Question about Exercise & Fitness
Burning smell after 40 minutes on treadmill also makes clicking noise when going slow
Avanti T100
  • 22 Answers
SOURCE: burning rubber smell and the dryer will not turn on
sounds like you need a new belt for your dryer, the smell of burning rubber is the belt slipping, thats my guess
Posted on Feb 09, 2009
  • 53 Answers
SOURCE: the television takes 35 minutes to turn on
It a common issue mainly with the R71 models. Faulty power supply, can be caused by some blown caps on the chopper supplying the mains board voltage rail.
what is your tv? please rate me:D
Posted on Mar 19, 2009
mcgyver468
  • 710 Answers
SOURCE: my van makes clicking noise when going uphill & and sometimes the speeds slows right down and makes noise (clicking under vehicle).
Could be front CV axles making that noise. Check out the rubber cv boots going from the transmission to the center of the front wheels, If the boots are ripped or cracked, replace the cv axles on both sides.
Posted on Apr 23, 2009
pilot210
  • 39 Answers
SOURCE: on one minute then POP loud noise, burning smell
Loud popping and loss of power is common on plasma TVs and is usually either the Y sustain or Z sustain boards or buffers; in these instances the damaged part will be quite evident.
If this is an LCD you might have degraded insulation on one of the pink/blue backlight power leads causing high voltage to 'arc' to the chassis.
The loud bang and smell is actually to your advantage as in these circumstances the damaged part is usually evident. It'll just be a matter of popping the back off and sleuthing around. :)
Posted on May 19, 2009
jmsill74
  • 27 Answers
SOURCE: Burning rubber smell from Subaru Legacy
Please have your exaust pipes checked, perhaps a mount is burning. The catalytic converter can make a nasty odor when it is clogged. Check the wear on the serpintine belt.
Posted on Sep 18, 2009
I purchased an Avanti AT380 6 plus years ago. The bearings in the motor appear to be faulty and making a loud noise. The model is AT3800707090041 and bought at Workout world in Cannington. Has this got a...
The AT480 model has a 2 year warranty on the motor and 2 year warranty on everything else. It probably has the same warranty that you have on your AT380 machine. It can be fixed at your expense.
Jun 09, 2014 | Avanti Fitness AT480 Treadmill
I have Merit 710T that has recently begun to smell. I have lubricated the belt and had some problems readjusting the tightness and alignment but now that its aligned the treadmill gives me about 30 minutes...
see the video attached, lube TOO the rollers bearing front +back.
see the video how to adjust the deck belt.God bless you
However if finally the problem persist, test the input voltage motor see my personal TIPS, if there are Voltage at the terminals, the motor is faulty. Measure the output Voltage from the control board
for to input to the Motor, if there are NOT voltage from output the control BOARD is faulty, replace.
Oct 07, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
Weslo Cadence G-40 during operation there was a loud pop and an electrical smell, as if something blew or burned. Since that time I've been using it and notice a minor slowing and recovering of the belt...
You must test the motor, and tight the electrical connection very well. and see if there some burn wires, or connector.in any board of the elliptical. See my personal TIPS.
And test the electrical wall, and see if the voltage is o.k .
However keep you eyes open, for any inconveniences. Suspect of the motor winding.
God bless you
Sep 28, 2013 | Weslo Cadence G40 Treadmill
I have a precor 9.2s I use it every day for about 40 minutes but lately smell like something is burning but it does not stopped dont know what is
1) LUBE the deck belt, this happen because the lack of maintenance schedule. maybe your have a WORN deck belt.,time to replace
2) LUBE the rollers bearing very well too
3) test the motor for maintenance repair.
see the block diagram, and see my personal TIPS.
God bless you
Oct 17, 2012 | Precor 905e 9.2 9.20 9.20s 9.1 9.2s Motor...
I didn't receive my instructional or users manuel for my Avanti AT380 Treadmill
GO THIS WEBSITE AND DOWNLOAD SIMILAR MODEL FROM AVANTI USER GUIDE:
http://www.manualsnguides.com/results.php#.TtV56Xpc71s
SINCERELY
Nov 29, 2011 | Avanti Fitness AT380 Treadmill
Avanti AT 480 treasdmill error code - over current
Lubricate your deck, run it at full speed for 10 minutes.. easy fix.
Oct 02, 2010 | Avanti Fitness AT480 Treadmill
My Cadence 825 is running on walking speed only when I'm on it but speed up when I'm not stepping the belt. It also makes burring sound when switched on and I can smell burning too.This is a 13 year old...
You actually used the opposite treatment that was needed when you used the lubricant spray. You want the belt to not slip but instead grab to the belt driver. Now, the lube should be removed and instead the powder that causes the belt to grab hold should be applied. You may want to call any treadmill store and ask them what they charge to do a maintenance on a treadmill like yours.
Oct 01, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Exercise & Fitness Logo
20 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
