Question about Minolta EP1031/1031F CS/PRO Copier
Minolta cs pro 1031f error CE 034566
Will not scan. Get a blinking series of numbers Ce 04 45 66
  • Minolta Master
  • 6,680 Answers
Could not find that in the service manual But might be the main board. Will it scan if the document is placed on the big glass instead of the document feeder.
Posted on Jan 30, 2015
  • 3 Answers
SOURCE: paper jams minolta 1080 cspro copier
Can you explain where exactly the paper jams, just check any obstruction in the paper path, or clean all the clutches/ sensors for registration and transport
Posted on Jun 16, 2008
PORRATEC
  • 25 Answers
SOURCE: MINOLTA EP5000 CS/PRO
Code COb31 means that the sorter didn't reset after a job. If you try doing a reset by opening the sorter as if there was a paper jam and it doesn't reset, it means that you have a problem with the sensors by the motor that turns the bins to open and clause as the paper passes. Give it a good blow with air. GOOD LUCK.
Posted on Nov 06, 2008
claudiomn
  • 10 Answers
SOURCE: my Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
Posted on Jan 17, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: i have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Posted on Oct 17, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: my copier minolta cs/pro ep 2010 does not
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
Posted on Mar 20, 2010
The display is flashing c 50 and not working. how do I fix this. Minolta cspro 1031f
maybe the board connected to fusing unit is broken just replace it that board called board f
Nov 19, 2010 | Minolta EP1031/1031F CS/PRO Copier
Pm reset n pm settings
Please describe your problem.PM reset not exist to Minolta CS pro 1030.
Aug 13, 2010 | Minolta EP1031/1031F CS/PRO Copier
Minolta Copier - 1031F - How do you clean the drum and the brushes
Are you asking how to clean the drum and cleaning blade? If so, it is not worth the time if you don't replace both of them at the same time. There is one screw that hold the unit in. Then it slides out.. This Model was designed to replace the 2152 series.. It is a very Bad design.... Good Luck
Apr 05, 2010 | Minolta EP1031/1031F CS/PRO Copier
At startup the Minolta 1031F as a flashing C 50 on the screen
Verify the continuity of the fuser heater lamp.90% the lamp is open.You need change the fuser lamp and the fuser roller(the heater lamp is in the roller and is not detachable).
Nov 03, 2009 | Minolta EP1031/1031F CS/PRO Copier
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
Minolta CF900 error code C0030
The C0030 is referenced to the developer drive motor for the 4 developer units.
you may need to replace parts.
BUT check the oporation of the unit FIRST. LOOK BINDING IN THE DRIVE UNIT
HOPE THAT HELP
Feb 15, 2008 | Minolta EP1031/1031F CS/PRO Copier
35 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
