Wiring diagram for soundesign 6608 record pplayer
I need to find an owner's manual for Soundesign Jukebox Alarm Clock model 3160J
You can get all kind of Soundesign Jukebox Alarm Clock manualshere: http://manuals-market.com/search.php?cmarque=PERFORMANCE%20TEKNIQUE&modele=ICBM%20779. After clicking this link you will be forwarded to a page contains aform. You need to fill up that form. Most of them are pre-filled. You need towrite "Soundesign" in Brand box and model number in "model number" box. Please don't forget to mention "Jukebox Alarm Clock" in the"description box". Finally accept their "terms and condition" and click on"search" tab. Hope this will help you. Good Luck.
Aug 20, 2011 | Audio Players & Recorders
I'm having problems with my Soundesign turn table... After finishing a record it auto-returned the stylus, and since then the turntable won't turn. I can't remove the platter, however I can lift it up...
I actually had the same problem with my soundesign. Really sucks that we can't remove the platter. However... I just jiggled mine for a while and it started working again. I know that doesn't sound like a real solution, but I would just try playing with it for a while. Mine worked after that..
Do you by chance have any idea how to get closer to the belt? Mine is having a speed problem and needs adjusting but obviously the platter is a ***** to take off.
Jun 29, 2009 | Audio Players & Recorders
Technics SL-B2 not cooperating with R4450W Soundesign receiver
I would suspect that the receiver has only an AUX input. If that is the case, you will need to purchase a phono pre-amp. These are readily available for about $20 or so. This will boost the low signal level from the table to line level which is what the AUX input is expecting.
Dan
Nov 18, 2008 | Technics Audio Players & Recorders
SERV REPORT FAULT 15.004.45-6608
the drum heaters are not working. They are 2, 150 watt halogen lamps in series in the machine, One or both have blown out.
Jun 27, 2008 | Xerox Phaser 8200 Laser Printer
Record player belt
Scott, the belt wraps around the bottom of the turntable platter, then put the platter back on your turntable, and you'll have to pinch back a section of the belt and wrap around the brass motor spindle. That's pretty much it!
Good luck.
- OPTiC
TWEAK A/V LAB
Apr 13, 2008 | Technics SL-1200MK2 Turntable
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
