Question about Garden
X520 jd mower trouble
This x520 j.d. mower stalls when I engage PTO for deck carb. has been cleaned new coils new pto clutch new belts new pulleys . I have checked all safety switches ,all blades turn by hand freely , also checked compression has 175 on left and 135 on rt. when engage pto tries to turn motor pulls down pops and backfires through carb then will die if I do not shut down PTO if it dies motor will start up . PLease Help can engage belts slowly by hand and mower works good.thanks papawpt
    New Friend:
  • 17 Answers
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Posted on Jul 20, 2013
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
huffman49
  • 235 Answers
SOURCE: Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
Posted on Apr 03, 2010
  • 394 Answers
SOURCE: DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Posted on Apr 30, 2010
Testimonial: "Hit on the head with such a simple solution"
  • 18 Answers
SOURCE: PTO loads engine down and almost quits running!
pto is going bad
Posted on Jun 06, 2010
yakuzza2
  • 68 Answers
SOURCE: craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Posted on Apr 17, 2012
I have a John deereL130, deck rusted so I got one from a JD L100 it has a manual pto lever to engage, but my L130 is electric pto.it mounted easily,do I need to add tensioners to deck for it to work
On the electric clutch method the belt from the engine pulley to the deck pulley is tight all the time, yes it normally has a idler pulley with a spring to keep it tight. The spring is needed so do not omit it and lock it solid or it will shake itself apart. Hopefully you can copy your L130 deck as well as use the idler and spring from it.
Apr 29, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
John Deere 265 replaced pto switch on dash pto drive belt and mower deck belt still pto does not engage...also randomly blows 20 amp fuse from time to time when pto would engage previously...checked...
The electrical is part of the PTO clutch assembly. It should only draw 5-7 amps. Ohm reading is somewhere between 1.7 to 2.5 ohms.
These coils do short from anywhere from a partial short to completely.
Jul 26, 2014 | Garden
Mower stalls
make sure belts arent around the guides to keep the belts on.
does it smoke or make any other noise
why did yu change all the parts
Jul 09, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
JD STX38 mower stalls when deck is lowered
If the belt bounces then it has stretched or the belt tightener is not working. properly. Also check the shear pin in the drive pulley. If it has sheared the blades will try to turn but slip when any pressure is put on.
Jan 07, 2018 | Garden
Replaced belt for mower thought i put it all back correctly blades engage when key is turned engage lever to off what did i do wrong
If you look at the motor pulley area, there should be two different pulleys with a PTO clutch between them. The PTO clutch has wires going to it, because it is operated electrically by the blade engage switch.
It sounds like you could have accidentally put the mower deck belt onto the main drive pulley (which turns all the time) rather than the pulley that is farther out from the engine, which only turns when the engage the blade switch. If so, just loosen the mower belt and move it to the right pulley.
Jun 09, 2010 | Garden
John Deere x520 pto issue
not trying to insult your intelligence, but did you make sure the belts were installed properly.it does happen to the best of us..good luck
Apr 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
235 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
