Sony bravia KDL-32V4200
The tv turns on for a second then it goes off with series of 4 red flushing lights.
  • Pcrepair Dublin
    Pcrepair Dublin Jul 18, 2013
    So far, I have replaced the inverter and power board. I also opened up the LCD and seen the 10 CCFL lamps turning on and then off. The symptoms are still the same. Next step is to get a main board replacement and then I'll let yous know.
mistersony
  • 320 Answers
SOURCE: Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Posted on Oct 18, 2008
mistersony
  • 320 Answers
SOURCE: sony bravia kdl40s2010u
A 4 flash indicates you have a backlight problem. Either the backlight inverter boards have failed or you have a backlight that has failed in the LCD panel. You will need a technician to check the set to determine which is the problem.
Posted on Nov 08, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Posted on Mar 14, 2009
dsacco86
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
We have a 2007 Sony Bravia 46" KDL-46VL130. There is not sound or picture. When we power it on the green light comes on blinking once and then the red light blinking once and then the green light stays on....
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
Oct 09, 2013 | Sony Bravia KDL-46VL130 TV
Sony KDL-32V2500 : It comes on and after few seconds the red light blinks 4 times, then stops and then starts blinking all over again.
This is sort of a generic answer but I found this info about Sony blink codes. Hope it helps!
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Mar 05, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
Nov 03, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
