Question about Baby Gear
Pennine sterling folding camper awning instructions
Iv just bought a pennine sterling and tried to put on the awning , i thought it would be simple but i couldnt figure it out ,,please help..
5 Suggested Answers
  • 10865 Answers
SOURCE: can you please tell me how to fold and expand the stroller
Call 1-800-671-1701 provide model and your email address
and they will email you the manual. Hope i was helpful
Posted on May 20, 2009
lingIT
  • 105 Answers
SOURCE: need instruction for mamas and papas p3 pramette
hi keelyharwood..pls visit this link. they have available instruction manual for download for pliko p3. hope it helps. good luck!!
http://www.pegperego.com/pegcatalogue/juvenile/downloads/P3-USA_FIUS0801I72.pdf
Posted on May 23, 2009
macnutz
  • 541 Answers
SOURCE: i bought this pram, but iv lost instructions for
Check out www.karlisles.com.au they have a large collection of manuals.
Posted on Jan 24, 2011
macnutz
  • 541 Answers
SOURCE: we bought the stooke stroller and folded it down
You will find your manual here. www.karlisles.com.au/baby_repairs_spares/instruction_manuals.html
Posted on May 15, 2011
I want to replace canvas on jayco camper
take the camper to a jayco service center and get the correct replacement items for that camper
then it is a matter of removing all the fitting strips to allow removal of the old canvas and the fitment of the new items
a clue her is to when the new canvas id fitted is to leave the camper opened up and to wet the new canvas with silicon fluid and allow it to dry put before folding it away
why , it stops water coming through the canvas when touched in the rain and prevents mould if folded away when wet
Jun 14, 2016 | Jayco 2008 Baja 10Y
The awning has two rollers and is manually operated, but we can't figure out how to use it
Teresa, I will post links to videos on awning set up and use. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Use the Awning on Your RV
RV Awning Tutorial
1 How to Open RV Awning
How to Use and Maintain Camper Awning Pete RV Service Tips
May 25, 2016 | Dometic A&E and Carefree 18 Universal RV...
Awning instructions
go to Campers World
Aug 18, 2014 | Optics
Trigano cheverny tent
Untie the cover and pull it back. Then unfold the camper trailer either sideways or backwards. Anchor with pegs, add poles and ropes as necessary. If you have specific models in mind, there is often a youtube video on the model that you're working with.
May 19, 2014 | Camping, Backpacking & Hiking
Looking for bottom mounting brackets for Coleman awning for my camper. It's a 12' long awning that pulls out on a winding tube. The arms that support it slip onto bottom mounting brackets on the camper. ...
Maybe these websites will help. The first one has a huge selection of parts. I am pretty sure you can find what you are looking for at one of these places. If they can't help you please let me know and I will keep looking. They are:
http://www.go-rv.com/coast/do/catalog/main?dealerId=66
http://www.marksrv.com/ultrahardware.htm
Aug 10, 2009 | Coleman Sport & Outdoor - Others
We just purchased a used '99 Starcraft Field & Stream PUP. There were no instructions for setting up the awning. I need step-by-step ''how-to'' help since everything I've found says, ''raise support...
I had exact same problem on my 93 popup. I finally figured it out. First, the poles with the plastic rings slide into the poles with the metal rings. These are the vertical support poles. Next, the poles w/ plastic nipples slide into the other poles with rubber ends. When put together the poles with the nipples should be spring loaded. These spring loaded poles rest against the top of the camper and the nipples are inserted into the 3 holes of the pole that go across the front of the awning giving you rafter support. The tension from the spring should keep the pole in place against the side of the camper. The first 3 poles with the plastic rings go from the ground to the front awning pole where the nipples can slide through the plastic ring and then into the awning pole. The vertical poles can be adjusted for height by sliding them up or down and then twisting them like a screw to tighten them up and keep them in place. 2 of my 3 vertical poles will not lock when I twist them so I have to get tricky with them. The metal rings, which should now be at the ground, are there so that you can stake it down under windy conditions. I hope this wasn't too confusing but I beleive it will help you. Good luck!!!
May 14, 2009 | Sport & Outdoor - Others
Wood Lining to Folding camper is wet
the best solution is to remove the spongy wood and replace with marine plywood
one possible fix is to glue(liquid nails) 4x8 vinyl sheets(used for bathroom walls and ceilings) over the spongy wood you should also determine where the support ribs are located and use rust proof exterior ( like deck screws) and put a washer through the screw and screw through the vinyl and sponge wood into the rib/stud to secure the vinyl do this about every 10 inches on the supports
finally caulk the edges and seams and put a lattice type of slat(1inch wide by 3/8 thick by 8 ft long on all exposed seams
tools needed small gig saw variable speed drill
caulking gun
I
Sep 09, 2008 | Sport & Outdoor - Others
Dorema awning` SOS
http://www.dorema.co.uk/awnings.html
try the above URL
Love and kisses to you also.
May 29, 2008 | Freezers
Baby Gear Logo
80 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
