Question about Jandy Pool & Spa
My Jandy 2Hp Pool Pump stopped working
Is there troubleshooting I can do to find out if it needs to be repaired or relacedD
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
See if there is voltage going to switch then to pump if voltage at pump bad pump make sure wires are tight if using a system make sure relay is plugged in then make sure voltage coming out of relay also
Posted on May 21, 2014
4 Suggested Answers
  • 77 Answers
SOURCE: JANDY JHPU2.5 POOL PUMP WILL NOT WORK
Did you separate motor from pump? If not, then there is most likely small debris lodged between impeller vanes which must be removed with a small pick or wire. hope this helps.
Posted on Apr 14, 2009
  • 16 Answers
SOURCE: Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
Posted on Jan 16, 2010
MOTORWIZJ
  • 1339 Answers
SOURCE: Hello , I have a 5yr old pool complete with
ALWAYS FREE.. SO IT SEEMS THAT YOUR NOT GETTING AIR, THESE BLOWERS HAVE FOAM IN THEM AND CAN ,AFTER A FEW YEARS GET CRISPY AND BREAK UP AND PLUG THE AIR PUMPS SUCTION PORT. THE FOAM IS USED AS A AIR FILTER AND A NOISE REDUCER , WHEN THESE BLOWERS GO BAD 90% OF THEM CAN'T BE REPAIRED ! = JUNK.. TO SEE IF YOU HAVE A RESTRICTION IN YOUR LINE OR LINES ,USE A SHOP VAC TO **** AND BLOW THE LINES IN AND OUT.. THESE BLOWERS ARE HELD IN USUALLY WITH ONE SCREW AND ARE EASY TO REPLACE ONE MORE CHECK 4 YA IS, THERE MIGHT BE A CHECK VALVE INLINE ON THE BLOWER , IT MAY BE BAD . BEST WAY TO CHECK IS TURN THE BLOWER ON FIRST , THEN TURN THE WATER PUMP ON.. HEY IF'N I WAS OF HELP GIVE ME A REVIEW OR A THUMB.. JAY YOUR LOCAL POOL PUMP WHISPERER IN FLORIDA
Posted on Nov 16, 2010
Testimonial: "Thank you -- the 2hp motor provides air induction and bubbles. There is no foam to break off. I did blow system out , still the same. Will keep lookin"
How to reset raypac pump that just stopped working
try turning the shaft on the back of motor then turn on if this doesnt work you need a new one
May 28, 2014 | Hayward 2HP Pool Pump Motor A O Smith...
Jandy Zodiac FloPro 2HP connecting Red Wire to which screw L1 or L2?
follow the owners manual.
if you are hooking this pump up as 220v, you will have two hot wires. one goes to L1 and the other to L2. it matters not which is where as they are both supplying power. be sure to connect the internal ground wire AS WELL as the bonding wire to the outside lug
Apr 28, 2014 | Zodiac Jandy 2Hp Flopro Pool Pump For...
Does the Red wire connect to the L1 or L2 Screw
when hooking up a pump on 220v, there are two hot wires. it doesnt matter which hot wire goes where. both L1 and L2 are power terminals
Wiring diagram for jandy flopro pump
look on side of motor for low or high wiring
Jun 21, 2012 | Jandy Flopro Medium Head 2hp Up-rated...
Jandy pump 120volt
look on side of motor schematic for low and high voltage wiring
Hello , I have a 5yr old pool complete with Hayward Filter and a 1hp pool filter motor and 2 hp spa air injection motor connected to an air switch the in ground pool is 32K gallons. Problem is with spa air...
Nov 15, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Just replaced my Emerson 2hp pool motor. Turned on new motor all is working fine but water isn't filling the basket?
First of all you need to fill the pot with water. it is best to pour a bucket in or use a hose and turn the pump on and off real quick a couple times to **** some water into the pump. Once you do that fill the basket as much as possible and quickly put the lid on and turn on (make sure your lid o-ring is there and in good shape. lubricate it with pool lube so it's wet but not all gooped up). when you turn the pump on you should see water either splash, or at least start trickling into the pot. if you see water splash in, but then go dry again, or if it just trickles but doesn't prime after about 20 or 30 seconds, then you may very likely have an air leak on the suction side. Make sure your lid is sealed, the pipe goin into pump is not loose or leaking air, and make sure the pool cleaner hose is not out of the water, or the skimmer sucking air. If the pipe coming into the pump is sucking air or you suspect it might be try wrapping black electrical tape tightly all around the joint (where it threads into the pump). This is temporary troubleshooting step but works great. If there is a union or a Jandy valve where the pipe comes into the pump check o-rings and all joints for leaks.
Jun 23, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Have 2hp northstar pump and its humming and flipping the breaker and then stops. How do we get the pump apart to see if we need to replace motor or propellor?
THIS IS A HARD PUMP TO WORK ON ! TAKE THE QUICK FITTINGS OFF AT THE TANK AND DISCONECT THE POWER LOOK TO SEE HOW TO PUT THE WIRES BACK UP (PICTURE) AND SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY .. WARNING THE HP IS MISLEADING ON THESE PUMPS , YOU MIGHT HAVE A A 2.60 HP MOTOR.. LOOK FOR THE SF ON THE MOTOR LABEL .. HAVE THIS READY WHEN YOU CALL TO FIND A MOTOR ! REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 29, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Pool & Spa Logo
65 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
