Question about Lands Phones
Periodic beep on Uniden Cordless 5.8 GHz phone
I have a Uniden cordless 5.8 GHz phone with 3 handsets and answering system. About every 10 minutes there is a beep that seems to come from the main base. There are no new messages. The phones all work for both outgoing and incoming calls. The power was recently out for 45 minutes but the phones seemed to work afterwards. I did reregister all of them to be sure, and I reset the time. I also unplugged the phone and plugged it back in. Any thoughts on how to get rid of this annoying beep? I just set this new phone system up the first week in August. It is a DXA15588-3 Series.
  • scottsupa Apr 22, 2008
    same problem here, hope someone knows what is wrong
  • Anonymous Aug 20, 2008
    I have the same problem and it is extremely annoying. I sent an email to Uniden customer support several weeks ago. I never got a response. I suspect that they did not respond because they know it is an inherent problem in the model that can not be corrected. I am going to buy a new phone from another company. I will never buy a Uniden product of any type again.
SOURCE:
  • 4102 Answers
SOURCE: AT&T 2230 2.4 GHz Dual Handset Cordless Phone - additional phones?
Hi yes you can add additional phones to it as long as their the same frequency so that they pick up the signal from the main phone that plugs into the phone line.
Im sure you can have upto 4 handsets but just make sure theis same make and frequency
Posted on Jan 29, 2008
  • 82 Answers
SOURCE: Uniden 5.8 GHz Digital cordless w 3 handsets interference background noise no matter where we are in the house or which handset we use
This is possibly caused by the internet connection.
Try new ADSL filter.
You need one each per device.
Posted on Oct 14, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 5 Answers
SOURCE: Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Posted on Mar 19, 2010
hmerchant110
  • 7191 Answers
SOURCE: need a operating instruction manual
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on Jul 02, 2010
THE BASE SET OF MY UNIDEN 1480-3 CORDLESS PHONE NO LONGER BEEPS WHEN I HAVE A NEW MESSAGE. CAN ANYONE HELP?
You can set or change the answering system options from any handset.
Open the menu and select Ans setup then select Message alert and activate it!
Beeps will be on!
Oct 05, 2014 | Uniden DECT 1480-3 Black Cordless Phone w/...
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
How to enter menu
Called GE Thomson @800-448-0329
Feb 24, 2010 | Uniden Cordless Phone
Can't listen to my voicmail
Click on a left side link of download manuels. ------------ 40000 series DS4122-4 ------------ 50000 series cs5121-4 ------------ i6785 English Not sure what series you have, but take a look at these manuels. found here :http://www.vtechphones.com/vtechui/support/manual_list.cfm#214 if not anyof these listed- there are many others to view and I know you'll find right instructions here!! Let me know if this helped.--Stevie ----------------------------------- 5.8 GHz Digital four handset cordless phone system with digital answering device and caller ID ------------------------------- 5.8 GHz digital Four Handset Cordless Phone System with Digital Answering System and Caller ID --------------------- 5.8 GHz Digital four handset cordless phone system with digital answering device and caller ID i6785 - Spanish 5.8 GHz Digital four handset telephone system with digital answering system english i6786 5.8 GHz digital four handset cordless phone system with caller ID and digital answering device i6786 - Spanish 5.8 GHz digital four handset cordless phone system with caller ID & digital answering system
Feb 14, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
No dialtone on handsets, 3 beeps sound
Deregistered 4 handsets, on suggestion from FixYa, by pressing hangup & # sign.
Then reregistered to base.
May 08, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Handsets give 3 beeps, no dialtone
Either they are not powered up, or the mother has lost power.  Make sure the mother and children bases have power and leave the handsets in the bases long enough to charge.
I am having problem with my cordless phone.
Another tip is to remove the battery from the handset for at least 5 seconds. You might want to get a voltage meter and check the voltage on that new battery - maybe it isn't charging properly.
Mar 13, 2009 | Uniden Cordless Phone
Oct 06, 2008 | Uniden Cordless Phone
Open Questions:
Lands Phones Logo
505 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
