Question about Ice Cream Makers
Coolata Machine-Model 430 12 operating manual
Do you have to put in mixture first to check in machine is working?
How long do I churn mixture?
Probably 15-20 minutes depends on machine and mixture. Some machines stop churning when the ice cream gets so thick that it stops the beater from turning. If you have this type of machine, when you hear clicks turn it off. If you start with a frozen container vessel, your ice cream will freeze faster. Remember that longer is not necessarily better. The longer it is out, the warmer it gets, and will turn back into slush.
Aug 28, 2016 | Ice Cream Makers
Gets only cool not cold
the thermostat is supposedly right below the BLACK switch knob of the unit.
it should look like this if you open the unit up.
but before you open the casing, try to refer to CuisinArt's warranty terms even if you lost the proof of purchase for the unit.
good luck
Jul 27, 2008 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Put a new motor in the left side, but when you try to run it, it keeps tripping the reset button and turning off. The left side controls the hopper cooler, so I come in and the hopper is warm on both...
Did you check the wiring ? This motor is reversible and you may not have the wires under the connection plate. A model number would be very helpful as I am looking at model # 339 manual.http://www.taylorfreezersales.com/op_man/0336_338_339op0.pdf
Jun 29, 2011 | Taylor Ice Cream Makers
Ice cream maker doesn't chill
The machine must be upright for 24 hours before using it.
If it was stored on its side or upside down you MUST wait 24 hours with the machine in the correct upright position. The 'person' who delivered mine made sure he tumbled it over and over again scanning shipping labels even though it said everywhere fragile and this side up.
If the machine does not work at cooling after 24 hours there is a problem and it should be returned.
Do not expect rock hard ice cream, but thick scoop-able medium firm soft-serve is easy to get as a result. A few hours in the freezer will harden it more.
Nov 08, 2009 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Ice cream maker instructions
I have the booklet for this machine.
1) you can use any IC recipe as long as it does not exceed 1 quart. This is for vanilla:
1/2 c sugar
1 1/4 c half&half
1 1/2 c heavy whipping cream
2 eggs 2 tsp vanilla
with mixer beat eggs and sugar until thincl and cream colored. Addthe cream and vanilla mix well.
the machine:
you want to put the freezer cylinder in a plastic bag (to prevent freezer burn) and then put it in the back of your freezer until completely frozen 6 to 22 hours. You should not be able to hear liquid slosh when you shake it. For making stuff quick they recommend keeping it in the freezer in the bag.
step one: Put maker on flat surface.
two: Put the mixer bowl on the base.
three: Place frozen cylinder into to the mixer bowl (the big one) do this when you are ready to start the IC because the cylinder begins defrosting right away.
four: set the paddle on top of the cylinder, placing the peg on the freezer cylinder inside the peg hole on the paddle
five: Place the cover over the mixer bowl, locking the grooves on the motor base. Plug in, turn on, the bowl and cylinder will begin to turn.
six: Pour the recipe into the feeder hole of the cover then put the lid on.
You will need 20 to 40 minutes or until mixture is frozen. Don't stop the machine until done. If you want hard ice cream spoon the soft serve into an airtight bowl and put it in the freezer till it is like you want it.
Hope this helps, Elizabeth
May 17, 2009 | Ultrex Double Canister 2 Quart Ice Cream...
Deni Ice Cream Maker Manual
I don't have a flatbed scanner to scan it, but here are the operating instructions (at least for the 5201).
1. Place canister in freezer for 8 hours (must be frozen solid-so that you can't hear liquid in canister sloshing around)
2. Prepare your ingredients ahead, and chill them for best results.
3. Take canister out of freezer and place on motor base. Use canister immediately after removing from freezer, as it will begin to thaw once placed at room temp.
4. Place the paddle inside container. Be sure the tould side of the paddle faces up.
5. Lock the lid (the clear plastic piece that fits over the container)onto motor base. The tabs on the bottom of the lid should line up with the indentations in the motor base. This ensures that the lid is locked in place. When fitting the lid onto the base, the stir paddle should "fit" into the lid.
6. Turn the On/Off dial to the right (on position).IT IS IMPORTANT THAT YOU TURN THE UNIT ON BEFORE POURING IN THE MIXTURE. THE CANISTER ROTATES WHILE THE STIR PADDLE REMAINS STATIONARY.
7. Slowly pour the mixture in the top opening of the lid. It is at this time that you place the top on the clear-vue lid and leave the machine on for about 5-30 minutes (time varies, depending on the coldness of ingredients and canister, and desired consitency) If making ice cream, your result should be a soft, custard-like ice cream
8. When the frozen dessert is ready, make sure the unit is off. Remove the lid and the mixture from the bowl with a plastic spoon or scoop. NEVER USE METAL INSTRUMENTS IN THE CANISTER.
9. Ice cream will be custard-like. If you prefer hard ice cream, place in freezer in air tight container and allow to set until it reaches your desired hardness. Don't put the ice cream in the canister in your freezer for more than 30 minutes, as the ice cream will freeze solid to the container and possibly damage it.
Hope this helps... If you need something else, let me know. I will try to check back soon.
Apr 14, 2008 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
When the paddle on my machine has stopped rotating it shoots the motor and guard off the top
you are letting the ice cream get to frozen, this should be a soft gelato ice cream, after 20 minutes turn off the top motor a leave on with the freezer unit still working or take out mixture put in tubs and put in freezer, the lid is designed to come off to stop the machine from breaking. Any magimix parts can be bought at http://www.magimix-spares.co.uk/
Feb 20, 2008 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
Ice Cream Makers Logo
Top Ice Cream Makers Experts
ray gallant
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
