will not print of the wrong type of ink tank is used or if it is installed incorrectly.
Be sure to install the ink tanks in the proper order. The proper arrangement from the left to right is Black - (CLI-8BK), Black -(PGI-5BK), Yellow - (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Replacing Tanks
1) Ensure that the machine is on.
2) Raise the Scanning Unit (Printer Cover) until it stops.
The Paper Output tray will open automatically and the Print Holder moves to the center.
Impoprtant : If the Scanning Unit (PRinter Cover) is left open for more than 10 minutes, The Print Head Holder moves to the right. Close and reopen the Scanning Unit(Printer Cover) to return the Print Head Holder to the center.
3) OPen the Inner Cover.
4) Press the Open button to open the Paper Output tray if it does not open automatically and remove the ink tank whoe lamp is flashing red fast. Do not touch the Print Head Lock Lvever. Remove only the ink tank.
Important : * Handle the ink tanks carefully to avoid staining clothing or the surrounding area.
* Discard empty ink tanks according to the locakl laws and regulations regarding disposal of consumables.
Note : Be sure to replace ink tanks one by one when replacing more than one ink tank.
5) Prepare a replacement tank.
a) Remove the new tank ink from its packaging, then pull the orange tape so that the protective film does not remain on air hole. Then remove the film.
b) Remove the orange protective cap from the bottom of the ink tank and discard it.
6) Install the ink .
a) Install the ink tank into the Print Head.
b) Press on the Push button on the ink tank until the ink tank snaps firmly into place.
c) Ensure that the ink tank clicks into place and then its lamp lights red.
Important : Make sure to install all the ink tanks to enable printing. The machine cannot be used unless all the ink tanks are installed.
7) Close the Inner Cover.
Note: Ensure that the Inner Cover is closed, Printing will not occur if the Inner Cover is open.
Hope this help. PLease rate my response.
Thanks
have a good day.
Nov 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I want to install ink cartidges and do not know where to begin. I have misplaced my instructions
To install your Brother machine#s ink cartridges, follow the steps
listed below:
1. Make sure that the Brother machine#s power is turned on.
2. Open the ink cartridge cover. This cover is located on right-hand
side of the Brother machine#s front panel.
3. Pull down the four lock release levers. There is one lock release
lever for each ink cartridge.
4. Take the ink cartridge out of its protective bag.
5. Carefully remove the yellow protective cap from the ink cartridge.
- DO NOT touch the side of the ink cartridge covered by the yellow
protective cap.
- Take care when removing this cover to prevent spilling ink and
staining your hands and clothing.
- If the cartridge cover comes off when you open the bag, the cartridge
will NOT be damaged.
6. Install each ink cartridge in the direction of the arrow on the
label.
- Please note that each color has its own specific position. These
positions are indicated by the colors of the four lock release levers.
Do not install an ink cartridge in the incorrect position, as this can
cause print quality problems.
7. Lift each lock release lever and push it until it clicks into the
closed position.
8. Close the ink cartridge cover.
- If the LCD shows #Install Black,# #Install Cyan,# #Install Magenta,#
or #Install Yellow# after you install the ink cartridges, please verify
that you have installed the cartridges correctly.
NOTE:
* DO NOT remove the ink cartridges from the Brother machine unless you intend to replace them. If you do, it may reduce the quantity of ink left in the cartridge, which may cause the Brother machine to miscalculate the amount of remaining ink.
* DO NOT shake the ink cartridges. If ink stains your skin or clothing, wash the affected area with soap or detergent immediately.
* DO NOT repeatedly insert and remove the ink cartridges. Doing so may cause ink to seep out of your cartridges.
* If you mix the colors by installing an ink cartridge in the wrong
position, clean the print head several times after correcting the
cartridge installation.
* Once you open an ink cartridge, install it in the Brother machine and use it up within six months of installation.
* Use unopened ink cartridges by the expiration date listed on the
cartridge package.
* DO NOT dismantle or tamper with the ink cartridge. Doing so can cause ink to leak out of the cartridge
Apr 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Can't find ink storage
look at this
Details Issue: How do I replace or insert an ink tank?
Solution: Install the Print Head and Ink Tanks - MP620 / MP620B
  1. Open the Paper Output Tray (A), then lift the Scanning Unit (Cover) (B) until it locks into place.
    The Scanning Unit (Cover) (B) is fixed automatically.
    The Print Head Holder (C) comes out. (This is where you install the Print Head.)
    Note : Close the Document Cover (D) and lift it with the Scanning Unit (Cover).
  2. Raise the Print Head Lock Lever (E).
    i_expl.gifCaution : Firmly raise the Print Head Lock Lever until it stops. (The Print Head Lock Lever may feel heavy.)
    i_note_e.gif Note : If the Print Head Holder does not move, make sure that the machine is turned on.
  3. Remove the Print Head from the silver package.
    i_expl.gifCaution : There may be some transparent or light blue ink on the inside of the bag the Print Head comes in, or the inside of the protective cap - this has no effect on print quality. Be careful not to get ink on yourself when handling these items. Be careful not to stain your hands.
  4. Remove and discard the orange protective cap.
  5. Tilt the Print Head and set it in place. Lower the Print Head Lock Lever (E) completely.
    i_expl.gifCaution : Do not knock the Print Head against the sides of the Holder.
    Be sure to install it in a well-lit environment.
    Pinch the Print Head Lock Lever firmly and lower it gently.
    Once you have installed the Print Head, do not remove it unnecessarily.
Install the Ink Tanks
  1. Pull the orange tape (1) in the direction of the arrow to peel off the protective film and remove the film (2) completely.
  2. While pressing down with your left thumb, twist off the orange protective cap (A) located on the bottom of the ink tank.
    i_expl.gifCaution : Do not hold the sides of the ink tank; ink may splash.
  3. Install the Ink Tank
    Press the PUSH mark on the ink tank until it clicks into place.
    Make sure the Ink lamp lights red.
    i_expl.gifCaution :Be sure to install it in a well-lit environment
    i_important.gif Important : Match the labels when installing.
  4. Install all the other ink tanks in the same way.
    Install all the ink tanks.
    i_expl.gifCaution :Once you have installed the ink tanks, do not remove them unnecessarily.
    i_important_e.gif Important : Make sure all the Ink lamp lights red.
  5. Close the Scanning Unit (Cover) (B).
Mark
Apr 16, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Check Black Ink blinking...???
Remove the ink cartridges
Remove the printhead
Close the access door w/o anything in the printer
wait for a few minutes
Install the printhead only
install the black ink cartridge
if the error still there ( Repeat the cycle 5x)
or go to www.kodak.com/go/itg
Mar 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Ink cartiage not proparly install but my ink cartiage refil
ink cartiage not properly installed ae shown but my cartiage are riffil
Jan 28, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Apr 04, 2008 | Canon PIXMA iP1600 Printer
Canon BJC 5100 InkJet Printer Logo
56 people viewed this question
old marine
old marine
