Question about Garden
Husqvarna lr120 mower
The mower has gas, and the battery is charged, and the motor turns over when the key is turned, but there's no spark so the engine won't start.
  • 203 Answers
SOURCE: Mower will not start, battery cgarged up but onlhy
Check all the wiring connections on the starting system. Start at the battery. Both posts. Then, check where the ground goes to the body of the tractor. Make sure it's not rusty and making a good connection. Check the wire from the battery to the solenoid. If worse comes to worse, you can take a jumper cable and go from the battery + side and jump right to the starter post where an electrical cable connects. This will let the engine turn over, but make sure you have the mower in neutral and brakes set, with blades OFF!
Posted on Jan 28, 2010
miket756
  • 2702 Answers
SOURCE: I have purchased a Toro zero turn mower and can't
no,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
Posted on Jul 27, 2010
Knucklebstr
  • 222 Answers
SOURCE: my toro mower won't start.
The Toros have a Tecumseh engine and are famous for this. I'd suggest you do a thorough cleaning of the carburetor, but there is a little known secret that I've learned about this particular carb. Pull the bolt from the bottom of the float bowl on the carb (1/2 inch wrench; the "main jet"). Be sure that all the little holes in that jet are clean and you can stick a wire thru them. There is a microscopic hole at the very top of the threads on that brass bolt that often gets clogged and your mower will not start. I use the wire from the needle valve inside the carburetor to stick thru it, as it's about the only thing that'll fit. (note: if you have 50 year old eyes like me, you can't even see this hole w/out specs). Hope this helps and best of luck to you. (also, be sure you put the float bowl back on the right way; there's a bevel in the back that needs to go toward the hinge in the float or the float won't work. Learned that one the hard way as well. )
James
Posted on Aug 21, 2011
  • 2239 Answers
SOURCE: Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Posted on Mar 07, 2012
  • 2239 Answers
SOURCE: mower won't start spark plug turns black
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
Posted on Jun 17, 2012
Mower won't start
This may sound stupid but don't mean it to... Have you tried with the choke all the way open? Do you have an automatic cruise? Is the right (correct) pedal being pushed in? These will affect if it starts or not. Also if your drive belt or one of the other belts not being tight enough will affect if it starts or just turns over. Not too many things can stope it from starting with new/good battery AND if its getting gas. Try cleaning your gas line and obviously making sure there is no obstruction around or near your blade, if it does start with blade engaged that is :)) If it doesn't start with blade engaged, well make sure it's in neutral. Mine won't start in reverse but will in forward or neutral. Hope it helps. Anthony
Jun 19, 2013 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Husqvarna riding mower, (Model: YTH2448) won't turn over
turn on device and wait for response inspect every component for malfunction
May 13, 2013 | Husqvarna Garden
Husqvarna YTH20K46 no power. HELP!
Not turning off sounds like an ignition switch problem. Not starting - then I think you should check the Low Tension side of the solenoid again to make sure there is current from the switch. If the solenoid's OK, the battery's fully charged with all the connections clean and tight, then it has to be the starter motor or engine. Check you can turn the engine by hand, if so then I would guess, it's probably the starter motor.
Good Luck
Apr 21, 2013 | Husqvarna Garden
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
I have a yth20k46 and when I turn the switch it won't turn over. I replaced the battery and spark plugs. what might be the problem
I also have a YTH20K46. During last mow (last week), I tried to turn off mower and would not turn off by key. I had to put it down to choke and then stand up. It created a backfire. Today I went to start it, now won't start. It does not turn over. Hour meter has no power. Tested battery & solenoid. Power to both. Key switch works fine. Any suggestions? Just had it serviced a few months ago. Oil, gas and all other things seem fine. Checked wiring, seems fine. Nothing melted or cut. Please help!
May 23, 2012 | Husqvarna Garden
Husqvarna CTH180XP rideon lawn mower 42" rear
Hi Sue and welcome to FixYa, I am Kelly. You have been quite lucky to get 7 years out of your battery. Given the age of the battery that is currently installed this is most likely your problem. You have voltage but very little amperage due to thinned out battery plates.... (
Let me know how it goes.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Husqvarna Garden
My Husqvarna riding mower won't start. I was
Check to see if you left the blades engaged. There is a safety switch that prevents starting with blades engaged. Easy to miss, happened to a friend of mine last month.
If this really helpful, please rate.
Jul 11, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Riding lawnmower 42 in husqvarna i changed spark plug and gave it gas and charged the battery it acts if it wants to start but it just doesnt turn over
Have you checked the air filter? Look at the filter and hold up to sunlight if you can't see the light thru the filter then replace.
Sep 07, 2010 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
