Question about Health & Beauty
Battery charger repair
Have a "Pride Traveler" mobility scooter,the charger (24BC2000T-1) went dead just a tiny light blinking shows. Could it be fixed??
  • 7 Answers
SOURCE: I own a pride mobility scooter with an issue of stopping
It could be a loose battery connector and the controller heats up when it's trying to pull amperage out of the batteries but can't because of the loose connection Try tightening bolts on batteries but disconnect them first. Also it could be the brake on the motor and if the unit isn't shutting off the lights on the tiller blink in patterns to let you know what problems to check for.
Posted on Mar 10, 2009
my-mobility
  • 9 Answers
SOURCE: have a harsh jerking movement while using
This is a common problem often caused by the potentiometer(pot) in the centre of the Wigwag (Accelerator.) This part takes a lot of “abuse” and the pot causes an intermittent electrical connection resulting in a very jerky ride. Try spraying a contact cleaner spray in the pot but most often the potentiometer will need to be replaced by a technician. Regards Chris…
Posted on Jun 22, 2009
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
  • 177 Answers
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
Posted on May 27, 2010
  • 14 Answers
SOURCE: we have a 11 month old elite traveler scooter. The...
I just fixed this problem in a Go Go Elite that was less than 6 months old. We would plug in the charger and the "charge" light would not turn on, just the "power light" I took out the battery pack (check manual for instructions), removed the cover (8 philips head screws) and checked the voltage on the two batteries. One read 4.5 volts and the other 4.7 volts. They should both read at least 11 volts, ideally 12 volts. Evidently the Pride charger will not work if it detects that the batteries are too low. So I took out one battery at a time and connected a 12 volt auto trickle charger to it for 3 hours on each battery. Checked voltages and it brought them back up to 11.5 volts. I reinstalled the battery pack and then connected the Pride charger and THEN it showed a "Charge" light. I left the pride charger on for 12 hours and it brought it up to full charge.
Advice: Don't let your batteries get too low or the factory charger will not work.
Posted on Jul 05, 2010
Why does green light on charger stay on?
Most pride chargers show up the green light when batteries r charged...when charging u should have a red power led & an orange led ...hope this helps
Jan 07, 2016 | Pride Mobility Products Go-Go Elite...
I HAVE A NEW gO-gO TRAVELER WITH NEW BATTERIES AND IT WONT MOVE
Who installed the new batteries? There could be a loose
connection or a disconnected plug to the controller when
the batteries were swapped out.
Jun 29, 2015 | Pride Mobility Products Go-Go Elite...
How do i remove the battery from my go go elite scooter..?
If it is like my Pride Go Go Traveler Elite scooter, what they don\'t tell you is that you need to give the battery a sharp jerk to make it release and come off the scooter. You can\'t just pull it strong and steady.
Apr 26, 2014 | Pride Mobility Products Go-Go Elite...
Scooter not charging only the green light is on, no red
hi , okay there can be a number of reason for this..why , because the charger can't see the battery voltage , if the charger does not have a fault.
1. the fuse has has blown on the battery case.
2. The Charger in question has develop a fault.
3. the charger socket on the scooter is damaged or the charger pins on the charger are damaged.
4. the battery voltage is too low...
Regards
www.gewizrepairs.co.uk
Nov 18, 2013 | Pride Go-Go Elite Traveler 4 SC44E
Sonic pride scooter won't move led light flashes 3 blinks then 1 blink?
the slot in the pot stem has to be dead centre..
1. Misadjusted throttle.
2. Broken throttle pot or throttle mechanism
Regards
Sep 02, 2012 | Pride Sonic 3 Wheel Portable Scooter
We have a 11 month old elite traveler scooter. The battery will not take a charge. We have had no previous problems. Any suggestions?
May 19, 2010 | Pride Mobility Products Go-Go Elite...
I have an Elite Traveler Plus. The batteries are dead. I plug in the charger and the light indicator is green (saying charge is ok)? but the batteries are still dead. Batteries have been drained for a...
The batteries will not accept a charge, therefore the charger things they are full. When a battery sits for that long then they drain beyond the point of repair.
Dec 09, 2009 | Pride Mobility Products Go-Go Elite...
Health & Beauty Logo
200 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
