Question about Whelen A7301 Tail Flood Light - 61 Beam - 01-0770144-00
WHAT IS THE REPLACEMENT LAMP PART NUMBER FOR THE 01-0770144-00 TAIL FLOOD LIGHT
Changing backup bulbs on 2005 buick rendevous
TAIL LAMP ASSEMBLY AND /OR BACKUP, SIDEMARKER, STOP, TURN SIGNAL BULB REPLACEMENT
REMOVAL PROCEDURE
1. Open the liftgate.
2. Remove the screws from the tail amp.
3. Slide the tail lamp rearward in order to disengage it from the retainers on the rear body panel.
4. Disconnect the electrical connector from the tail lamp wiring harness.
5. Remove the tail lamp and side marker lamp sockets from the tail lamp, depressing the locking tab and turning counterclockwise.
6. Remove the bulbs from the tail lamp and the side marker lamp sockets, if replacing the bulbs.
INSTALLATION PROCEDURE
1. Install the bulbs to the tail lamp and side marker lamp sockets, if removed.
2. Install the tail lamp and side marker lamp sockets to the tail lamp, turning clockwise until the locking tab is fully seated.
3. Connect the tail lamp electrical connector to the wiring harness.
4. Position the tail lamp retainer slots to the tabs on the rear body panel.
5. Install the tail lamp to the rear body panel, pressing into place until fully seated.
6. Install the tail lamp screws to the Taillamp.
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the tail lamp screws to 2 N.m (18 lb in).
7. Close the liftgate.
Apr 16, 2017 | Buick Cars & Trucks
Tail Lamp Stays On
You turned the ignition key to the wrong position when you took it out of the bike. that is the 'P' park position. It allows you remove the key to leave the bike on the side of the road with the tail lamp on as a warning in case you break down or in an emergency.
Aug 15, 2012 | 2008 Buell Lightning CityX XB9SX
2009 impala rear turn signsl bulb replacement
Tail Lamp Replacement Impala
Callout
Component Name
Preliminary Procedures
  1. Open the rear compartment lid.
  2. Remove the nut securing the rear compartment trim the backside of the tail lamp assembly.
  3. Pull down the rear compartment trim liner.
Tail Lamp Assembly Nuts (Qty: 2)
Caution: Refer to Fastener Caution in the Preface section.
Tighten
2 N·m (18 lb in)
Trunk Trim Line Nut
Tip
Ensure the trim liner nut is installed after the liner is repositioned in the rear compartment.
Tail Lamp Assembly
Tip
Pull rearward to remove and connect the electrical connector and push lamp inward in order to position the lamp to the body panel.
Rear Lamp Harness Connector
Ensure to connect the lamp harness connector before securing the lamp to the rear body panel.
Jul 29, 2011 | Chevrolet Impala Cars & Trucks
How do I change a brake light bulb in a 1999 c70 volvo?
Welcome to FixYa.com
Brake Lamp Replacement
Location of the lights
The illustration shows the locations of the lights on the RH side. The LH side is the same but
mirror-reversed.
The lights have the following functions:
- 1 +1 = Parking light Fail light
- 2 = Reversing light
- 3 = Fog light LH side only (LHD cars)
- 5 = Direction indicator
- 6 = Brake light
Tail light changing bulbs
Ignition off.
Open the cover in front of the tail light
Undo the wing nut and take out the lamp holder.
Change the defective bulb.
Fit in reverse order.
Check that all bulbs lamps are intact and in working order.
Replacement of tail light cluster
Note! If a new tail light is to be fitted, the sleeves must be ground down 1.5 mm.
Open the cover in front of the tail light Undo the panel partly in front of the tail light Unplug the
connector for the tail light Undo the four nuts securing the tail light see illustration.
Pull the tail light straight out. Fit in reverse order
Note! check the sealing and fit on reassembly.
Check that all bulbs lamps are intact and in working order.Thank you for Using FixYa.comKind Regards, LeeYour FixYa Expert and Master Technician
Jan 27, 2011 | 1999 Volvo C70
How do I replace a burned out backup light on a 1998 cheverolet silverado c-1500 pickup truck?
Removal & Installation Cab/Chassis gm-06-00-1071.gif
To Remove:
  1. Disconnect lamp assembly electrical connector.
  2. Remove nuts and lamp assembly from bracket.
  3. Remove lens screws.
  4. Remove lens, gasket and bulb.
To Install:
  1. Install lamp assembly and nuts to bracket.
  2. Connect electrical connector.
  3. Install bulb, gasket and lens.
  4. Install lens screws.
Except Cab/Chassis gm-06-00-1075.gif
To Remove:
  1. Lower endgate.
  2. Remove 2 tail/turn signal lamp assembly retaining screws.
  3. Rotate tail/turn signal lamp assembly and remove from vehicle.
  4. Disconnect lamp assembly electrical connector.
  5. Remove bulbs by pulling straight out of bases.
To Install:
  1. Install bulbs by pushing straight into bases.
  3. Install tail/turn signal lamp assembly to vehicle and secure with 2 screws.
Jul 17, 2010 | 1998 Chevrolet C1500
How do you replace the tail light bulbs on a 2006 Pontiac Vibe
Tail Lamp: Service and Repair
TAIL LAMP REPLACEMENT
REMOVAL PROCEDURE
2. Remove the rear compartment trim panel (4).
3. Disconnect the tail lamp electrical connectors.
4. Remove the following components from the vehicle:
- The 3 nuts (3)
- The tail lamp (7)
5. Remove the following from the tail lamp:
- The stop lamp socket (2)
- The turn signal lamp socket (5)
6. Remove the following from the lamp sockets, if necessary:
- The stop lamp bulb (1)
- The turn signal lamp bulb (6)
1. Install the following to the lamp sockets, if removed:
2. Install the following to the tail lamp:
3. Install the tail lamp (7) to the vehicle. Secure the tail lamp (7) with the 3 nuts (3).
Tighten the tail lamp nuts to 10 N.m (89 lb in).
4. Connect the tail lamp electrical connectors.
5. Install the rear compartment trim panel (4) to the vehicle.
6. Close the rear compartment lid.
Oct 30, 2009 | 2003 Pontiac Vibe
NEED TO REPLACE A TAIL LIGHT BULB IN A 2005 CHEVROLET IMPALA
and Repair Notes TAIL LAMP REPLACEMENT REMOVAL PROCEDURE Open the rear compartment. Remove wingnut and pull back the rear compartment trim panel from the tail lamp. Remove the wingnuts from the tail lamp. Remove the tail lamp from the rear body panel. Disconnect the electrical connector from the tail lamp. Remove the tail lamp socket, turning counterclockwise. Remove the bulb from the tail lamp socket. Remove the sidemarker lamp socket, turning counterclockwise. Remove the bulb from the sidemarker lamp socket. INSTALLATION PROCEDURE Install the bulb to the tail lamp socket. Install the bulb to the sidemarker lamp socket. Install the sidemarker lamp socket, turning clockwise. Install the tail lamp socket, turning clockwise. Connect the electrical connector to the tail lamp. Install the tail lamp to the rear body panel. Install the wingnuts to the tail lamp. Pull back the rear compartment trim panel to the tail lamp and install the wingnut. Close the rear compartment.
Jun 08, 2009 | 2005 Chevrolet Impala
Replacing the left rear driver side tail lamp assembly
Most of these type lights do not have a plug. I am assuming that you want to replace a burnt out lamp.
Here's what you do. Remove the assembtail lamp assembly. It is usually held on with 2 or 3 phillips head screws. If the problem is a burnt out lamp, the lamp assembly will unscrew from the unit by turning it counterclockwise about a quarter turn. Take the bad bulb to an auto parts store and get a replacement. The bulb will only fit one way into its socket. Then take the socket with the new bulb and insert it back in the housing. Again it will only fit one way. remount the tail light assembly.
If the actual plastic tail light assembly is broken or cracked remove the lamp assembly as described above, take the broken tail light to a dealer and ghet a new one. They are expensive. I just replaced one for my 95 F-150 pickup and it was $40.
Oct 14, 2008 | 2002 Honda CR-V
Whelen A7301 Tail Flood Light - 61 Beam - 01-0770144-00 Logo
29 people viewed this question
Top Whelen Sport & Outdoor - Others Experts
Bill Eager
Are you a Whelen Sport and Outdoor - Other Expert? Answer questions, earn points and help others
