Question about Exercise & Fitness
970 Proform Treadmill Console
My 970 Proform Treadmill console will not decrease the speed increments. I can only use the manual setting for my running routine. Help
    Top Expert:
  • 12,223 Answers
Run the software calibration, go under the HOOD cover motor, and see the instruction, for easy diagnostic and fix it. God bless yo
You must clean the speed sensor, and lube the elemation motor.
God bless you970 Proform Treadmill Console - 556dbfc7-31f4-4891-a86f-2dcb99538833.gif
Posted on Jul 17, 2013
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
maxtreadmill
  • 832 Answers
SOURCE: Proform treadmill console displays FF and will not
SOUND LIKE YOU HAVE A UPPER DISPLAY PROBLEM SINCE I DO NOT KNOW THE MODEL# IT SAFE TO SAY THAT THOSE CONSOLE CAN BE RATHER EXPENSIVE.
GO TO iconfitness.com to customer service then replacement part and put the model# in and it will tell status of parts and pricing or call them @1-800-999-3756
Posted on Mar 01, 2010
maxtreadmill
  • 832 Answers
SOURCE: After replacing batteries on Proform PF800 console stays lit
Pull the batteries out let it reset itself while its doing that check all cable to make the connection are seated firmly then reinstall the batteries, unless the function pad is sending a phantom signal engaging the display to be on continuously,or by pure chance the upper electronics went hay wire
Posted on Apr 11, 2010
Testimonial: "Thank you very much for your advice! Very helpful!!"
maxtreadmill
  • 832 Answers
SOURCE: Proform 350s crosstrainer treadmill; surges 3 MPH to 4MPH
Walking Belt is Worn: The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon). Fewer steps indicate high friction. The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem. Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
Posted on May 31, 2010
SOURCE: i have a proform xp 550s treadmill. The belt
change drive belt proform xp 550s treadmill
Posted on Jan 17, 2011
I have a Proform 1026 EXP treadmill that began running at full speed whenever it is turned on. The incline controls function normally but the belt speed is incredibly high. When set to 1.5 MPH (the slowest...
please run the Software calibration see the instruction.
GOD BLESS you
The Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Sep 18, 2013 | Proform 1026 Exp Treadmill Motor Control...
I have a Proform 970 Treadmill and the speed function is not working properly on the console, help
Run the software calibration for easy diagnostic and fix it. Go under the HOOD cover motor, and see the instruction. God bless you
Jul 16, 2013 | Exercise & Fitness
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Proform Sport 1000 - The right hand side of my controls which allow me to change the speed of the treadmill do not work. The left side is still operational and allows me to change the incline and select...
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Aug 09, 2010 | Proform Sport 1000 Folding Treadmill...
I have a proform 785..the problem is the speed and incline decreases all of a sudden like within a minute...i raised the speed to 4 and it dropped to 2 within 1 min and same thing with the incline it...
Unplug unit remove motor shroud then start calibration procedure.
Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
Press either incline key and the incline will calibrate automatically
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
Press the Stop key once and remove the safety key.
Jun 11, 2010 | Proform 785 CS Personal Trainer Treadmill
Proform treadmill doesnt work
Press the Stop and the Speed Up keys down while inserting the safety key and try to get this unit in calibration mode if you cannot then, the upper console will have to be replace.
May 26, 2010 | Proform Perspective Es Treadmill PFTL99806
Hello I am having problems with my ProForm 540 panel board on the treadmill. I cannot put in my speed manual. I can select a program on the left side of the panel. Please help!!:)
Sounds like your function key has failed and needs replacing if this model offers it they may want you to purchase the entire console so go to iconfitnes.com or call them @ 1-800-999-3756
Mar 03, 2010 | Proform Crosswalk 500 Treadmill
Treadmill automatically speeds up upon start up
If you have a unit where the speed can be adjusted with 1 mph increments 0 to 10 and with speed up or down .1 mph increments . it sound like the key pad itself is causing this problem. Depending on manufacturer you can purchase the keypad/overlay and some will want you to purchase the entire display.
Mar 01, 2010 | Proform Exercise & Fitness
The console of my treadmill displays time and speed incorrectly
Hi. if you are talking about the same segment in all the characters of your display being lit, then it is a console problem - it will not be a hard thing to fix but you will need a board level electronic serviceperson to do it for you
Jul 28, 2009 | Proform Exercise & Fitness
Apr 14, 2009 | Proform CrossTrainer Treadmill
Exercise & Fitness Logo
41 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
