Question about Frigidaire Fad704dud 50 Pt Pint Electronic Control Dehumidifier Low Energy Star
Getting error code A5, still working but overfilling bucket
70 pt bucket not always full but water on floor
Posted on Jul 17, 2013
Why did my dimplex dehumidifier dh211 overfill with water and not cut power off when full?
Trip switch not working properly. The spring that provides the tension to counterbalance the weight of the bucket is probably set too high.
Aug 31, 2017 | Dehumidifiers
Why would the system keep running, all the time, filling up bucket, then leaking onto floor? What is my next step?
There is supposed to be an auto-shutoff float in the bucket to prevent overfilling of the bucket. You have either removed it or it is defective. The fact that it runs constantly has more to do with the humidity and the setting that you have the unit set to, Obviously there is adequate humidity in the space or the bucket would not fill. You need to look for, find, and repair the shut-off float, or, if possible, some units allow you to connect a drain hose either to the bucket or directly to the unit to drain the water to a drain. If you choose this option, remember that the hose must remain lower than the top of the bucket or it will not drain properly and the bucket will still overflow.
Jan 23, 2016 | Dehumidifiers
CH67 error code & blinking "bucket full" light
It is a well know problem , you need to replace the bucket switch
Dec 16, 2014 | LG DH404E Dehumidifier
Displaying "A5"
Do you mean error code AS instead of A5? If so, error code AS commonly refers to a sensor issue. Because it is a smaller appliance, repairs are often more costly than the actual unit replacement. You may want to check and see if your dehumidifier is still under warranty and if so, reach out to the manufacturer to determine the exact warranty coverage.
Dec 21, 2013 | Frigidaire FAD704DUD Dehumidifier
WHy does P2 code come on display for my Westpointe DeHumidifier
I could not find the user manual for your particular model but the manual for the MDF1-30AE model indicates that the P2 code is when the bucket is full or not in the right position.
If you have already emptied the bucket and the error remains I would recommend checking around where the bucket goes as there should be a switch that gets pressed by the bucket when it is in the proper position.
My guess would be that when you are putting the bucket in it is not properly hitting this switch.
Source: User manual for MDF1-30AE
Oct 25, 2012 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Jun 30, 2010 | Haier HD451E Dehumidifier
01 error code
check sw. on dehumidifier possibly stuck open
Jan 15, 2010 | Comfort-Aire BHD-501 Dehumidifier
Bucket overfills to the point of spillage
The float is the main feature that keeps it from overflowing. I have no idea why there would even have to be an adjustable component in the circuit. The float is connected to an On-OFF microswitch and may be tested with the unit set to run.
Remove the bucket and manually push upward on the float. If the unit stops running then the bucket may be misalgned,(Make sure float is on the inside of the bucket and not lodged behind the bucket).
May 26, 2008 | Dehumidifiers
Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
May 09, 2008 | Kenmore 54701 Dehumidifier
Frigidaire Fad704dud 50 Pt Pint Electronic Control Dehumidifier Low Energy Star Logo
469 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
john h
mike cooper
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
