Question about Water Heaters
Fleetwood rv leaking water valve
  • Water Heaters Master
  • 5,089 Answers
Http://waterheatertimer.org/Repair-water-heater-valve.html
Water valve?
Which valve... drain valve, TP valve, shut off valve?
Posted on Jul 16, 2013
Superflue. Why doesn't it stay lit?
If this is in a RV there is a propane monitoring valve. It will close and cut of the propane if it is not being used for a period of time or if there is a leak. The valve is mounted between the propane tank and the first appliance, usually inside the RV.
Mar 09, 2016 | Water Water Heaters
1999 fleetwood prowler 25 5b
You need to visit a local dealer...any RV dealer. They should provide a general walk through as a courtesy. Pay them for a maintenance inspection and they can provide a detailed explanation of their work. After that you might be able to troubleshoot/repair simple problems yourself.
Feb 15, 2014 | Water Heaters
How do I feel the water heater in 1996 fleetwood angler?
A product manual is probably best guide... model number appears somewhere on water heater... especially since the heater is probably not original
Copy following links for possible resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Gene
h
Sep 15, 2013 | RTO Atwood DSI-RV Water Heater-6 Gallon
Fleetwood rv
Copy following link for possible troubleshoot manuals:
Gene
Jul 26, 2013 | Water Heaters
Fleetwood rv 2009
Copy following link to identify valve:
http://waterheatertimer.org/Repair-water-heater-valve.html
Add a comment and give more specific information, and add what you have tried so far.
Jul 16, 2013 | Water Heaters
I have a 1997 Fleetwood Bounder with an Atwood G6A-8E water heater. My pressure relief valve was leaking heavily, and I think it shorted something out, because now my electric igniter will not light the...
Have you checked your fuses? there should be a removable cover to pull off there will be a fuse in side that powers the self ignite..can you take a pic of the panel and post it or send it to my email?
Nov 30, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Have an Atwood 10 gallon gas/electric water heater. When on electric, water gets only luke warm. Would like to check element, but can't find it. Do I have to remove the water heater from the RV to...
If it is electric, It has an element. I would suggest that before reinstalling the unit, you make accommodations to make the next experience a little easier. Add an access door to the rear of the unit
Aug 24, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
How to check thermstat pop off valve starts
you might want to check the water pressure going into the unit, it should only be no more then 75lbs anything over that will make the top pressure valve blow off
Jun 27, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Mar 31, 2009 | Water Heaters
Water Heaters Logo
51 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
