Question about Generic VTech Write and Learn Desk
Can a vtech learning desk be reset?
I replaced the batteries. I am going to try leaving them out for a while. is there a way to reset. or to reprogram it??where can I find replacement parts?? I need the the thing that closes down on the paper. and the sheets that go with it also.
How do I get the VTech Learning Lodge Navigator back on my computer without the disc?
You might go to the following (VTech) link, select your specific product from the alphabetical tab for the downloadable manual (also here) and look for 'factory reset' in same manual. Hope this helps!
Electronic Learning Toys ' Best Learning Toys ' VTech America LINK:
http://www.vtechkids.com/support/product_manuals/A
Nov 10, 2014 | Toys
Innotab 2s can't connect to computer via USB.
try another USB cable/usb port. if that doesn't work: For windows--check under device manager>>disk drives>>look for vtech nand1>>right click--uninstall>>unplug the toy>>plug it back in>>turn it on>>try to access Learning Lodge again. For Mac>>open Disk Utility while toy isnot connected to toy.>>plug toy to computer>>turn it on>>look for anything that says vtech.if you do go to Learning Lodge--send error report--call vtech
Mar 29, 2013 | Vtech InnoTab 2S Wi-Fi Learning App Tablet...
How vtech on wireless
1) clean the contact base with pencil eraser and then put a little ethilyc alcohol. and let to charge the phone
2) test the power batteries with a VOM, replace if necessary
3) try again, if work is o.k .
4) test the adapter for to see is working try with another phone for to see if working ,replace it
5) try again and see if working
6) you must shure the outlet wall is o.k reset c. breaker if necessary try putting a desk lamp or another device for to see if working.
Oherwise you must go to the repair shop for repair electronic circuit power supply.
God bless you
Sep 17, 2012 | Vtech Lands Phones
I have a vtech mobiGo touch. I want to reset it. Start fresh. I just learned about the progress log an want to watch him grow an learn. An everyone in the house has played it so i cant tell what he has...
had the same prob with my son. the games are fun the wife and i couldn't help it.
1. take out the batteries then hold the "on" button for 45 sec replace batteries
2. go to your vtech mobigo acct edit your childs name to "family" or something
3. now add the child you wanted to "reset" now switch mobigo from "family" to new child
4. plug mobigo into pc and the progress log should be reset
thats what worked for me hope this helps
Mar 11, 2011 | Vtech Mobigo Learning System
I'd like to know how to reset my daughter's mobigo so that it will be able to trace her accoplishments. Currently her, aunt, mother and myself performed multiple tasks for her, and I want to erase the...
Feb 26, 2011 | Vtech Mobigo Learning System
Replacing the batteries in the vtech ride and learn giraffe bike lost manual
It uses three AA batteries. The battery compartment is on the left side of the head.
You can download the manual from the manufacturer's web site at
http://www.vtechkids.com/_f/_pw/_manual/80-106400%20-%20Ride%20&%20Learn%20Giraffe%20Bike.pdf
Feb 14, 2011 | Vtech Ride and Learn Giraffe Bike
My daughter's mobigo won't turn on even with new batteries
Here are some tips to try:
If your product has a "Reset" button, try using that.
Another tip. Try removing all of the batteries and holding down the "ON" button for about 45 seconds. Then replace the batteries (be sure they are fresh) and try your product again
Jan 21, 2011 | Vtech Mobigo Learning System
How to reset the mobigo?
Take out the batteries then hold the "on" button for 45 sec replace batteries.
Jan 18, 2011 | Vtech Mobigo Learning System
Our vtech globe isn't identifying places correctly
Is this a new problem, has the unit worked in the past? You may need to reset the unit - remove the batteries for a few minutes, then re-insert. You may also try new batteries.
This is a link to the product manual: http://www.vtechkids.com/_f/_pw/_manual/Fly_and_Learn_Globe.pdf
Oct 15, 2010 | Vtech Fly and Learn Globe
Vtech whiz kid learning system has no sound. can use it with the pc, however; takes 15-20 times trying to turn on the unit before the software recognizes it is on. Tried resetting unit...new batteries (3...
My son has a year old Vtech laptop and I can no longer get sound from it. Have replaced batteries but that has not solved the problem. Can anyone help?
Jan 06, 2010 | Vtech Toys
Generic VTech Write and Learn Desk Logo
29 people viewed this question
Top Generic Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Generic Furniture Expert? Answer questions, earn points and help others
