the P6R8MD/OR0502 is a PTC device .. thats a "Positive Temperature Coeficient Resistor" .. that is, it has a low resistance when cold and a high resistance when hot .. it is used to get the compresser started in the right direction ... it costs about $18 so it would be a good idea to test it before purchasing another .. if you know anyone with an ohm meter then they can test it .. it should read low resistance when at room temperature .. .. if it reads open then its bad .. even without that part i think the compresser will hum for awhile but just wont start .. other things (lights, displays) should work ok even if the part is bad .. check to make sure you dont have a blown circuit breaker in your main power panel .. just plug in a lamp to the same outlet the frig uses to check that .. if the lamp doesnt light then go to your fuse box and look for a circuit breaker out of position .. make sure the power outlet and its wiring were not damaged by the water
if you find that you really do need that part then it is available here
http://www.repairclinic.com/Appliance-Parts?s=t-p6r8md-%3d%3d
