Question about kickasstorrents.com
Block pop-ups on crackle - kickasstorrents.com
    Top Expert:
  • kickasstorre... Master
  • 14,162 Answers
Posted on Jan 16, 2016
2 Suggested Answers
SOURCE: block pop-up on crackle
can not see pass when i crack password
Posted on Jul 16, 2013
Crackles and pops when playing and even after it is turned off
UNPLUG the radio. Once you have gotten to the volume control spray contact cleaner, available at most radio shack or other electronic stores, into the switch. WD40 will also work. Clean up any excess liquid before plugging radio back in
Mar 20, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
Block pop-up on crackle
Jul 16, 2013 | kickasstorrents.com
Crackle or popping from EV Sx 100+ speaker
test this : Gd bless you
Line noise is feeding in from the AC line. Use an ac line filter to block the line noise. RF (radio frequency) interference is being picked up by the power line or wiring. Remove sources of RF interference, such as fluorescent lighting or wireless devices not designed to work with audio/video equipment. Wires between the components are on top of one of the components; the transformers are causing RF interference. Be sure that wiring goes behind the components rather than on top or between components. If there is an equalizer in use, there could be a ground loop. Ground loops can be resolved by installing GLI's (ground loop isolators) on the cables connecting to the equalizer.
Jul 10, 2013 | ElectroVoice Audio Players & Recorders
Drained old gas put in new new now its poping from exhust
Crackling and backfire is nearly always lean on fuel condition...
open your air fuel mix screw tiny amount at a time and test to see if helping this should clear up the popping..
Please note if you need to open the air fuel mix screw more than 3 full turns from fully closed then the easiest solution is leave the air fuel screw at 2 turns out from closed and increase the size of your pilot jet by one or two sizes.. they very cheap to buy few dollars each.
I would suggest if your only popping and crackling a little then small adjustment on the air fuel mix screw will cure it for sure
Being YZ I find an occasional pop or backfire when de acelorating is exactly how they should be if you don't get a pop or crackle every now and again then chances are it running to rich.
but if it is regular occurance then definitely needs fine tuning or larger pilot jet installed
good luck regards Jamie
Sep 09, 2011 | 2003 Yamaha YZ 450 F
I have a powered sub for my surround sound and every now and then its starts crackling and popping. i can make it stop by playing with the volume knob or even tapping it sometimes. my old sub did the same...
Does the crackling and popping sound comes only from the sub, or from the other speakers too? Try switching of to check. I think that it is problem on volume control potentiometer. In that case all the speakers must sound crackling and popping. If the problem is only in the sub you have to check its connections.
Stelios.
Feb 20, 2010 | Audio Players & Recorders
Audio crackling and popping noise for PS3
Might be a problem with your cables. Get new ones.
Nov 27, 2009 | Sony Playstation 3 (PS3) Console
Dell studio 1737 speakers crackle and pop.
My best guess is, if they crackle with the speakers but not the headfones,  then replace the speakers. Must be a lose wire or something of that nature.
Jul 27, 2009 | Dell Studio 1737 Laptop
Dell Inspiron 530 + Vista music sound popping crackle
check you speakers or try reinstalling the sound drives
Dec 20, 2008 | Dell Inspiron 530 Desktop Computer
Gateway Computer 710X Speakers are crackling/popping
It sounds as if the card itself may be physically bad. or you may have a microphone connected/something in your mic jack and you are picking up noise.
Nov 26, 2008 | Gateway /Creative SoundBlaster Sound Card
Crackling/popping sounds
Try re-booting your cable box....
works for me...
Nov 08, 2007 | Bose Lifestyle 38 System
kickasstorrents.com Logo
Top kickasstorrents.com Computers & Internet Experts
ray gallant
David Payne
David Payne
Are you a kickasstorrents.com Computer and Internet Expert? Answer questions, earn points and help others
