Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Top 1/3 of screen has a dark band across it as well as the whole screen pulses
The top 1/3 of the screen has a dark band across the top and the whole tv screen pulses. we really noticed the dark band when it was suppose to be blue sky but looked gray. The pulsing is constant as well as the dark band. Has anyone else had this problem? We've had our tv for 15 months. tnx
4 Suggested Answers
  • 43 Answers
SOURCE: Horizontal (dashed) line across screen
On the KDFE55A20 this sounds like a bad Q-Box. I would get an estimate from a Sony authorized servicer as this part may be quite expensive. On the 55A10 model this may be the B-Block and is also quite expensive. Getting an on-sit estimate would be the first step I suggest. Again go with an authorized Sony servicer. Call Sony or go to for customer service. Good Luck
Posted on Jan 06, 2008
  • 13 Answers
SOURCE: SONY xbr screen problem
It sounds like one of your circuit boards may be going out. I'm sorry I don't have a better response than that.
Posted on Mar 27, 2008
  • 1635 Answers
SOURCE: pulsing/strobing on black screens or dark backgrounds
It is very likely that there are electrolytic capacitors going high in ESR on the processor and driver boards, and also in the power supply areas. The tech should be able to see this by monitoring supply distributions with a scope.
Depending on the complexity of changing the caps on the boards (if it is actualy a cap problem), the best choice may be board replacements.
In almost all the cases where I had this type of fault, it was a number of capacitors that had to be replaced.
Jerry G.
Posted on Apr 14, 2008
  • 193 Answers
SOURCE: My 4 1/2 year old Sony KDF-42WE655 TV is on its
Posted on Apr 22, 2010
0 characters
1 Points
Dark band lcd tv
Back-light fault. Contact any service technician. The panel might be taken out for repair. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Flat Panel Televisions
Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
check connections on top of screen this is becoming a stockfault on samsung tvs
Dec 01, 2012 | Flat Panel Televisions
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
Vizio VW46L10 TV has a 6 inch dark band across the top of the picture.
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Flat Panel Televisions
Screen blinked and then there was a dark band across the top of the screen
This sounds like one of the back lights have failed. This could be its power supply, and or the lamp itself.
Not all the screens can be service for back light failure. This is design dependent. Also, if you are going to change a back light and you can, it is best to replace all of them at the same time. If not the coloration of the screen will be different from one part to the other. With age the color of these lamps changes a little.
I would suggest with such an old set, I would get one of the newer LED/LCD sets. They are very far improved over the one that you have. Your set will be expensive to service, if it can be serviced.
Jerry G.
Jul 27, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Vertical Band has appeared on my TH-42PX60B
Before getting a new tv set I would try all cables and contacts, as well as looking in the troubleshooting section in the manual.
hope you succeed
Feb 20, 2012 | Panasonic VIERA Flat Panel Televisions
I have a dark band across top of screen. Sometimes it disappears altogether but always returns.
sounds like a bad capacitor in set. If you are electronically inclined you can try getting schematics online and replace bad 'cap' otherwise you will need to take to a repair shop or replace set.
Mar 04, 2011 | Philips 42FD9932 42 in. Plasma Television
For several months we would get bands of lines across our screen. We thought we were experiencing some kind of outside interference as it would come and go. Two days ago the bands began to cover most of...
You're verical output IC is dead, this might because of a leaky capacitor on that section which causes the lines across the screen.
The processor shuts down the unit automatically to avoid further damage to your tube.
Send it to repair shop to isolate the problem. This is fixable.
Thanks for using fixya.
Jan 18, 2011 | Hitachi Flat Panel Televisions
Dark band at top of whole screen
Pop sound is probably the Lamp or maybe the color wheel. When you unplug and try it on do you hear a whirling or winning sound ? Is it followed by a slight ticking sound ? If you get the whirling and a ticking sound it's probably a bad lamp. If you don't hear the whirling sound you may have a bad color wheel. The parts are both made of glass. The pop you heard was one of them breaking. If you can't tell, order a lamp you will need to change it eventually anyway.
Apr 16, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My 50" Plasma has developed a band across the middle of the TV
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If you don't have the reciept then call 1-800-SAMSUNG.
Jan 24, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
109 people viewed this question
Top Sony Flat Panel Televisions Experts
Brian Sullivan
Brian Sullivan
Paul Bade
Are you a Sony Flat Panel Television Expert? Answer questions, earn points and help others
