Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Coed of
My freezer says the coed of what does this mean and how do i fix it
  • Official Brand Answer
  • 4,342 Answers
Hello Lori - First, make sure the freezer is plugged in and the plug is tightly pushed into electrical outlet. Confirm that the temperature control is not set in the OFF position. Set temperature controls to proper setting or set to the halfway point and adjust it up or down as needed. Also there is a possibility that the timer may be in defrosting mode, therefore it will not run. Allow the defrost cycle to complete and the unit should resume to normal operations. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Best, Chris.
Posted on Jul 17, 2013
Orange light on freeze . running all the time .turn over to storage light goes out. what does storage mean
This is an easy one oops I cannot look in the manual I do not know what brand and model it is!
Try cleaning the condenser coils that should allow it to cycle. To my knowledge storage indicates that, it shuts everything down like the big on and off switch. Try these links:
Refrigerator repair DIY
Freezer Repair Help DIY Fridge and Freezer Repair Penniless Parenting Freezer Repair Guide How To Fix Freezer ACME HOW TO com
May 30, 2016 | Freezers
AEG santo fridge freezer model S7534 - freezer heating up after door left open
Might need to be 'cycled' through a total defrost and re-cool period, how long have you left it?
Might mean you will have to empty it into another unit while it settles down :-(
Apr 23, 2014 | Freezers
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from www.4daewoo.co.uk for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
Freezer not freezing
If you can hear the motor running it could be the thermostat that has gone or if there is no noise at all it could be the motor that has died, a good easy fix ( sometimes works ) is to turn the freezer off leave it for 24 hours with no power then try turning it on again.
ThanksTalkAppliance.co.uk
Apr 22, 2012 | Kenmore Freezer 20.6 cu. ft. Upright...
HOW TO FIX FREEZER SEAL
Check spares at www.TalkAppliance.co.uk the old one should just pull of and new one replace easy.
Apr 15, 2012 | GE 16.7 cu. ft. General Electric Upright...
I am looking for the instruction manual to my lost freezer SWAN SR5030
If you lost the freezer, why do you need the manual?
Swan is a UK company that does not have a website for their freezers. The UK help center phone number for Swan is: SWAN helpline: 0845 610 4118
email: sales@swan-brand.co.uk
Also, isn't a freezer a little large and hard to loose?
Feb 01, 2011 | Freezers
I have a GE chest freezer and the exterior green light has started flashing. The freezer is less than a year old.
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
Jul 07, 2009 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Upright freezer not cooling adequately
Go to there website and see if you can find your model. You can also contact them from there.
http://www.aeg-electrolux.co.uk/node145.asp?CategoryID=2595
Also get yourself a stand alone fridge and freezer thermometer - leave it in for an hour -that will establish what the temperature really is which will help in diagnosing the cause.
Also trying unplugging it for 15 minutes so the display board loses power - then plug it back in - sometimes that will reset it.
May 04, 2009 | AEG 7.59 cu. ft. / 215 liter Upright...
How to unfreeze the deep freeze, and which of the two type is more reliable,.,., tc tnx and god bless
There are numerous methods to defrost freezers, from placing buckets of hot water inside to using hair blowers. I like to unplug freezer, unload freezer, use a plastic putty knife to scrape excess frost off walls if in a bit of a hurry, and to let it just thaw out, using the drain port in the bottom of the freezer, hooked up to the garden hose adapter that came with the freezer to run the water to a drain.
The chest freezers are a bit more reliable than an upright (in my opinion) and are more energy efficient, but do make it harder to find and organize items in the freezer. FYI: Virtually any brand name freezer on the market in the US was built by either Frigidaire in St. Cloud, MN, W.C. Woods Co., from Canada, or Haier Co. in China.
Mar 28, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Temperature control show code CE model GLFU2067FW4
It means there is a wiring error in the door. The only way to fix this error is to get a new door. What a pain! I had the same problem and the freezer was only 1 1/2 years old - thank goodness the manufacturer didn't charge me.
Mar 28, 2009 | Frigidaire Freezers
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
56 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
