Question about Microtek SCANMAKER I900 Flatbed Scanner
Where can i buy replacement bulbs - Microtek SCANMAKER I900 Flatbed Scanner
Replacement bulb/lamp availability
Google search your manufacturer make and model and the words replacement lamp. You can find reputable vendors it in the search results.
Mar 31, 2015 | Televison & Video
I want to change the dash board light bulb in my cars but cant find out how to do it or whas bulbs to buy
the bulbs are led and are built into the dash gauge cluster, non replaceable i believe, best bet call dealer and ask for bulbs
Jun 08, 2012 | Cars & Trucks
Philips Mitsubishi WD62525 Lamp with Housing 915P020010 Do I have to buy the housing? Do I need to replace the housoing when I replace the bulb?
The housing is part of the bulb cooling system so it has to be properly mounted to cool
I did a quick look for the bulb and yes you can find bulb only BUT they are $10 to $20 more than the bulb and housing !
So it looks like it is cheaper to replace the bulb and housing. As a guess I would say that these bulbs are what someone has found out to be a replacement but can't purchase then as cheap. So to save yourself some money buy the combo.
Sep 14, 2011 | Philips Mitsubishi WD62525 Lamp with...
Headlamp bulb replacement - Ford Ranger
There is a threaded ring that must be turned counter clockwise to remove bulb, it can be done without removing anything but the ring once the ring is pulled away from lamp pull bulb out and buy replacement, suggest you buy two new lamps and replace withthe new halogen lamps.
Jul 05, 2009 | 1999 Ford Ranger SuperCab
Bulb replacement
Ok, you can buy the bulb separately and it will save you money. I will have to warn that , installing this bare bulb will be tricky and you can not touch this bulb with your bare hands. it will damage it. Other than that, it is possible to purchase the bare bulb alone. i will post a link to your replacement bulb without the housing below.
CLICK HERE FOR YOUR BARE BULB WITHOUT HOUSING.
Please rate and have a great weekend:)
May 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Zenith replacement bulb
I would suggest to remove the lamp from your TV and check it. You can also just buy the lamp without the other hardware.
This site seems to have good prices.
Let me know if you need any more assistance.
Mar 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
Microtek SCANMAKER I900 Flatbed Scanner Logo
50 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Tony
shelmnot
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
