Question about Water Heaters
Rheem criterion ii a/c problems
Mry Rheem Criterion II was installed in 2007. I had flooding around the a/c-furnace that developed and spread in 12 hours or less. The air also stopped working. The repairmen said the pan overflowed from blockage of the drain pipe. He cleared it. The a/c then worked for less than 24 hours. He unclogged and cleaned so the a/c worked again , but not 100%. He put a auto overflow shut off switch in. That light was on the next day. No a/c again. A different sensor switch was then placed....after aditional visits for no a/c, he could not restore the a/c at all. He said that the fuse in the outdoor unit burned out and the compressor was destroyed. What can I do??? Do I need to either replace the compressor, or buy a whole new system, to cool the house? Did I get scammed?
  • Water Heaters Master
  • 18,060 Answers
Not a scam but you can get 2 opinions. Moisture removal is a process of closed circuit HVAC. It appears that you have a lot of moisture. IS there a leak in the building structure? Outside air or a swamp cooler can cause this. Sounds like the evaporator coil on the inside unit needs cleaning badly. IT is dropping debris in the pan and causing the flood. The installation of the switches was an attempt to fix the issue by a guessing. I doubt the final diagnosis unless it was a direct result of something the repairman did. He added so many additional switches that it could be his modification that caused the issue.
Posted on Jul 18, 2013
3 Suggested Answers
SOURCE:
SOURCE: I have a Rheem Criterion
Roscoe007 shouldnt speak unless he knows what he is talking about, as a heater installer i am telling you the ignitor needs to be replaced, the very fact that the ignitor does light for about 30 sec than goes out rules out any issue with the themostat, replace the ignitor!
Posted on Dec 28, 2008
mrhotandcold
  • 248 Answers
SOURCE: RHEEM CRITERION II FLAME LIGHT DOES NOT COME ON
1/ overheat stat 2/ fan 3/ diaphrapm valve 4/micro switch when checking fan be sure to check the very small rubberor nylon hose for pinhole best of luck
Posted on Oct 30, 2009
Own rheem criterion. pilot light is on but no hot air
make sure thermostat is calling for heat white & red wire touching to buy pass and verify unit is ok and maybe a bad temp control .
Feb 15, 2015 | Rheem Water Heaters
I have a Rheem Criterion II gas furnace. I have been looking for the filter. Where is It?
If it is @ the furnace, then it is in the blower compartment on the return side.
Dec 07, 2013 | Water Heaters
Rheem 42vp50f
Contact rheem about model differences.
Shop around for cost comparison.
Copy following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://waterheatertimer.org/Which-is-best-gas-water-heater.html
I usually recommend avoiding Rheem, but others disagree.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 12, 2013 | Water Heaters
Drain valve plastic slow leak 81V-80D
If the drip is coming out of drain valve: Put a hose cap over end of drain valve.
If water is seeping out of cracked drain vale, then replace it.
If the leak is seeping around previously sealed threads, then tank may be rusted beyond repair.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
http://waterheatertimer.org/Leaking-water-heater.html
Oct 06, 2012 | RHEEM 30 GAL ELEC TALL Water Heater 6YR SC...
I just pumped out the 7 inches of water in my basement that extinguished my flame on the rheem 21v40 gas water heater. How can I relight the pilot safely?
Manufactures suggest replacing water heater after it has been flooded.
Otherwise replace the burner and pilot assembly.
Contact Rheem:
http://www.rheem.com/Contact.aspx
Buy water heater locally and install yourself
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 11, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
How can I get a manual for my Rheem Gas Furnace
Contact Paloma/Rheem customer (800-432-8373) support and tell them what you have; they'll send you the documentation - by regular/email.
Happy Holidays;]
JZ...
Nov 25, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Oct 29, 2009 | Rheem Paloma PH-20R IFSN / RTG-53PVN...
I have a Rheem Criterion II Gas furnace. It is not igniting.  When I switch the thermostat to "heat" - the furnace doesn't not start.  There are 2 green lights - one is one and the other is blinking.  The...
Dec 13, 2008 | Water Heaters
Water Heaters Logo
94 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
