Question about Kenmore Refrigerators
Kenmore elite error code ef
Displays this code and top have of refrigerator section is room temp. Freezer temperature is normal
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
  • 145 Answers
SOURCE: My Kenmore Elite refrigerator keeps freezing the food!
Replace your thermostat and will work like new again
Posted on Jun 07, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
  • 93 Answers
SOURCE: What temperature should we set the refrigerator and the freezer?
Totally up to you. Most people set them for the temp they like their milk and the firmness of their icecream
Posted on Sep 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: Problems for Refrig. Kenmore Elite
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
Aug 20, 2015 | Miele KFN12923 SD-2 Stainless Steel 369 l...
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
I have a code a code one the front where it show the freezer and fridge temps. the code is ER FF. It is a kenmore elite double door with the freezer on the bottom.
http://www.managemylife.com/mmh/owner_manuals/16224/KENMORE-Bottom-Mount-Refrigerator-L0306154?brand_name_search=73502
go to normal operating sound section. f= heatexchange. so you have to check condensing unit fan and clean the coil.evaporator fan .if the frost build up to block air way. you have to check heat element and defrost thermostat. good luck
Jan 10, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
I HAVE AN ERROR CODE dH on my Kenmore Elite bottom
Apr 14, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio Model 795.7757960 - Error Code 'IF'
Hi!!! You have a control board problem.Change the control board and you should be okay..Them boards did'nt come out good.Good luck..
Jan 04, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator not cooling
This could be that it is out of balance. Set the temperature settings to midway. This control can easily get the fridge temp out out of balance if over adjusted. If you already have the tmp control at midway then you need to make sure there are no obstructions to the duct that carries the cold air from the freezer to the fresh food section to cool it. Check for ice buildup or any kind of blockage. Let me know what you find.
Nov 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
29 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
