Am I the only one that sits and wonders why these companies like RCA, Samsung, Vizio put in a USB connection yet has nothing to do with the TV or DVD or better yet the Bluray, great place to what hold onto an extra Jump drive? These are worthless and deceiving.Am I the only one that sits and wonders why these companies like RCA, Samsung, Vizio put in a USB connection yet has nothing to do with the TV or DVD or better yet the Bluray, great place to what hold onto an extra Jump drive? These are worthless and deceiving.
You can't post conmments that contain an email address.
The Orei DVD-P901 is a 9-inch portable DVD player that can be used to play DVDs from any region. It has a swivel screen that can be rotated 180 degrees, so you can watch movies in either landscape or portrait mode.
The player also has a built-in rechargeable battery, so you can watch DVDs for up to 4 hours on a single charge.
To use the player, simply insert a DVD into the disc tray and press the play button.
The player will automatically begin playing the DVD. You can use the on-screen menu to navigate through the DVD's content. To adjust the volume, use the +/- buttons on the side of the player. To fast forward or rewind, press the FF or RW button. To pause the DVD, press the pause button.
The Orei DVD-P901 also has a USB port, so you can play video, audio and photo files from a USB flash drive. To do this, insert the USB flash drive into the USB port and press the play button. The player will automatically begin playing the files on the USB drive.
Check the user manual (find one online if you don't have the printed version). It will list the file types that the player can decode and play. If it does not specifically list mp4 or mkv files, you're out of luck. There's no way to add codecs to most DVD players.
As we know, most old DVD players only support DVD video on DVD disc, they cannot play any video file not to mention MP4 file. Later, some DVD players can play video files on DVD disc. Even later, many DVD players come with USB ports, users can attach USB drive to it, and it can search and play video files on it. However, the video formats they support are very limited. Because DVD video is some kind of MPEG-2 video, this format is supported by nearly all DVD players. MP4 is newer than AVI format, some players doesn't support MP4 but support AVI. Hence, to play MP4 on DVD Players, we suggest you convert MP4 file to DVD-Players-sensible formats like the MPEG or AVI format.
You may also try this method to solve can't play MP4 on DVD player from http://www.idealshare.net/video-converter/solution-on-mp4-wont-play-on-dvd-player.html
Most DVD players only accept MPEG-2 in standard VOBs. Some of the older standalone DVD players do not play AVI at all. Now some of the newer DVD players support AVI encoded with DivX. Look into the player manual, it'll tell you what formats are supported. If the DVD player does not support AVI, it will fail to play AVI files even if we have successfully burn AVI to DVD disc.
These are the 2 possible causes and solution on that problem:
The format of the file on U.S.B device is not compatible to the format requirements of the DVD player.For example your DVD player required A.V.I or MPG/M-PEG for the video while the file format of your U.S.B is F.L.V and when you try to insert it to the U.S.B port the file doesn't read.You have to do is convert the file that store on your U.S.B device depends on the format requirement of your DVD.Use a total video converter to convert the file on your U.S.B to the format you need to play on the DVD player.
Or the problem could be the U.S.B itself,because the U.S.B host on this product does not supported all U.S.B device.Please try to use other mass media device such as memory card or mp3 players.
The size of the usb device also matters on these dvd players more often than not. If you are using a larger usb device and you have a smaller one try using it with a couple of files and see if that makes a difference.
