Question about Craftsman Garden
Stalls when put in gear
Stall when put in gear and when I engage the mower to mow.
  • Craftsman Master
  • 2,239 Answers
Replace the seat micro switch. Also make sure the block connector is fully pushed home on the micro switch.
Posted on Jul 17, 2013
  • 257 Answers
SOURCE: Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Posted on Aug 15, 2009
Dustybobcat
  • 39 Answers
SOURCE: why does my riding mower stall when i put it in
it sounds like your low ideal need ajusting up. it is positiond on the side of the carby. you are looking for some thing that resembals a screw hed. you should be abel to ajust it with a short phileps hed scrow driver.
Posted on Mar 13, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Just had a Poulan 12.5 hp 38 in. mower delivered
Bob.... I know you don't want to hear this but I would straight up return it. There is no way you should have to troubleshoot something that expensive. You could have a broken governor spring. BUT this should be a HOME DEPOT problem and not yours.
There are a couple of simple things... like checking that the fuel selector is all the way on and that the fuel filter is not clogged with old gas. One mor ething is make sure it is fully serviced with oil... the LOW Oil level sensor could be shutting off the engine BUT from your symptom description that does not sound like the problem.
Other than that I am dead serious.. Talk to the Home Depot Manager and return it / Exchange it. OR work out a deal where HOME DEPOT arranges for on site warranty repair within 10 days.
Kelly
Posted on Apr 14, 2010
  • 4 Answers
SOURCE: stalls when put in gear or engage mower
had same problem is safety switch by the deck causing your problem jump it or replace it
Posted on Jul 25, 2010
aquaman987
  • 927 Answers
SOURCE: I have the Craftsman 20.5
I agree it is the seat switch. This switch will let you start the mower as long as it is in neutral, the brake is set and the mower blades are not engaged. I think it is just two wires, maybe you can jump them together and see if it runs.
Gary
Posted on Aug 06, 2011
Was mowing leaves and mower stalled. It started right back up but now I can't put it into any gears or engage blades without it stalling
check to see if there is anything that may be stopping the safety switches from working properly. if it is all clean check to see if there is a bad safety switch.
Nov 11, 2016 | Garden
Why does mower stall when engaging the cutter?
i had to replace the safety switch on a cub cadet that did what you are saying. when she tried to mow it died. i checked everything . replaced the switch and that was the problem it mows as it should now.. hope this solves your problem
Jan 02, 2016 | Garden
Ride on mower can ride around but whe engage fanbelt for cutter motor stall no power but very thing does turn easy with hand
Sounds like your mower deck safety switch is bad..it is located near the end of the handle that engages the mower deck..try unhooking it and bypassing it with a wire or heavy paper clip...then try mowing if it mows that is your problem..the mower deck will,operate that way but is a safety switch..you need to get it replace,,easy to do yourself..good luck.
Jan 09, 2014 | Briggs & Stratton Garden
Have a John Deere lawn tractor. It starts and runs fine in forward gears, but when put in reverse it stalls . Any ideas what it may be? Could there be a faulty limit switch of some sort?
does it stall when mowing in reverse?
its supposed to do that
look for an over ride switch or button some the key has to be in reverse position to mow
check owers manual
Sep 24, 2013 | Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Poulan mower stalls when I released the brake....also stalls when I try to engage the mowing blades....any suggestions? thanks, Sonya
Hi, there is a switch under the seat that is broken or faulty which is basically telling the engine that no one is on the seat, hence the stalling issue. Fix or replace the switch and you will be mowing in no time. Hope this helps, regards Phil.
Jul 27, 2011 | Garden
Stalls when put in gear or engage mower
your lacking power and probably need to clean your carb or adjust the main idle screw..its on the botton of the float bowl...back it out a half turn...start with a quater..well its running
Jul 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Apr 21, 2009 | Garden
Garden Logo
89 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
