Question about Coleman Air Tools & Compressors
Motor Wont Work on Air Compressor
Just Moved and Compressor won't work.
  • Coleman Master
  • 17,155 Answers
What do you mean that it wont work?
Posted on Jul 21, 2013
5 Suggested Answers
deme-tri
  • 90 Answers
SOURCE: i got a 2 gallon tank and maybe 1/4 hp eletric
the company that did the re-wiring of the motor,
need to give u the details of the type of capacitor,
to purchase.
Posted on Nov 30, 2009
  • 103 Answers
SOURCE: craftsman air compressor won't turn on. Worked
Motor start capacitor probably bad.
Posted on Aug 08, 2012
  • 885 Answers
SOURCE: husky air compressor motor hums won't start
In a safe manor, when the motor is humming, give one of the pulleys a push to help get the motor started. If the motor runs OK with the help push, the start capacitor is bad. If not the next thing to check is the tank check valve.
Posted on Nov 26, 2012
Testimonial: "Pushing the pulley did no good as it turned out to be the run capacitor that was bad . Replaced both the run and start capacitor and back to normal! Great advice- Thanks!"
  • 3 Answers
SOURCE: JobSmart air compressor won't start.
check cap
Posted on Feb 21, 2013
A/c & heat control not working
temp control door is stock door motor is bad or control switch is bad ck door motor for movement its hard to see some time you must pull dash to change motors
Jul 29, 2012 | Jeep Cars & Trucks
Compressor motor runs but does not make compessed air
Some of the things for you to check are for any leaks anywhere, the valve plate assembly, the piston and cylinder assembly and the con-rod. If you have any leaks that let air out as fast as the piston is trying to pump it in you won't get any compressed air. Check the drain valve on the bottom of the tank and the air line from the pump to the tank. If any of the reeds on the valve plate assembly are bent or broken they won't seal the way they need to in order to compress air. If the cylinder is badly scored or the piston rings are scored or broken the piston won't pump compressed air into the tank. If the con-rod is broke the piston won't work at all.
Jul 25, 2012 | Makita Mac5200 138a 3 Hp 5 Gal Wheeled Air...
Ac won't get cold anymore power to compressor but won't click on clutch won't engage possible problems are compressor or evaporator what do you think?
Has the Freon been checked with a gauge to see if there is enough Freon to allow the system to work. Low or no Freon will not allow the compressor to engage. The low pressure switch is most likely activated due to low freon, and will cause this condition.
Aug 19, 2011 | 2001 Jeep Grand Cherokee
I have a 03 honda civicand the air conditioner wont work? it doesnt need recharged and the light comes on when i push the button but i get no cold air? any ideas?
I have the same problem right now, and from what I can figure, it looks like an intermittent thermal protector switch on top of the AC compressor. My 2003 Civic air conditioning works fine for 20 minutes or so and then stops working. If this switch is faulty, the compressor clutch won't engage and you won`t get cold air. I will get it replaced soon, but it seems like the access is not easy.
Jun 16, 2011 | 2003 Honda Civic
Air conditioner won't work added freon changed low pressure switch compressor comes on when jumped across at low pressure switch just no cold air
The low pressure switch turns on appox 26 psi. If the pressure is lower than that, it wont work, you have a leak.
Jun 03, 2011 | 2001 Chevrolet Silverado 1500
The vacuum keeps falling over and won't stand upright. The vacuum won't **** from the bottom, only from the hose in the handle.
No Vacuum will work for more than a few weeks
if you don't own an air compressor & blow them out
after every 2 or 3 uses
May 29, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
IR 2475E Wont start up 220 everywhere No LOP switch
did you check for a motor reset button on the motor??
Feb 20, 2010 | Ingersoll Rand - Rand Type - 30...
Air Tools & Compressors Logo
59 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
