Panasonic pt-51g53w tv will click once and then shut down
  • 1 more comment
  • Alex the Man Oct 15, 2008
    At first my tv (Zenith, P/N IQC50H94W) had a badly messed up picture. The colors were misaligned and they could not be aligned. I began to take it apart to diagnose it, and now when i turn it on, it clicks and shuts off before the picture even comes up. I was told the green tube needs replacing. Could it have shorted out like you said, as I began to smell an electronics burning smell?
  • rlake_se1 Nov 23, 2008
    When I turn the TV on, the power light comes on for a second then shuts off by itself.
  • Anonymous May 13, 2009
    Need A Replacement Screen Complete Broken Someone Help Please.
  • 398 Answers
Usually, in the Panasonic projection sets that start but then shut right back off, one of the convergence IC's has shorted out and is drawing too much current. When the TV is turned on, the computer senses the extra current and shuts the set back off. The set should be serviced by a qualified tech familiar with Pansaonic projection sets.
Posted on Aug 28, 2007
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Where is the air filter on a Panasonic PT-52LCX65 Projection TV
THE AIR FILTERS ARE INSIDE THE ENGINE YOU MUST TAKE APART MANY PIECES LET A REPAIR CENTER DO THIS!!
Apr 25, 2010 | Panasonic PT-52LCX65 44" HDTV
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53TW53; Red shadows appear and then the t.v. shuts down.
The convergence output IC's have failed. Only fix is to replace them. These are large amplifier IC's bolted to heatsinks and have a high failure rate in all projection sets.
Jun 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
TV powers up for literally a second then shuts down (PT-47WX49)
check R517 on the power supply board if burnt replace with 5% 1/4 watt 10K carbon resistor.
Dec 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Jun 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Shutting down....
You have POWER supply board that went out.....apparently this is a common thing for this model.....sorry to see such low activity on this site......hope it helps.....
Apr 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic pt-61lcx65
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt-51g53w
Usually, when a Panasonic projection powers up for a few seconds and then shuts down, it is because one of the convergence IC's is shorted and drawing too much current. This is usually very easy to troubleshoot because the shorted IC causes one of the large reisitors near it to glow red hot just before the set shuts down. The set should be serviced by a qualified tech familiar with Panasonic projection sets.
Sep 02, 2007 | Panasonic PT-51G53 51" Rear Projection...
Televison & Video Logo
975 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
