Question about Exercise & Fitness
I have a Proform 970 Treadmill and the speed function is not working properly on the console, help
I have a Profom 970 Treadmill and the speed control on the console will not lower the speed in increments. Also, I can only use the manual setting, can't get other functions to work. Help
    Top Expert:
  • 12,223 Answers
Run the software calibration for easy diagnostic and fix it. Go under the HOOD cover motor, and see the instruction. God bless you
Posted on Jul 17, 2013
Testimonial: "Thank you Ernesto for responding so quickly I will try what you have suggested. Many blessings to you also."
SOURCE: I have a proform j8li treadmill, all 4 led lights
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
Posted on Feb 09, 2010
  • 208 Answers
SOURCE: the console of my treadmill displays time and speed incorrectly
Hi. if you are talking about the same segment in all the characters of your display being lit, then it is a console problem - it will not be a hard thing to fix but you will need a board level electronic serviceperson to do it for you
Posted on May 07, 2010
SOURCE: My treadmill Proform Crosswalk 400e stop, speed
we have the same problem, did you solved it?
  • 3 Answers
SOURCE: Proform frontrunner most control function not working.
I had the same problem-only one of my programs would work, and the rest of the buttons (even start) would not work. I used some scissors and carefully cut about a 1/2 inch in the plastic inbetween each of the copper strips in the ribbon cable. Then I seated each one individually (put them back in the white plastic thing) until I found the one that was freezing all of the other buttons up. Now all of my buttons EXCEPT for the one that was working before work. I can live without 1 program if it saves me $300.
Posted on Aug 23, 2010
SOURCE: console buttons don't work,only ifit button works
Has anybody found the solution for this? I'm having the same problem on my 850T treadmill. It's really annoying..
Posted on Jul 04, 2011
970 Proform Treadmill Console
Run the software calibration, go under the HOOD cover motor, and see the instruction, for easy diagnostic and fix it. God bless yo
You must clean the speed sensor, and lube the elemation motor.
Jul 16, 2013 | Exercise & Fitness
Proform Sport 1000 - The right hand side of my controls which allow me to change the speed of the treadmill do not work. The left side is still operational and allows me to change the incline and select...
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Aug 09, 2010 | Proform Sport 1000 Folding Treadmill...
Proform treadmill doesnt work
Press the Stop and the Speed Up keys down while inserting the safety key and try to get this unit in calibration mode if you cannot then, the upper console will have to be replace.
May 26, 2010 | Proform Perspective Es Treadmill PFTL99806
Proform treadmill zt 5 runs but display is dead
If what you say is that all functions are working (start, speed up , down and incline up,down) then the upper console lighting may have loose wire harness( check first) bad soldier connection or the components that generate the images on the LCD are defective. If you have good connections on the wire harness then you may need to replace the upper console.
May 21, 2010 | Proform ZT5 Treadmill
Bought a proform ekg treadmill from a lady on line
Mine did the same thing. I had to take the display apart and clean the contacts on the circuitboard that are underneath the buttons. After I put it back together it has worked perfectly. Mone came from a house where the people smoked and it was the nicotine and tar that was in the smoke that had seeped inside and cause it to stop functioning properly. Well I guess thats why they sold it to me. They likely were not using it anyway. Well I hope this helps
Mar 13, 2010 | Proform 730 Folding Treadmill Model...
Hello I am having problems with my ProForm 540 panel board on the treadmill. I cannot put in my speed manual. I can select a program on the left side of the panel. Please help!!:)
Sounds like your function key has failed and needs replacing if this model offers it they may want you to purchase the entire console so go to iconfitnes.com or call them @ 1-800-999-3756
Mar 03, 2010 | Proform Crosswalk 500 Treadmill
Problems with my pro form 540 treadmill
So after reading the post from EricLaw, I wanted to clarify his solution because it also worked for me. When you open up the console, you will see the membrane (it actually says membrane inside very small) and the connecting wires to the membrane is actually a wide flat plastic with some stripes embedded in the clear plastic which can be easily detached from the membrane (looks like masking tape w/ stripes). These stripes are how the touch pad on the console talk to the membrane. I then took scissors and cut slits between each stripe (cutting only the clear plastic part of the plastic tape) so that I could leave a strip out of the membrane. I played around leaving different strips out until the right strip was left out. If I recall correctly, I left the 5th strip out and the key pad now works entirely EXCEPT the speed 1 and 4 which were the only keys working until I did this. Hope this helps.
Jul 20, 2009 | Proform Crosswalk 500 Treadmill
I turn my treadmill on and it immediately goes full speed
That sounds like a motor control that is shorted out,the only thing you can do is replace the motor control.When replacing the controller follow the instructions to calibrate it to the console.
Jul 06, 2009 | Nordic Track /proform Treadmill...
Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Apr 14, 2009 | Proform CrossTrainer Treadmill
Exercise & Fitness Logo
59 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
