Question about Seiko Watches
My seiko 7t82-ofdo watch have the hour hand misplaced
The minute hand is on 12 and the hour hand is in between hours, how can i fix that
  • 37 Answers
SOURCE: Hands of watch out of synch
My watch just did the same thing. I unscrewd the back off as to change the battery then the pulled up gently on the insides (on the opposite side of the time ajusting knob) just enough to allow a staight pin to slip between the glass then I advanced the adjusting knob while holding back the hour hand untill it was properly aligned.
Posted on Feb 22, 2009
  • 188 Answers
SOURCE: How do I safely remove the crown of SEIKO ladies wristwatch
it might just lightly push on but not expert at this. clocks do. and some watches do. thats a fact.
Posted on Mar 26, 2009
SOURCE: reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Posted on Aug 28, 2009
SOURCE: Guess Watch's stop watch is broken?
it's not broken.
let's call the top stopwatch button "a" and the bottom stopwatch button "b." eg, for normal stop watch function press "a" to start timing, press "a" to stop timing, and press "b" to reset.
to reset: press button "a" and "b" simultaneously and release (an easy way to do this is press and hold down "b" then press "a" and release both). this will send both hands spinning. next press "a" intermittently until the second-hand is back to it's desired reset location. then, likewise, press "b" intermittently until the minute hand is zeroed. now with both hands at the correct reset location, again press and release "a" and "b" simultaneously to save these resets and return the watch to normal function mode.
Posted on Oct 07, 2009
  • 3 Answers
SOURCE: seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Posted on Jan 03, 2010
Hello. I have a Seiko 7t62 ojpo chronograph. The small second hand will run for about 20 minutes then stops. As a result, the main minute and hour hands stop working. Everything else works. Any ideas?
You have a fairly premium watch and some versions are more premium than others. Your watch clearly needs attention and that should be entrusted to a Seiko dealer or to the manufacturer. Once the case has been opened the sealing must be retested to ensure it meets specification. If this isn't done as part of the repair or service or battery fitting there is little point in having a watch with such a high specification.
Jan 04, 2017 | Seiko Watches
The hour hand doesn't move
try opening the glass over the hands and pressing down on the hub of the hour hand
they are a press on fit with slots cut in the sides and will slip if the hub is loose on the hour shaft
place the minute hand and the hour hand at 12 o'clock first so that the minutes will always be in the right position on the hour.
Jun 21, 2015 | Home
Seiko SGF204 second hand hesitates or jumps a second and looses probably 10 minutes an hour. Any suggestions would be appreciated. Thanks
When the watch jumps a second or seems to stop then tick twice, it indicates that the battery is low. You will need to take your watch to have the battery replaced.
Feb 28, 2011 | Seiko SGF204 Wrist Watch
Pulsar chrono hand alignment
mcdedevito75 here, Return to the watch rep[air that installed the battery for adjustmaet.
Jul 03, 2010 | Seiko Pulsar watch
My watch has had the battery changed and when you reset the stopwatch, the second hand and the small hour/minute hands no longer rests on 12. How do I reset these hands
I have the same problem with my Seiko Coutura Chronograph. Ever since battery was changed, the stopwatch resets to 32' 8" instead of 0'0". How to re-zero the hands?
May 08, 2010 | Watches
Watch hour and minute hands are not lined up at 12 o'clock
Take the back off, then slip the works out of the case. move the hands to line up at 12.. hope this helps..
Feb 27, 2010 | Tissot T-Touch T33159851 Wrist Watch
How to change the hour
Anniversary clock hands can be adjusted directly moving the minute hand clockwise. Do not touch hour hand as this may cause hand disalignment. Carefully move minutes hand with your finger all the way around till you reach desired time.
Do not forget to rate, please.
Mar 09, 2009 | Seiko Clocks Melodies In Motion QXM135BRH...
Can't set Seiko Yacht Timer Sports 150
Turn knob to set on "Match" Pull out crown knob. Press both buttons for 3 seconds. When you release both buttons it will beep and both hands start moving. Press either button to stop movement. Then press the top button to set the minute hand to 12 oclock. Press the bottom button to set hours to 12. Press in crown and turn to "Time" Pull out crown and set time the same way.
Mar 01, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
How to Set Alarm
This is the movement used in the following Seiko watches..
SNAC74 SNAC75 SNA548 SNA694 SNAC40
SNAC41 SNAC42 SNA749 SNAC03 SNA411
SNA414 SNA765 SNAA03 SNAA05 SNAA01
SNAA02 SNAA61 SNAB61 SNAB62 SNAB64
SNAB65 SNAC25 SNAC29 SNAC35 SNAC36
SNAA61 SNAC38 SNA283 SNA695 SNAA30
HOW TO SET ALARM TIME
1. Pull the crown out to the second click position.
2. Press button “B” to set the alarm hour and minute hands to
current time.
3. Push the crown back to normal position.
4. Pull the crown to the first click position.
5. Press button “B” to set the alarm hour and minute hands to
desired alarm time.
6. Push the crown back to normal position.
Note:
Alarm setting on a 12-hour basis only. Alarm will ring at the
designated time for 20 seconds; one time alarm only. The alarm
needs to be reset in order to re-engage the alarm function.
HOW TO USE CHRONOGRAPH
1. Set crown at normal position.
2. Press button “A” to Start/Stop/Restart.
3. Press button “B” to Split/Split release/Reset.
HOW TO USE ALARM DIAL
AS DUAL TIME DISPLAY
2. Pres the button “B” to set the hour and minute hands to time of
a different time zone.
Nov 27, 2006 | Seiko Coutura SNA341 Wrist Watch
Watches Logo
50 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
