Question about Freezers
How old is model fv21m2wlfa serial # 1016396683
How do i find out how old a freezer is?
Search online to find the manufacturer's website. Call or email them. Be sure to have the model number and serial number. They should be able to help you.
Jan 07, 2015 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Freezer age and kwh usage for kenmore 2722
go here,put the name,model and serial numbers in and it will tell you how old any appliance is.
http://www.appliance411.com/service/date-code.php
Jul 10, 2013 | Kenmore Freezers
How do i replace a wheel on a beverage air freezer
For Service Call (877) 866-1223 Beverage-Air Corporation Offices: 3779 Champion Blvd., Winston-Salem, PA 15825
_________ Manufacturing/Shipping/Receiving: Brookville, PA 15825
Contact with Model Number and Serial number for assistance
Beverage Air
Sea Breeze
Feb 26, 2013 | Freezers
Lid on chest freezer will not securely close Model #FCM 7DAA WH Serial #RTI63278 Mfg 81998
Remove lid, squeeze hinge back into shape and refit, adjusting screws in rear of hinge bracket as you do.
May 19, 2012 | GE Freezers
How old
May I get the model and serial # to help you find out the year.
Jul 02, 2010 | True 49 cu. ft. / 1388 liter Commercial...
I would like to have a wiring diagram for a model 6125 freezer
http://www.delfield.com/docs/uploaded/del/manuals/archive/dm6000.pdf
Start with this web site. It has Delfield old manuals. Page 6 has wiring diagrams.
Hope this gets it for you.
Oct 20, 2009 | Delfield Freezer 6125XL-S
Stand up freezer builds up frost quickly
It sounds like you may be on the right track here. If the gasket is old, hard, and brittle, it will allow moisture to be administered into the freezer, causing frost buildup. Not to mention, that old door gasket is leaking out a lot of cold air. Your best bet is to provide the model number (as you've shown here) and the serial number to an appliance parts store or authorized GE appliance parts outlet. They should be able to provide you with a brand new gasket. Removal and re-installation of the new gasket is fairly simple and you'll notice a big difference, not only in the lack of frost buildup on the inside of the freezer (especially in the summer) but you may even see a noted improvement on your electric bill as well!
I hope this helps and let me know if you need any further assistance! :)
Sep 22, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Freezer has difficulty shutting off
Check the relay located on the compressor on the back of the unit. Sounds like the relay is not completely shutting down the compressor. Almost like it is still allowing electrical currents to get to the compressor
Feb 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
No instruction manual
The name plate on the freezer should give a model and serial number. Without it you are just chasing the wind.
May 14, 2008 | Freezers
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
