Platter Grinding Noise on Aiwa PX-E860
I started notice a loud grinding noise from time to time on the back of the music and now the noise is continuos. It's coming directly through the mechanic motion of the platter. Whenever the platter is spinning, with or without a record on and with the turntable connected to the receiver or not. Took off the platter but did not sea any strange thing inside (anyway I can't be sure as it was the first time in my life that took off the platter from a turntable.) Any help on what to do? One more detail. Sometimes, after not using the thing for many hours, I put a record on and it plays it without making the noise for two, three or four songs, but then starts again. And, as I said, the horrible and loud grinding noise is not coming through the speakers. Thanks for any advice you can give.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
If the platter is scraping, then the spindle bearing that holds the platter up, has either loosened or has gone bad. If you need more assistance, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
Posted on Nov 27, 2014
  • Audio Player... Master
  • 5,047 Answers
Try to determine if the noise is caused by the motor or the platter touching something. Try moving the platter by hand. Press on it whilst turning to see if it's catching. If you can get the platter off you could try some silicone grease on places you think touch one another.
Posted on Jul 19, 2013
lesliemurphy
  • 69 Answers
SOURCE: A needle for AIWA PX-E860?
try this company?
mailto:info@needledoctor.com
Posted on Oct 07, 2009
djproaudio
  • 515 Answers
SOURCE: Platter not spinning properly
Make sure the platter is seated correctly. Lift it off, and set it back down. Also check to see that there is no debris or foreign matter stuck underneath the platter or where the platter sits.
Check to make sure the platter itself is not bent or warped. Do this by removing the platter (lift up), and then put it on a flat table/surface. Look at it from the side. Is it warped?
Hope this helps
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Posted on Jul 24, 2008
djproaudio
  • 515 Answers
SOURCE: Aiwa PX-E860 turntable
Don't understand. If it doesn't turn on, how do you know the electronics are ok? More than likely your transformer shorted, and will need to be replaced.
Posted on Sep 24, 2007
dunnbiker
  • 8546 Answers
SOURCE: Platter/motor won't turn
I don't know the answer, but you have written one of the finest, most comprehensive problem descriptions I have come across. In mechanical scenarios, that is priceless. I'm sure a turntable guru will see it and go, "aw. I know what that is". Good Luck.
Posted on Feb 15, 2010
  • 256 Answers
SOURCE: the drive belt on my Aiwa px-e860 turntable has
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Posted on Aug 18, 2010
Reconnect the belt on an AIWA PX-E860 turntable
To replace a turntable drive belt.
Before starting any work on your turntable disconnect it from the mains power supply. Remove the stylus or complete headshell to prevent any accidental stylus damage.
1. Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes either side of the centre spindle and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter and motor pulleys with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure it is sitting flat without any twists.
5. Flip platter over to the right way up. A correct fitting belt will stay put and an over sized belt will fall off.
6. You will see 1 or 2 large rectangle or square shaped cut outs in the platter near to the outer edge. Through one pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
You have now successfully completed the process.
MUSIC IS LIFE, LIVE IT LOUD.
Copyright.. Styluscity, John Harrison.
Dec 16, 2014 | Aiwa PX-E860 Turntable
I would like to have a diagram to show how to fit the belt for Aiwa turntable PX-E860K
Good day. I assume that you have lifted the platter off the table. On the inside of the platter you will notice a second ring, or rim. the belt should be put on the outside of the second rim while the platter is still in your hands. Next, slide back the platter and look for the spindle running the platter through one of the big holes in the platter. Slip the belt onto the spindle and turn with your hand to make sure it runs freely. Hope this helpsmicmor100.jpg
Feb 13, 2011 | Aiwa PX-E860 Turntable
Turntable will not spin
Sound to me like the belt has snapped on your turntable. To replace, lift the platter oof the table and check the inside of the platter. You will notice a second ring, or rim. the belt should be put on the outside of the second rim while the platter is still in your hands. Next, slide back the platter and look for the spindle running the platter through one of the big holes in the platter. Slip the belt onto the spindle and turn with your hand to make sure it runs freely. Hope this helpsmicmor100.jpg
Feb 07, 2011 | Aiwa PX-E860 Turntable
My turntable willnot spin aiwa px-860
Sounds to me like the belt has snapped. To replace, lift the platter off the table. On the inside of the platter you will notice a second ring, or rim. the belt should be put on the outside of the second rim while the platter is still in your hands. Next, slide back the platter and look for the spindle running the platter through one of the big holes in the platter. Slip the belt onto the spindle and turn with your hand to make sure it runs freely. Hope this helpsmicmor100.jpg
Jan 17, 2011 | Aiwa PX-E860 Turntable
On my Aiwa PX-E860 the automatic mechanism is failing - when i thry to manually place the stylus the platter does not turn - is there a way to by pass the automatic part and just have it manual?
Select the record speed.
Press the 2 down arrows or triangles( placed side by side) - This the same thing you press if you want the styles to lift during play
Place the stylus on the desired spot.
Press the same button again.
The stylus will drop to the desired spot & continue playing
If you have the manual look it up, else download one from this site after becoming a member(its free)
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Nov 30, 2010 | Aiwa PX-E860 Turntable
How do I remove the turntable to replace the belt underneath - I have just purchased the turntable and the belt is loose.
Oct 10, 2010 | Aiwa PX-E860 Turntable
AIWA PE860U got the platter of and the belt was
if it's falling off regularly, you will need to replace it soon.
Apr 18, 2010 | Aiwa PX-E860 Turntable
The drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on
Dec 14, 2009 | Aiwa PX-E860 Turntable
What size belt do I need?
There are zillions of belts out there. I hope you still have the broken one which will give you the profile of a new belt. Measure the diameter of the sub-platter under the platter. The belt you need well be a slight stretch fit. Then, with the platter back in place, slip the belt over the motor pulley making sure it is not twisted.
Dec 28, 2008 | Aiwa PX-E860 Turntable
118 people viewed this question
 Grubhead
Grubhead
