Question about Health & Beauty
Freedom scooter 644
Power don't engage after turn throttle
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
Hello,download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 as a PDF File.It is 36 pages of info for you & please if you are doing things yourself.Take a photo step by step with your mobile,then you can see what goes where.Have a nice day & i hope i helped you,Colin.
Posted on Jul 17, 2013
2 Suggested Answers
gewiz
  • 1263 Answers
SOURCE: Pride Gogo scooter breaks don't work when I come to a stop
hi, so would it be right to say you can still push it when you stop ?
The brake simply stops the scooter from moving , it does not slow you down, the motor does that.
Does the brake click when it comes to rest ?, if the scooter has not been used for sometime or kept out in the cold it can start to seize, so spray some WD40 or contact cleaner would be best in the slot around the brake area now remember you just lubricated the brake so don't go near hills or road until you used it and you're sure the brake is working again.
Regards
GeWiz.
Posted on Feb 22, 2013
Why when mobility scooter not moving when engaged but when disengaged moving slightly
The unit is not made for "medical approved" market and does not have a POST (Power On Self Test) to confirm wig-wag (throttle) is in neutral when it first turns on. SOLUTION: Put the scooter up on blocks so the drive wheels are off the ground. With the SPEED KNOB turned fully clockwise, adjust the wig-wag (throttle) so the cart will not run and the brake is engaged when the cart is in neutral. There are usually Allen screws in the wig-wag handle that can be loosened and re-tightened once the wig-wag pot is properly centered for neutral.
Aug 09, 2014 | Electric Strider Maxi 4 Wheel Mobility...
Have a pro rider freedom sometimes it will switch on and drive other times it turns on an bleeps and wont move
hi,okay the bleeps , bleeps and pause or continuous bleeps ?
Has the scooter been serviced recentrly ?
Regards
Rob
www.gewizrepairs.co.uk
Jan 10, 2014 | Electric Mobility Power Electric Scooter...
The tines on a honda f220 always spin and don't change speed when clutch is engaged but speed up when throttle is increased. Adjusted cable with no luck.
I believe that unit utilizes a centrifical clutch. try decreasing the idle speed and see if the tines stop. They should then engage as throttle is increased.
Sep 24, 2012 | Honda 25cc 4-cycle Mini Tiller
George Freed, I don't understand the terminology, like whats a pod and where is is?? Thanks, Jim
I think the following is the post that is in question. I don't see "pod" anywhere in this text. However "pot" is mentioned quite a few times. Do you know what a pot is? Its short for potentiometer, which is kind of variable register when you turn it, it changes its resistance. What controls the speed of the scooter is the toggle throttle lever which are connected to pots. If you have anymore questions please feel free to ask. Be patient i just got my gull bladder removed, it wasn't fun.
You don't want to ever bypass anything on these scooters, doing so will either get someone hurt or silverly damage the scooter. There is a good reason your scooter is shutting down. The controller monitors the amperage flow, if at any time the amperage is to high for to long a period of time the controller will shut down the motor, so as you can see there is no sensor to bypass. Also the controller will send a code 4 failure out to a LED out on tiller head. There should be a lamp blinking on the tiller head when the motor is off line. The service lamp is cyclic, in this case the lamp to flash 4 times pause flash 4 times pause.
iT sounds to me like you have one or more shorted windings on the armature of your drive motor which is apart of the trans-axle assembly. TO BE SURE remove the entire trans-axle module. I have a Rascal 600t all i have to do to remove my trans-axle is to remove to quick pins and my entire trans-axle assembly comes away from the scooter. Take the entire assembly down to your local motor repair shop that can rewind motors. Thay will check out the motor, take it apart and clean all the carbon dust from the brushes that gets all over the interior of the motor, doesn't do the motor bearing any good. Rewinding a motor isn't inexpensive costing $200 and up depending on the size and complexity of the motor. But the scooter trans-axle cost is astoundingly high at $1,500 and up. They say they are sealed unit and that they can not be repaired. In reality trans-axles are quite simple to repair and easily repaired. The only difficult thing are the scooter companies that will not come across with the parts and info we need in order for us to keep our scooters in good repair. So ii'd take the trans-axle down to the motor shop. They don't charge anything to check it out. When they do maintenance you will know its working right. When troubleshooting problem with scooter you eliminate half the machine when you eliminate the trans-axle. Get back to me once you've checked it out
If you want to do a check of the trans-axle your self. You can do this by blocking the drive wheels off the ground. Turn the speed pot to
slow. Just give the motor enough power to just move the tires very slowly. Does it take allot of throttle to move the motor. Could be stiff bearings. Does the motor stall out. Hook an amp meter in series to the motor, run the motor real slow. Does the meter needle bounce around allot. If it does that means the winding are not so good. Now floor scooter. Does the trans-axle get hot. There usually a brake assembly at the end of the motor. When you start or stop the motor put your fingers on it you should feel it engage and disengage. Is that brake dragging, does it get hot. This brake assembly gives me lots of grief, drying out it gets stuck. WARNING never use WD40 it eats certain plastics and gets gummy. I use pure silicon oil spray. Hope this helps.
Aug 09, 2012 | Pride Mobility Products Go-Go Elite...
I have a Schwinn S500 electric scooter.When you turn the power switch on the scooter will not run. the power indicator by the throttle jumps from low to medium charge. I charged the battery for the 8 hrs...
Hi Ron, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
Sep 28, 2011 | Transport Schwinn Rechargeable Portable ...
Hi my scooter will drive in reverse on its own at all kinds of speeds if u leave the key on and is slow in forward only it will only stop in reverse if you turn of key or disconnect the forward or reverse...
Hi tandseaster,
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. I know exactly what the problem is. I can almost tell you what kind of scooter you have. In the future give as much info about the scooter as possible.
Your problem is the throttle pot or somtime called the engager.
You can do one of two things. 1. Open the faceplate to your tiller. look for a lock nut on the throttle pot. loosen it, on the bottom of the pot is a slot for a flat tip screwdriver. Take the key out before you start this procedure. You can turn the screw slot on the pot a little at a time, one way then the other. Turn the key back on, turn the speed pot to lowest speed so the scooter won't take off on you. Once you align the throttle pot to neutral tighten the lock nut. The easiest way to fix your problem is:
2. Replace the throttle pot.
Your problem will be fixed.
Good Luck
Tim
May 02, 2011 | Health & Beauty
I need immediate help with a problem with my wife's GO GO Elite Traveller 3-wheel scooter. With a fully charged battery, in about 10 to 20 minutes of operating, there is a clicking noise in the area of...
Check the area at the rear of the motor where the brake is attached after operating for a while if you can feel heat or hot at the brake motor area then the brake is sticking causing excess drag this in turn drains the batteries quicker and can be the cause of the clicking sound you hear. If the battery is not getting hot or the motor then the problem could be in the transaxle. Block the rear wheels off the ground and have the wife engage the throttle if you still hear the clicking noise place your hand on the gearbox /transaxle to see if you can feel a vibration in time with the clicking If you feel a vibration then the transaxle/gearbox will need to be changed If you see that the brake is dragging then the brake will have to be replaced If Medicare paid for the wife's scooter then they will pay for 80% of the repair. You can contact the provider that sold your wife the scooter to see if they do repairs or you can contact Repair xpress @1-877-581-3733 to see if they have a tech in your area Hope this helps you
Apr 21, 2011 | Pride Mobility Products GoGo Ultra X...
Moter engaging wheels not turning
Hi Jimmy. Does your machine display and flashing lights, if it does, count the flashes between the pauses. This is a fault code. If you let us know how many flashes, we can help you.
It might be a stuck motor brush. Undo the caps and see if either brush is stuck. A light file with a fine file might help. Careful tightening the brush caps as they can crack if done up to tight.
Good luck. Neil.
Aug 02, 2010 | Electric Mobility Mobility Electric Power...
Health & Beauty Logo
180 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
