Question about Garden
Cub Cadet HDS3186. Hard Steering
The hydraulic steering is very sticky and hard to turn. I have replaced the steering hydraulic motor and the hydraulic cylinder.
  • 103 Answers
SOURCE: My steering wheel is hard to turn
the Hydraulic oil is not going throw there is a blocige in the line cheers peter
Posted on Apr 05, 2009
  • 133 Answers
SOURCE: cub cadet LT1018 won't start or crank
It might be a saftey problem. But before you start changing swithches or whatever try this. If you have to lift a lever to engage the PTO for the blades try wiggling it up and down a little bit while sitting on the tractor and the brake pedal depressed and turning the key to start it.
Sometimes there is a little wearing and it won't be in the right spot on its own.
Good luck and let me know if this helped.
roundo4
Posted on Aug 08, 2009
SOURCE: Cub Cadet lt-1050 can't steer
If you purchased this unit from a home center etc. they never set them up or grease them ... if you can not steer this unit it was probly never greased at set up . you may need to remove the front spindles from the axle and remove the rust. before you reassemble be sure the grease fitting is not pluggedd up with rust as well , reinstall replace retainingclip( you will need to get a new ones) and grease your machine, also the mower spindles have grease fittings as well that need to be greased but the spindles need to be taken apart and the inner bearings seal removed to allow grease to enter the bearings
Posted on Aug 21, 2009
cincinaty5
  • 132 Answers
SOURCE: I have a Cub Cadet Tractor Model # 7260.
just replace it and fill the hydraulic fluid level resivore and it will bleed itself by turning the wheel left to right .
Posted on Sep 06, 2009
SOURCE: I have a cub Cadet M60 Hydrostatic zero turn. When
i have same mower with 200 hours after 30 mins it starts lossing steering and whining i have checked disengage and is ok
Posted on Oct 28, 2009
Have a cub cadet and steering wheel keeps turning but not turning the wheels at all now
howdie sounds like the Gear Box is broken it might need replacing or ther is a shear Pin that is Broke in ther To stop it from moving so might need to be replaced as well
Apr 25, 2015 | Cub Cadet Garden
How do I adjust he turning radius on my cub cadet rider?
actually you need to fix the steering stops and these should be on your steering castors
Sep 02, 2014 | Cub Cadet 2012 - LTX1042 KW - 42 Inch Lawn...
Pump won't fill with hydraulic oil
have to bleed air out of pump just like primeing it
Apr 22, 2014 | Cub Cadet Garden
I need to repair the steering on a Cub Cadet LT 1045 ANY HELP?
there is a plastic coupler the holds the shft to the gear they wear and don't hold the shaft tight to the gear and they jump
Jul 31, 2012 | Cub Cadet Garden
Steering wheel is hard to turn on cub cadet riding lawn mower seems locked up
Start buy checking from steering wheel down the shaft , to gear that does turning, to shaft underneath mower that goes to steering tierods , to tires. Oil and grease will do wonders on any parts that look rusty, or may be tight. Definately check air preasure in your tires. You should be fine.
GOOD LUCK.
Jun 16, 2011 | Cub Cadet Garden
I have a 2 year old Cub Cadet and I find it very hard to steer the wheels during mowing.
First grease the the axles and all steering components associated with steering, there should be grease fittings where you can pump grease into, then make sure your tires are all filled to proper psi. Good Luck...
May 06, 2011 | Cub Cadet Street Sign- tractor lawn riding...
My Cub Cadet riding mower won't turn. It just makes a clicking sound as you turn the wheel??
sounds like teeth on fan gear are worn or steering shaft and gear came away from fan gear. if fan gear worn replace if ok loosen lower steering shaft mount push tward fan gear and tighten, grease front steering spindles. or may need to replace spindle bushings.spindles too tight causing fan gear priblem
Jul 15, 2010 | Cub Cadet 42 And 54 Inch Blade Operator's...
I have a Cub Cadet Tractor Model # 7260. I am replacing one of the hydraulic steering hoses. My question is- How do I bleed the air out of the new line?
Sep 06, 2009 | Mtd Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
