Question about Boost Mobile Lg Venice No-contract Mobile Phone - Black
Charging problems for lg venice
Wont charge with any other charger but the one that came with the phone. it used to charge with other chargers just fine, but now it wont.
    New Friend:
I had a problem like that before with the iPod 4th generation. I know your problem is about a phone, but...... I don't know what to tell ya!! Sorry. :(
Posted on Jul 17, 2013
My Lg is not keeping charge, and I bought a new Battery and it still wont charge or keep charge. Please Advise.
A charging problem could be due to a bad battery, corrosion on the battery contacts (you can clean them with rubbing alcohol) a bad charger or the charger plug on the phone. I would try replacing the charger and checking the connects.
Jan 13, 2016 | LG Cell Phones
My phone wont turn on or charge even tho i charged it all night
It sounds like you need to replace your battery. But first, if you're using a home charger, try charging the phone with a car charger (or vice versa). If the problem is not with your charger, then replace your battery.
When you get your new battery:
1) Make sure you are using the proper charger for your phone (not one of the cheep $5 kind), and
2) charge your battery for at least 12 hours before you use it for the first time.
Click here to see a battery for your phone on eBay: http://cgi.ebay.com/NEW-OEM-LG-VERIZON-VX8560-CHOCOLATE-3-LGIP-330H-BATTERY-/250764708864?pt=PDA_Accessories&hash=item3a62bdcc00
Jan 28, 2011 | LG Chocolate 3 Cell Phone
My LG-VX9200 wont turn on and the battery wont charge. I assume is the battery, its a practically new phone. It hasnt get wet either. What can it be? Thanks in advance
Before you conclude that the battery is the problem, i suggest, you get a similar charger to charge your phone first, if the similar charger charges the phone, then, ii means you are having charger problem, but if it does not charge the phone, you should be considering the idea of getting another battery to see if it will charge on your phone.
The problem can also be that, the charging port of your phone is bad, you can use your charger to charge a similar phone and see if it charges, if it does, then, the problem is either th battery or the charging port.
Check the following one after the other to detect what the problem is,
1. Try use a similar charger to charge your phone to see if it will charge.
2 Get a battery from someone that as a similar phone to test your phone to see if it will power up.
If it works with your phone, get a new battery for your phone, the one you have on it is dead and will need to be replace.
Take care.
Jul 18, 2010 | LG enV3 VX9200 Cell Phone
I put my charger into the lg cookie charger and it wont charge
hi, try using the charger with another lg phone that it is compactible with to confirm if it will charge..if it worked, it means the charger is fine but if it does not it means the charger is bad...also, it could be that the charging port of the phone is faulty...so if that charger charges another phone, it means you will need to change your charging port.
cheers
Jul 01, 2010 | Lands Phones
Wont charge
hello,
try to use the charger on another phone to see if works, if it does it means its not the charger.
then try to remove the battery and reinstall it, the try to charge again with phone off.
or you can try another charger on the phone, if it doesn't charge it must be the charging connection port on the phone that has a problem.
thank you.
Jan 07, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
LG shine wont charge
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Jan 31, 2009 | LG Shine CU720 Cellular Phone
yeh same problem with me, take the battery out, put it back in, then stick the charger in and it will work
Oct 10, 2008 | LG Shine KE970 Cellular Phone
Boost Mobile Lg Venice No-contract Mobile Phone - Black Logo
191 people viewed this question
Top Boost Mobile Cell Phones Experts
John mullen
Lawrence Oravetz
Are you a Boost Mobile Cell Phone Expert? Answer questions, earn points and help others
