The factory reset sequence using the front buttons! I had it once and it was easy, then I lost it and need them again.
  • Matt Weaver
    Matt Weaver Jul 16, 2013
    I should mention that the monitor is a neovo f-419! Sorry about that.
  • 629 Answers
If you are having issues with the display, try to press and hold the first or the left most buttons located at the bottom right section of the monitor for about 2 to 3 seconds. this should allow the display to auto adjust. if this does not solve the issue, press any of the function buttons with left or right arrow symbols to make the OSD or function menu to show up, then continue to press the left or right buttons to navigate to the list of menus until you find the RECALL option. Once this has been selected, use the UP or DOWN arrow to select Yes to reset to factory default.
Hope this helps. :)
Posted on Jul 18, 2013
  • Matt Weaver
    Matt Weaver Jul 18, 2013
    Thanks for your help. I discovered the issue after breaking down the monitor. 2 capacitors are bulged and bad. After I replace them, it should work fine.
  • Rodie Jul 19, 2013
    glad that you've pinpointed the issue.
Samsung dvr 7162 need to reset password
please help me to reset password Samsung DVR SHR7162
Dec 24, 2012 | Samsung Shr-7162-15t Dvr Shr7162 Techwin...
Reset printer
Please print printer settings configuration page. The page will explain the printer menus and change values. Menus are represented by Continue, Ready/Data, Toner Low and Load/Remove Paper light sequences. Menu Items and their values are indicated by Paper Jam and Error Light sequences
Here are the instructions to do that:
1. Turn off the printer.
2. Open the front access cover
3. Press and hold the red Stop button while powering up the printer.
4. The lights should cycle, release it when the light stops cycling.
5. Close the cover once the ! light displays
6. The lights should cycle again.
7. Then press the Continue button.
8. This should print a Printer Diagnostics page.
9. On the Printer diagnostic page, Use the Utilities menu to troubleshoot printer problems
- Return the printer settings to factory default values.
- Sometimes resetting the printer to the original settings solves formatting problems.
- All menu items are reset to the factory default values except:
- All settings in the Parallel menu, Network menu, and USB menu.
- All downloaded resources (fonts, macros, and symbol sets) in printer memory (RAM) are deleted.
- Resources in flash memory are unaffected.
10. Please locate the value that would say "Factory Defaults".
11. We would need to follow the exact light sequence that you see for the "Factory Defaults".
12. Press and release the Cancel button to advance through the menus and the menu items to the one we would need.
13. Press and hold the Continue button until all the lights cycle to save the function/value.
14. Restart the printer.
Jun 16, 2011 | Lexmark E260dn Laser Printer
Subtitles are coming turned on,and I can't get turn them off what should I do
Hello
Your TV has mistuned with improper remote entry. Set it reset to factory settings. To set it to factory settings, do the following.
Using the "POWER button on the front panel or remote control, cycle
the power off and back on again. When the front panel LED displays
"boot", press these buttons in a sequence: "UP, DOWN, BACKWARD ARROW" and
" MENU-SELECT". The Receiver will be reset as the default status
automatically.
Use the default password "0000" to access the Lock menu and set a
new password.
Be sure to repeat your channel Auto Scan before using the receiver.
ok
Feb 04, 2011 | Olevia LT37HVS 37 in. LCD HDTV
I forgot my Password for NETGear WGT624 Please help
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Jan 17, 2011 | NetGear WGT624 Wireless Router
I NEED TO RESET MY WIRELESS PASSWORD, ZHONE MODEL 6218-12-200-0CL PL SEND INSTRUCTION
YOU CAN RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory setting from the reset button on the back side of the router. Use a paper pin to press the button for few seconds, the lights on the front would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
Here is the link to official Zhone support site for further detail (if required)
HOPE IT HELPS...Let me know if you need any further assistance
CreativeTECH
Dec 03, 2010 | Zhone (6218-I2-200) Router
Lost password,how do I change password
ALL YOU CAN DO IS TO RESET THE ROUTER TO FACTORY SETTINGS
CreativeTECH
Nov 13, 2010 | NetGear WGR614 Router
Drum, alarm, and data lights on--won't prnt
This unit might need resetting!
Here's how..
There's two ways to reset it
First: Soft Reset
1. Open front cover.
2. Hold down button located under LED's until all LED's are lit.
3. Release button and make sure drum LED is off, then
4. Close cover
Second: Factory Reset
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5. Hold in the circular button on the front panel again.
6. Once the Alarm light comes on, let go of the button.
This will perform a factory reset on the printer.
I hope that's everything you want.
Please accept this answer if this will help you.
Thank you for using Fixya.
Aug 01, 2010 | Brother HL 1440 Laser Printer
Lacie 2 big does,nt boot
Hmmm, reseting worked on mine. Identical symptoms except light stayed blue, not red. Unable to power down.
Before trying to get the drive working I got the data off using the procedure in the second post of this thread:
http://www.linuxforums.org/forum/peripherals-hardware/126831-reseting-lacie-2big-network.html
You need a linux system running. Maybe a live cd will do. I installed on an old IDE drive I had.
I then rest the decive using this procedure from Lacie and my drive is working again. Worthless though, because I can't trust it.
The procedure below will reset the 2Big Network to factory settings:
IMPORTANT NOTE: Following the procedure below can ERASE ALL DATA on the drive. Prior to following these directions, verify important data is stored securely on a different storage device.
Switch the drive OFF. Once it has shut down, ensure the power switch remains in the OFF position.
If the drive is in the SAFE mode, move the RAID switch to the BIG mode.
PRESS AND HOLD the button on the front. MOVE the power switch to the ON position. The light on the front of the drive will start blinking.
Once the light stops blinking, RELEASE the front button.
When released, it will begin BLINKING AGAIN. When it stops, PRESS AND HOLD the front button. The light will begin to blink again.
When the light stops blinking, RELEASE the button. The drive is now resetting itself. Switch the RAID selector back to SAFE if desired.
To restore data if it was lost during the process, recreate the shares and users on the unit prior to the reset. Any firmware updates applied will need to be applied again.
Sep 02, 2009 | LaCie 2big Network (2-disk RAID) (301257U)...
I have just bought a new photoconducter unit and put it in the printer. Instructions talk about select, return buttons, menu buttons and exit buttons. My printer does not seem to have this. It only has the...
  1. Enter the printer's Configuration Menu. To do this:
  2. Turn off the printer.
  3. Open the front cover, as shown below.
  4. Press and hold the Continue (pattlnk_1122005_1857-enus20682_continuebuttonicon_e230_en_us.gif) button.
  5. With the front cover open and the Continue button pressed down, power on the printer.
  6. Hold the Continue button until all the lights cycle.
  7. When just the Error light (!) is displayed, close the front cover. The top four lights of the operator panel should come on, indicating that the printer is in configuration mode.
  8. Print the Configuration Settings page. To do this:
    • Press and hold the Continue (pattlnk_1122005_1857-enus20682_continuebuttonicon_e230_en_us.gif) button until all of the lights flash. This page lists the functions within the Configuration Menu. The functions are the non·indented items listed along the left edge of the page (along the bottom as printed from printer). They are also unshaded.
      Save this page for possible later use.
  9. Reset the photoconductor page count as follows:
  10. Press and release the Cancel button (pattlnk_1122005_1917-enus20682_cancelbuttonicon_e230_en_us.gif) to move sequentially from one menu item to another. NOTE: If you get lost, you can press and hold the Cancel button to jump to home state (top four lights on).
  11. Press and release the Cancel button until the Toner Low (pattlnk_1122005_215-enus20682_tonerlowbuttonicon_e230_en_us.gif) light is the only light left on.
  12. Press and hold the Continue button until all of the lights flash.
  13. Then release the button. When the Toner Low light is once again the only light left on, the photoconductor page count should be reset to zero.
  14. Return the printer to normal mode. To do this:
    • Power it off for five seconds and then turn it back on.
  15. Print a menu settings page. To do this:
    • When the Ready (pattlnk_1122005_218-enus20682_readylighticon_e230_en_us.gif) light is on, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
  16. Check the photoconductor reading on the menu settings page. To do this:
  17. Look for a section labeled Cartridge Information and locate the word Photoconductor under that heading.
  18. Confirm that the photoconductor level reading is OK or close to 100%.
  19. If the photoconductor reading is low, try printing 10 - 20 pages.
  20. Print the menu settings page(s) again. Confirm that the photoconductor level reading is OK or close to 100%.
  21. If the photoconductor reading is still low, refer to the Configuration Settings page you printed in Step 2.
  22. Confirm that Reset Photoconductor Counter is listed on the page.
    Also confirm that the light sequence for the photoconductor counter is the Toner Low light.
    • If the light sequence is correct, try repeating this entire procedure again from the beginning to reset the counter once more.
    • If a different light sequence is listed for the photoconductor counter, repeat the procedure but this time, instead of stopping at the Toner Low light (Step 3.2), press the Cancel button until the operator panel shows the light sequence that corresponds to the one listed on the Configuration Settings page. Continue with the remainder of the procedure as before to reset the counter again.
  23. If the photoconductor reading is still low after the page reset procedure has been performed twice, the printer may require service.
Jan 01, 2009 | Lexmark E238 Laser Printer
Computers & Internet Logo
2,278 people viewed this question
David Payne
David Payne
