How to get service mode for Sony TV KDL-40Z4500
falter
  • 245 Answers
SOURCE: Sony Bravia KDL-46V4000 tuned to digital mode has
YOU LIVE IN A BAD RECEPTION AREA WHERE DIGITAL IS NOT WORKING WELL......
LOOKS LIKE U HAVE TO SWITCH TO ANALOG.....
UNTIL THIS PROBLEM IS SOLVED IN UR AREA.....
Posted on Nov 20, 2009
SOURCE: service manual SONY KDL-40M4000
http://www.service-guides.net/Television/Sony/MA2_Chassis/index.html
Posted on Apr 30, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
  • 3 Answers
SOURCE: sony kdl-32s3000 tv standby mode
Replace the main board (BU1 Board).
This is a problem in the audio circuit.
The part # is A-1257-244-A.
Posted on May 26, 2011
SD Tech
  • 14553 Answers
SOURCE: Sony Bravia KDL-40V5100 stuck in stand-by mode
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.6_8_2012_3_55_52_pm.jpg6_8_2012_3_56_10_pm.jpg
Posted on Jun 08, 2012
WHAT IS THE KEY CODE FOR TV modelAEG 4812 ST/VT????
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Jul 15, 2015 | Sony Remote Control Originally Supplied...
How do i set convergence of red,green ,blue through service mode
Most common cause for this on the Sony KDL 40EX520 is that the connections to the screen across the top edge of the panel become loose causing blurred picture, mis-aligned colors etc. The Fix requires dis-assembly (Removal of the entire case) and re-seating/resecuring the connection across the top of the LCD Panel.
There is a pretty detailed video of the process (less the disassembly) here: https://www.youtube.com/watch?v=80PfZXFGDvQ
Jan 10, 2015 | Sony KDL40EX520 Bravia KDL-40EX520 40 Inch...
Reset tv sony kdl-37l4000
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 07, 2014 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Sony KDL-32EX340 Calibration and Testing
You are discussing about the service mode setup procedure to this TV, I assumes. Check this to know more. Your TV model's service mode entry and other details are described in detail there.
Jan 07, 2013 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
Sony bravia kdl-46w4100 troubleshooting
This is on protection mode and an error indication. Switch off TV, remove plug after switching off power outlet, wait for 48 hours and retry. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Hi sir.I have a sony Bravia tv KDL-40Z4500.My tv screen is showing Bar of colourful lines from top-to-bottom verticle close to centre of screen and width is 8cm.You can still see tv picture either side of...
Hi Djmojoey,
Your question is probably best answered by Sony...in the meanwhile, I found a manual for you to review the troubleshooting.
https://www.sony.co.uk/electronics/support/res/manuals/4138/41385145M.pdf
In addition, the Sony website page states some features that are discontinued as of March 2017. Support for KDL 40Z4500 Downloads Manuals Tutorials and FAQs Sony UK
I hope this helps at least some.
If you do not have experience discharging the tube, PLEASE BE CAREFUL!!!
Jul 06, 2017 | Televison & Video
Have a sony KDL - 46v5100 volume problem
Tap the "Theater" button on the remote. You should see either "Theater Mode: On" or "Theater Mode: Off". If it is off, tap it again to turn it on and wait for it to go away. Now tap again (should say "Theater Mode: On") and then press and hold it for about a second. This should actually turn it off, as opposed to just pretending to. Works on my larger Sony KDL.
Jan 15, 2010 | Sony KDL 46V5100 46 in. LCD HDTV
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
Electro Med Services...
