Question about Ricoh Office Equipment & Supplies
Squeaking noise loud squeaky noise on my printer
khanmohammad
  • 188 Answers
SOURCE: squeaky HP printer
Hi Bryn,
Please click on the web link given below and perform the steps carefully as provided in the web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00743863&cc=us&lc=en&dlc=en&product=1146331
This should help you out fix the issue
Have a great day!
Posted on Mar 25, 2008
SOURCE: Squeaking
that's a mechanism issue inside..it's going to fail quite soon, so you may not have this problem for too much longer.
Posted on Aug 20, 2008
gwbm
  • 353 Answers
SOURCE: squeaky noise
When you first start the printer, the print head is moved over a rubber blade to "wipe" the print head. Sometimes it will also carry out a head-cleaning cycle. The sheet-feeding roller is rotated to ensure it is in the correct position. So, it seems likely that the squeak comes from the paper feed mechanism. The problem is, you will have to remove the printer top cover to make a more detailed diagnosis. This is not simple without the right tools and knowledge. If you feel game to give it a try, you can obtain the Service Manual quite cheaply from the internet - see for example:
http://www.2manuals.com/product_info.php?cPath=2_39&products_id=647
Do a search - it may be cheaper elsewhere. I will also produce a short tutorial on doing the job to cover the bits the service manual doesn't explain!. Post a new comment if you want to go further.
Otherwise, it's a trip to the repair shop - or just leave it until something fails!
Posted on Mar 03, 2009
Typically the squeaking comes from the toner cartridge. If you just purchased it, take it back, it's bad. If you can find an identical printer, swap cartridges and see if it makes a difference.
Posted on May 27, 2009
SOURCE: makes a loud squeaky noise
hi do one thing that at the right side do you have any thing stuck whih is causeing this problem..open the rear door of the printer and try to clean the rollers..close every thing if its working then grt! else its causing this problem because the encrouder srtip is gone bad...so you need to replace that ..in order to resolve this issue..
Posted on Jan 26, 2010
Much will cost replace power steering
the hard power steering is given away by the loud squeaky noise . It is the drive bely slipping from worn out or needs adjustment.. If the key problem is in the switch the replace the switch of if it is not engaging the starter motor have a look at the battery connections (shiny clean and tight) or the solenoid or starter relay.
Jan 09, 2014 | Mercury Cars & Trucks
Squeaky noise
You clean the printer by running cleaning pages. You can find "Cleaning Page" in your printers menus. As for the "squeaky noise", I have found it is the worst with "recycled" toner and toner kits. Finding the cause of the squeak is a very difficult thing to do. You will need to remove the front, back and sides of your printer and check all the nooks and crannies for the squeaky wheel. I have been able to remove the squeak by installing a manufacturer original toner. "Cleaning" the rollers usually has nothing to do with the squeak.
Nov 19, 2013 | HP® LaserJet M5035 MFP Laser...
My dryer makes terrible noise when tumbling. It is a loud squeaking noise. Is it a belt that needs to be replaced?
Loud squeaky noises are usually a dry bearing--in this case, probably the one(s) that hold up the front of the drum. Open the top to inspect, then remove the front panel to replace or repair. Hope this helps!
Oct 23, 2010 | Frigidaire Dryers
Loud squeaking and rattling when you accelerate after a stop
Is the underside rusty? If so, take it to a qualified welding and autobody repair shop to have new metal welded on.
Your symptoms sound like the engine or transmission mounts may have deteriorated.
Jul 04, 2010 | 2003 Chevrolet Blazer
Loud squeaky noise from front tires when turning and somtimes whe
Hi my name is Tom and I can help you.
Driving with your emergency brake on is only going to affect your rear brakes. There is a cable running from the emergency brake lever to your rear brakes.
You did not say how long you drove with the emergency brake on, but even a short distance and you forced the front brakes to do the work of stopping the car. This causes overuse which translates to heat. When the brakes over heat they "fade" and do not stop the car effectively.
In addition the heavy load of doing all the stopping causes the brakes not to realign. Therefore, when you go around corners the brakes pads will rub against the rotors.
I would suggest you get the brakes looked at or look at them yourself. I can help you do the job but I would need to talk to you directly. Let me know what I can do to help.
TomE
Jun 29, 2010 | 1995 Ford Escort
Makes a loud squeaky noise
Jan 25, 2010 | Brother MultiFunction Center MFC-440CN...
Loud squeaky rear wiper on a 2000 odyssey.
Before you go through the time and hassle of removing the motor itself, spray some WD-40 or something similar on the shaft that goes to the motor...could be the weather seal is dried and squeaking.
Dec 13, 2009 | 1999 Honda Odyssey
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
15 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
