Question about Dishwashers
Seimens IQ 100 SN25M231GB/01 dishwasher fault
Control panel showing flashing water tap and low rinse aid. Will not reset, have switched power off and on, checked water supply, filled rinse aid. No error code showing. Clicking noise from bottom front rhs. Any clues?
  • 59 Answers
SOURCE: Hotpoint Dishwasher DWF 30
Just one question is the water to the unit turned on ? some times a unit will have a fail safe protection device where it would not start the system if there was no water pressure to prevent damage to the unit, but given the symptoms i really don't think thats it.
It sounds like there may be an internal fuse in the dishwasher circuitry that has blown and needs to be replaced.
Unfortunately without the circuuit diagrams its impossible to say if that is so. the manufacturers today don't supply circuit diagrams with the appliance and they tend to send a repair agent out who changes the whole board rather than just fixing the one problem.
If your adventurous you can try starting to apply power to various parts of the unit to see if they work - i.e. i am sure the pump works if you can get the appropriate power supply to it - but your risking some serious electric shock and issues with blowing things up.
Posted on Aug 14, 2008
VOTIT
  • 2071 Answers
SOURCE: Subject is Bosch dishwasher SHU6800.
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Posted on Aug 17, 2008
  • 409 Answers
SOURCE: Error flashing and won't reset.
hi there,
PF stands for power failure. the first you should do is check your house breaker and make sure that you did not trip the fuse.
Does anything run? Can you hear the motor running? If not, you have no power coming into the machine. In this case it's the main control board that needs to be replaced.
If the motor hums, it means you have power to the d/w, in that case you need to replace the touchpad.
thanks
Posted on Oct 02, 2008
codfish124
  • 36 Answers
SOURCE: Dishwashing detergent in rinse aid compartment
not good there is no way to drain it out. you might be able to take the door apart and take off the rinse aid reservoir and clean it out
Posted on Dec 20, 2008
SOURCE: put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Posted on Apr 30, 2009
We have a Siemens dishwasherSN66T091GB. The unit is not showing a fault code but the 'tap' light and 'rinse aid' lights are flashing continuously.
Tap symbol indicates a water problem.
Check that the water supply to the dishwasher has been turned on.
Check that the water supply hose hasn't bent or kinked.
Check the water supply first, see what you find.
Rinse Aid symbol light indicates low on rinse additive.
Hope this helps?
Oct 16, 2016 | Siemens Dishwashers
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
What does fault code ef52 on Miele km5733 mean
Heater pressure switch has reset during heating The program continues from the wash block in which the fault is registered without the heating being activated. The fault will only be indicated when the fault code memory is checked in the service mode.
Cause:
Excess quantity of detergent or rinse aid dispensed. Excess foam has developed.
Remedy:
Check the dispensed quantities of detergent and rinse aid. Follow the information given in the operating instructions.
Note:
A check should also be made to ensure that the type of detergent used matches the setting. When, for example, combination products (2-in-1 or 3-in-1 tablets) are used but the corresponding parameter has been set to Normal, rinse aid will be dispensed twice.
Cause:
Heater pressure switch defective.
Remedy:
Replace the heater pressure switch.
Cause:
Pump pressure too low.
Remedy:
Clean the circulation pump and remove any foreign objects that may be present.
Cause:
An item has tipped over and a large quantity of water is retained, e.g., in a bowl, and is then not available for the wash water circuit. This reduces the pump pressure.
Remedy:
Follow the loading information given in the operating instructions.
Oct 09, 2014 | Dishwashers
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 24, 2013 | Dishwashers
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
Does not dry dishes..still wet and spotty after cycle ..already have replaced control panel..now it reads HE
The reason it would not be drying is because either the rinse aid is low or the heater element is faulty. Not sure why you replaced control panel.
HE means the heater circuit is tripping. if you are using hot water direct from the tap then the water temperature could be too hot. If using cold water then the heater element could be faulty.
You can try some diagnostics if you are confident to do so. The details are in the service manual
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Jan 20, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Hi had trouble with water tap feeding dishwasher , was leaking
it trips the safety switch because the machine is unsafe
call an electrician to do an insulation check , wiring and component check
Nov 18, 2017 | Siemens 24 in. SE25A091 Hi-Line...
hi there,
thanks
Oct 02, 2008 | Frigidaire 24 in. PLD3465REC Stainless...
PLD4555RFC: Low Rinse Agent Light Will Not Go Out
I've disconnected the sensor in the dispenser for my new Frigidaire dishwasher. The setup is too unreliable in my opinion and is a potential source of headaches. I had the same problem. I studied the design and it's too easy for the floating magnet sensor in the rinse aid reservoir to stick thereby not actuating what is called a reed switch to toggle the control card LO ckt light. Mine has the electronic control front panel.
Jan 07, 2008 | Frigidaire PLD4555RFC Dishwasher
Dishwashers Logo
Top Dishwashers Experts
