Question about Health & Beauty
Shoprider scooter 889XLS. TURNS ON, REVERSES OUT OF GARAGE. DRIVES ABOUT 3/4 MILE AND STOPS. TRIGGER THROTTLE, RESULTS IN A SUBTLE CLICK OR SHUNT UNDER THE SEAT, FOLLOWED BY NO MOTION AND ENDLESS BEEPS. AT RANDOM, SOME TIME LATER, IT WILL WORK AGAIN. ALL LIGHTS, SIGNALS AND GAUGES ARE NORMAL. IF I TRY TO GET IT GOING BY RECYCLING THE ON-OFF IT WILL AGAIN CLICK WITH A SUBTLE NUDGE AND BEEP. PRESS THE DRIVE TRIGGER AGAIN AND ABSOLUTELY NOTHING HAPPENS. IN MULTIPLE EXPERIENCES HAVE RECYCLED THE FREE WHEEL. THE FIRST TIME THE SYSTME RETURNED BUT NEVER AGAIN.
  • 323 Answers
SOURCE: 7436 beeps problem
Raise your button hole lever which is near the presser foot.
sewman7
Posted on Jun 19, 2008
  • 107 Answers
SOURCE: Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Posted on Jan 25, 2009
dromtonpa
  • 40 Answers
SOURCE: The scooter will just start beeping 7 times and then won't go.
Call pride. That is under warranty. The will replace it.
Posted on Apr 06, 2009
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
Posted on May 07, 2009
  • 29 Answers
SOURCE: Hi I have a shoprider cadiz .. when i try using
your throttle pot needs replacing. your thumb lever attaches to the throttle pot.
Posted on Nov 20, 2009
Testimonial: "Wonderful information Thank you ..before i read your answer i sprayed the throttle pot as you call it with switch cleaner Been great since .. "
I have a shoprider echo when I turn it on the power meter works. The horn works. But there is a beep every 3 seconds. Please help
Your Throttle maybe out of neutral when you start the scooter.
Make sure your parking brake lever is on so the scooter is hard to move. If it is easy then it is not on and won't drive. Make sure there are not any cables that are disconnected to the motor and brake. Scooter Doctor App
Apr 28, 2016 | Shoprider Health & Beauty
When throttle is applied, right wheel drives, left wheel locks within a few feet, keeps moving, but drags left wheel.....
I had similar problem on my Hoveround. Replaced controller with one I found on eBay. Works great now.
Mar 03, 2015 | Shoprider Sprinter Deluxe Four Wheel...
How to replace tension spring for throttle pot
Hi, if you are based in the UK i can install one for free of charge however you will have to pay the returned postage...
Regards
Rob
www.gewizrepairs.co.uk
Aug 06, 2014 | Echo 3 TE SL7 3 New Electric Scooter by...
Altea 4 stopping an alarm going of
Hi, normally this is a loose connection.... Could also imply the throttle is worn , try pushing the lever in the upwards or downwards direction.. Does it cut out ?
Regards
Rob
Jan 01, 2014 | Echo 3 TE SL7 3 New Electric Scooter by...
Shoprider Echo 3 throttle spring
hi ,so me picture of this string , i have loads of strings , make sure i send you the right one :)
Regards
Rob
Aug 28, 2013 | Echo 3 TE SL7 3 New Electric Scooter by...
Cant get the printed circuit board repaired or replaced for Madrid scooter
The Madrid scooter is a Shoprider scooter. The controller can be repaired by calling 800-798-0325 (Monster Scooter Parts). If you open the controller there are 2 fuses inside which are replaceable and may be the cause of the problem. I have attached a link to the service manual available for download. Refer to Page 14-15 for specific controller info.
http://www.centralmobility.co.uk/includes/pdfs/scooters/Scooter%20Service%20Manual%20Live%20Document.pdf
Aug 05, 2012 | Electric Mobility 4 Wheel Power Electric...
Constant beeping, won't run
The beeping on shopriders usually means that the Main Control Box is faulty. It may also be caused by the Throttle Pot being out of neutral. This is a common promlem on this model of scooter as they use a Plastic throttle control lever instead of a metal one. Unfortunately, the plastic one's sometimes slip round slightly causing the above problem. Throttle pots can be very difficult to set to neutral without a multimeter so may be best left to you local dealer.
Jul 01, 2010 | Echo 3 TE SL7 3 New Electric Scooter by...
Health & Beauty Logo
21 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
