Question about Panasonic SA-HE200 Receiver
Overload When I turn the receiver on it flashes overload and there is no sound
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
That means you are trying to pull way to much power from the receiver and it can not supply the power needed
Posted on Jul 17, 2013
Overload keeps flashing
Remove anything that may be sitting on top of it, and give it at least 6" of clearance all the way around it to help dissipate heat and leave it that way
permanently.
Next check that the speakers you are using have a compatible Ohm rating for the receiver.
Dec 19, 2009 | JVC RX-558V
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
VSX-D608 Overload and shutdown
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
No more than two 4 Ohms speakers can be connected to the unit, or you will get overload.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
Jun 22, 2009 | Pioneer VSX-D608 Receiver
Overload flashs
there will be 6 amp circuit in your receiver. you can't unplug them one by one. with a multi-meter you may be able to find the shorted channel. (most JVC receivers use discrete circuits instead of an output IC) Check for shorted transistors attached to the heat sink. You will possibly find some open resistors also. Generally this is a job for a pro.
Feb 26, 2009 | JVC RX-6042 Receiver
Overload
The audio amplifier IC of your device are damaged you gotta send to a repair center.
Jun 04, 2008 | JVC RX-6042 Receiver
Jvc receiver OVERLOAD
possible short across speaker wires somewhere or even inside speaker
Dec 21, 2007 | JVC RX-6000V Receiver
Overload...
Pioneer posted this on it's Canadian Web Site:
Poor wiring connections, bad wires or a bad speaker may cause this. As you increase the volume, you will increase the amount of current you are drawing from the receiver. To troubleshoot this issue, try the following:
  1. Disconnect each speaker wire connection. Inspect for any frayed or damaged wiring and replace it.
  2. Check the impedance of the speakers; make sure they are properly rated for your stereo. In most cases, they need to be 8 ohms. Only a few Pioneer receivers will support lower impedance.
  3. If the problem still continues, try these steps:
    1. Turn the receiver off.
    2. Remove one speaker.
    3. Turn the receiver on.
    4. Increase the volume.
If the receiver overloads, repeat steps 1-4 (selecting a different speaker each time). If you disconnect a certain speaker and the receiver no longer overloads, have this speaker checked at a service center. It could have a bad speaker component, like a tweeter, sub-woofer, or even a bad crossover.
Dec 08, 2007 | Pioneer VSX-D514 Receiver
Overloading
What speakers are you using? Are they seperate from the TV set? How is the audio attached to the TV set. What inputs I mean are you using for the speakers and the sound for the TV set?
Dec 08, 2006 | Pioneer VSX-516-K
Overload
Firstly check all your speaker wiring. Any damage can cause a short which will overload the system. You might not notice it, due to the fact that when you have the system on loud, vibrations move the wires on the cabinets or elsewhere. So make certain there are no loose wires near the speakers terminals into each one. If all that is good go to the next check.
Check If the amp is getting VERY hot when the overload occurs, then it might have a faulty part(s) on it. This might have occurred if you have been using speakers that never did match the amps requirements in the first place.
Mar 12, 2017 | JVC RX-668V Receiver
Panasonic SA-HE200 Receiver Logo
85 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
