Question about Samsung RS2530B Side by Side Refrigerator
My samsung rs2530b refrigerator's cubed ice type is flashing and nothing else is working
tborn6
  • 700 Answers
SOURCE: samsung refrigerator RS2534WW ICE MAKER DOES NOT FUNCTION PROPERL
Hello here is how to fix the problem, first you have to remove the ice bin then then press the freeze temp and power cool buttons for about 12 seconds until the display panel switches to the option mode and you hear a beep.
A number under "Frige temp" corresponds to the option number. Press the fridge temp. button to increase the number and the power cool button to increase the number and the power cool button to decrease the number. set the option number to 3
now you have to select the input data to control the water supply time. Press the freeze temp button to increase the value. Press the power freeze bottom to decrease the value. Choose the right amount of water supplied to the ice tray which should be to where the water level is even with the rib on the inside of the tray.
input data = 00, 5 secs/01, 4 secs/02, 3 secs/ 03, 6 secs/ 04,7 secs/05,8secs
Let em know if this helps or not.
Posted on Dec 21, 2008
  • 219 Answers
SOURCE: My Samsung RS267LBBP has stopped making cubed ice. It only crushe
try emptying your ice tray out cleaning it real good then try it if doesnt work still may need board or auger motor
Posted on Mar 19, 2009
  • 212 Answers
SOURCE: Samsung RS26 frozen water line in Ice maker
all you can really do is put heat to it (hair dryer) but be careful that you don't melt the water tube. or you can remove food and leave door open til it melts
Posted on Jun 24, 2009
Sea Breeze
  • 4654 Answers
SOURCE: I have the samsung rs2577sl. the ice maker cube
Your model has the twist tray style icemaker. The part number for you front section that contains the motor assembly is DA97-00258E Ice Maker Assembly. You can try by taking it out and seeing if the tray will return to the home position but stopping there make me question if the thermal fuse in wiring harness may have blown. We may need to test that wire also to see if the thermal fuse is still good, I will leave you some of the links and ready to help when you need me, Thanks, Sea Breeze
Posted on Apr 21, 2010
SOURCE: My Samsung refrigerator ice maker
I have the same problem. I just called custormer support and they are shipping me a new ice bucket to resolve the issue (I'm still under warranty). Based on the agent's quick response, it seems that this is not an uncommon problem.
Posted on Nov 12, 2010
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Samsung Rs2530B frig had power outage, now cubed ice is blinking and water and ice dispensers are not working.
CONTROL BOARD ON REAR PANEL IS MOST LIKELY THE PROBLEM .THIS IS COMMON WITH STORM DAMAGE..
Apr 26, 2017 | Samsung Washing Machines
Samsung RFG298AARS is cylcing between crushed and cubed ice several times a minute and chimes each time it does that!
\it could be that the switch for the ice selection is stuck or just went bad and shorted out. You can check with appliancepros.com to get price of switch and trouble shoot the problem
Apr 07, 2014 | Samsung RFG298HDRS 29 cu. ft. French Door...
Samsung rs2530b refrigerator making loud noise...why?
It might have dust in it. It can drain the fan speed, which makes odd sounds. It could be something else jammed in there too. Clean the fan and see if that works.
May 28, 2012 | Samsung RS2530B Side by Side Refrigerator
The freezer fan makes a very loud noise
it probably has ice build up around i. Try manually defrosting it. Unpluggit and let it thaw out.
Apr 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
Crushed ice option don't work properly . samsung RS2530B
if it new call sears for service...with crushed ice the augar moter turn the other direction... it must not be turn the other way could be a switch in the control...
let me know for it help if NOT please let me know and I will be glad to do more in depth.
Sep 26, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Mar 18, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Refrigerator stopped working
ok whats the light that you see? i need to know what the bars are and or your email and i can email you the list for the codes.
Feb 22, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Ice type won't change
If this is a mechanical unit, look for a bent or broken part. Electrical...this will likely also be a bent or broken part. Unplug before servicing this unit.
Nov 17, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2530B Side by Side Refrigerator Logo
21 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
