Question about Denso 475-0101 Expansion Valve
What is the location of the expansion valve on 2003 bmw x5 3.0 manufactured December, 2002
Manufactured December 2002? Is it difficult to replace? Product below could be wrong.
How to replace expansion valve in BMW 525i
I think these don't use a traditional expansion valve, but rather an "orifice tube", located in the high pressure line junction near firewall going to evap unit.
Jun 12, 2015 | BMW 525i Cars & Trucks
Where is the purge valve located on a 2007, E60, BMW, I looked on youtube but they only had other models
If you are talking about the purge valve for radiator, look on the expansion tank.
Nov 28, 2014 | 2007 BMW 530i Touring
Where is the expansion valve for ac unit on a Saturn 2003 l series
expansion valves (TX valves-thermal expansion valve)are locate at the inlet tube at the top of the evaporator unit inside the car. The line from the condenser goes in one side and the evaporator coils on the other.. Not a DYI job.
Aug 10, 2014 | Cars & Trucks
How do you Replace the AC expansion valve
If you can't find the answer in a Chiltons or Motors car manual-Contact the dealer service shop
Aug 02, 2014 | 2003 Saturn L-Series
Orifice tube location on a 2002 chrysler 300m
2002 Chrysler 300 has an expansion valve instead of an orifice tube which is used to meter the flow of refridgerant. It is located on the firewall attached to the AC manifold hose assembly 4e13a00d-e237-447d-9c7e-ef4684c71d0b.jpg 452a74e8-1d11-479f-9e19-3d118dc43633.jpg
#10 is expansion valve and #3 is the hose assembly..follow AC hoses from compressor to the firewall and it will take you to the expansion valve
Jul 13, 2014 | Cars & Trucks
Where to locate the ac expansion valve for 2003 acura 3.2 tl
  1. Remove the filter lid (A), then pull out the dust and pollen filters (B).
  2. Pull out the evaporator temperature sensor (C) from the evaporator fins.
  3. Remove the screws, carefully separate the upper housing (D) from the lower housing (E), then remove the evaporator core (F).
  4. If necessary, remove the expansion valve (G). Use a second wrench to hold the other fitting on the valve so the evaporator line won't twist. Leave the first fitting loosely connected so you can use it to hold the valve while you loosen the second fitting.
  5. Reassemble the evaporator in the reverse order of disassembly, and note these items:
    • Replace all O-rings, with new ones at each fitting and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for HFC-134a (R-134a) to avoid leakage.
    • Immediately after using the oil, reinstall the cap on the container, and seal it to avoid moisture absorption.
    • Install the capillary tube (H) directly against the outlet line, and wrap it with electrical tape (I).
    • Reinstall the evaporator temperature sensor in its original location.
    • Make sure no air is leaking from the upper housing and the lower housing fitting.
Apr 25, 2014 | 2003 Acura 3.2TL
Were is the expantion of A/C located in chavy cavalier 2003
there won't be an expansion valve their will be an orphis located in the discharge tube
Aug 29, 2012 | 2002 Chevrolet Cavalier Coupe
How to replace my ac expansion valve on my bmw e39 540i?
YOU NEED TO HAVE AC SYSTEM DISCHARGED AT DEALERSHIP.REMOVE MOST OF THE DASH TO REMOVE THE EVAPORATOR HOUSING TO GET TO REMOVE EXPANSION VALVE.BEST TO LET DEALERSHIP FIX.YOU HAVE TO DISMANTLE MOST OF THE DASH TO REMOVE EVAPORATOR HOUSING TO FIX EXPANSION VALVE THIS JOB VERY HARD.
Jul 01, 2011 | BMW 545 Cars & Trucks
2001 x5 3.0 have freezing expasion valve low side pressure is 10 high side is between 25o to 300
there is a filter inline with the expansion valve and it sound like it may be clogged up. it is replacable but it is not a cheap affair to do it. good luck!!
Feb 13, 2011 | 2003 BMW 5 Series
How do you get to front expansion valve on 2003 honda odyssey, and where is ther rear valve located?
the front expansion valve is located with the evaporator ,
a big job. the rear is the same , just easier.
Aug 13, 2010 | Honda Odyssey Cars & Trucks
Denso 475-0101 Expansion Valve Logo
Top Denso Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Denso Heating and Cooling Expert? Answer questions, earn points and help others
