Hotpoint aqcf852bi it wont switch on not a flicker of life fine one min not the next
    Problem Solver:
  • 5 Answers
Start simple, check the plug,, especialy if the machines been moved and theres a possibility the plug has been pulled
Posted on Jul 17, 2013
My Audisonic T-22B has gone dead, wont switch on cant reset- what do I do?
With the flickering you stated I would bet that your video card or inverter has gone out or going out.
Aug 15, 2014 | Tablets & eReaders
My wt640 hotpoint washing machine wont spin and says f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also check the drain pipe 2 so that it can drain out. if you have checked for blockages and can not find any reset machine by switching off at plug for 5 mins then back on and try again hope this helps.
Sep 28, 2010 | Hotpoint WF645 Front Load Washer
I have a tumble dryer.
Sounds as if the door switch is the problem. This is normally a safety switch that stops the dryer when the door is opened.
Unplug the dryer.
Remove the door switch and check the switch condition with a continuity meter after removing the wires. Try turning the switch on and off....the meter should read power on and off when you do that.
You may have to remove the front of the dryer to get to the door switch.
Good luck,
I hope this helps
Oct 05, 2009 | Hotpoint Dryers
My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Aug 23, 2009 | Televison & Video
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
My hotpoint ctd 40 wont heat up
Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jan 27, 2009 | Hotpoint Dryers
Runs for a few minutes then switches off
there is a relay just inside the control panel at the front ,
it allows the mchine to rotate in both directions
by replacing this it should cure the problem
Jan 23, 2009 | Hotpoint TDC32 Electric Dryer
My Hotpoint Aqaurius WD62 door is shuting but the door lock light wont come on!
you may need a switch but not a door see if you can adjust the door and try shutting it hard as front loaders close snug because of the rubber boot check your power too
Mar 02, 2008 | Hotpoint Aquarius WD63 Front Load...
White horizontal flicker on screen
Sounds like the logic boards on its way out
Feb 01, 2008 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
