Question about Craftsman Clamp Spreader Bar 9 31484
Reassemble clamp I need a picture of the innards of this clamp or at least some instructions as to how its parts fit together
    Top Expert:
  • Craftsman Master
  • 3,698 Answers
Searspartsdirect.com/Craftsman
Or go to the store and lok at one.
Posted on Jul 06, 2014
The trigger on my Ryobi pressure washer won't turn off and ter leaks out from it. Anyone know what the problem could be?
I had this problem as well. The valve inside the gun cracks causing it to leak. I repaired mine with fast setting epoxy and a hose clamp. Disassemble the gun taking note how the parts are assembled taking pictures helps. Look for the crack sometimes it is not very visible check the ends where parts come together. Mine was where the tube that the trigger connects to enters the tube where the hose connects to. Epoxy the OUTSIDE of the crack not inside the tube because it needs to be smooth in order for it to seal properly. Try to get some epoxy inside the crack then use the hse clamp to hold it together while the epoxy cures.reassemble the gun and test. Sometimes the O-Rings will need to be replaced oil the orings while assembling the gun to prevent damage to the orings.
Oct 25, 2016 | Garden
How to remove the armature on a Lacawanna 4-8-4 #1501?
Gain access to innards of engine, and remove the screws holding the motor together taking care not to misplace the brushes that contact the commutator. Once the motor is split open you pull out the armature and replace it or clean it as intended.. Reassemble.
Aug 20, 2016 | Crafts & Hobbies
I have a Brother XR-65. The needle bar fell out as I was sewing. I need a repair manual or some instruction on how to secure the needle bar in the machine. I have the bar itself and a pin sized piece of...
This was happening to me also - you have to tighten a different screw than the one that holds the needle in.
http://www.sewingpartsonline.com/needle-clamp-screw-brother-ls-2125-sewing-machine.aspx
My husband thought the screw was missing - it is actually a plastic screw with a hole in it for a tiny allen wrench.
You can see it in this picture also
http://www.sewingpartsonline.com/needle-clamp-babylock-brother-xz0001051.aspx
If you look at the photo of the screw I attached, you can zoom in and see it has a hexagonal hole.
It is above the flat head needle clamp screw (the one that holds the needle in)
It is REALLY annoying that this screw is mentioned nowhere in the manual, and the hex allen wrench is not included with the machine.
Kind of an important little detail, considering it holds the needle assembly together... you'd think that they would have told you about it.
Sep 09, 2011 | Brother Sewing Machines
Diaper genie 2 fell apart and can't figure how to get it back together. The flapper with spring attached to it will not go back together. Are there any diagrams to put it back together.
There are two parts to the diaper genie clamp mechanism. Look closely at the cutaway view of the diaper genie at this link: http://playtexbaby.com/App_Themes/PlaytexBaby/pdfs/DiaperGenieIIAdvanced_OwnersGuide.pdf One part that has the cutter, and one part has the spring attached to it. If you look closely at the illustration where it is labelled "clamp" and follow the black line it actually points to the spring - its just such a poor quality image you might miss that detail. Look at the orientation of the parts to each other in that illustration so you know which direction the parts go. To reassemble, starting with the part that has the cutter built into it, slip the end of that part that is opposite the cutter under the spring on the second part. When assembled, the smaller part of the clamp slides upon the other part, and when the clamp,is pulled apart the spring tension pulls the two parts back together. These two parts, once assembled, snap into place inside the top of the diaper genie.
Aug 20, 2011 | Playtex Diaper Genie II Elite Diaper...
The mechanism inside my diaper genie II fell apart. I need some pictures to see how it goes back together.
Jul 28, 2011 | Playtex Diaper Genie II Elite Diaper...
I purchased a Hyundai 00285-03006 fully enclosed luggage carrier and the instructions are one picture with no words. The picture does not describe where the carrier is in the picture, where the rails fit...
That same luggage carrier is sold (as OEM approved equipment) for MANY different makes and models of automobiles. From what I can see, it simply clamps onto the cross-rails on your luggage rack. (Not much instruction needed) It does require however, that you have a luggage rack and a cross-rail kit. The cross-rail kit is sold separately. I would give you the part number, but the cross-rail kit varies depending on your make, model, and year.
Cross-Rail Kit
May 22, 2011 | Hyundai Veracruz Cars & Trucks
Drive lever
that bracket is worn.....[ part number 557689 A ]...but is tricky to reassemble....
May 20, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Craftsman Clamp Spreader Bar 9 31484 Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
