Question about Husqvarna MZ5424SR 54 inch 24 HP Kawasaki Zero Turn Mower
Remove Deflector How to remove it and replace it later?
    Problem Solver:
  • 11 Answers
If they dont have bolts on the back they just break out.
Posted on Jul 16, 2013
Where is the signal light relay that makes signal lights flash located on 2000 ols intrigue 3.5 liter
Important: The hazard warning switch includes the turn signal and hazard warning flashers.
Removal Procedure
Remove the center air deflector. Refer to Instrument Panel Center Air Outlet Deflector Replacement .
Squeeze the retainer on the backside of hazard warning and cruise control switch.
Pull the hazard warning and cruise control switch from the retainer in the instrument panel.
Disconnect the electrical connectors from the hazard warning and cruise control switch.
Remove the hazard warning and cruise control switch from instrument panel.
Remove the hazard warning and cruise control switch bezel from the instrument panel trim pad by using a small flat-bladed tool to the release retainers.
Remove the radio. Refer to Radio Replacement in Entertainment.
Reach through the radio opening and push the retainers up towards the roof of the vehicle. When the retainers release, slide the instrument panel (I/P) center air outlet deflector out of the I/P opening
Remove the air outlet deflector
Remove the instrument panel accessory trim plate. Refer to Instrument Panel Accessory Trim Plate Replacement in Instrument Panel, Gauges, and Console.
Remove the bolts from the radio.
Pull the radio toward you.
Remove the front floor console trim plate. Refer to Front Floor Console Trim Plate Replacement .
Pull the instrument panel (IP) accessory trim plate away from the IP trim pad.
Disconnect the IP harness seat heater leads, if equipped.
Remove the seat heater switches from the IP accessory trim plate, if equipped.
Remove the IP accessory trim plate.
Nov 09, 2016 | Cars & Trucks
Gx 6750 carriage daisy brogham
If you can remove the platen, roller, you may find a label stuck on the deflector. Remove the label from the deflector. Make sure the deflector is installed properly.
Nov 05, 2013 | Brother ML-100 Typewriter
Window regulator replacement in 1988 olds cutlass calais (non-motor). How do I replace the window regualtor?
1985-1998 Oldsmobile Grand Am/Achieva/Calais/Skylark/Somerset
REMOVAL & INSTALLATION
Door Glass and (manual) Regulator
See Figure 1
Fig. 1: Common window attachment
SEE ILLUSTRATION #1 BELOW
1. Remove the door panel.
2. Remove the water deflector from the door.
Be careful not to tear the water deflector when removing it from the door.
The "water deflector" is also known as the "dew wiper"
3. Connect the power window switch/window regulator handle.
4. Lower window to full down position.
CAUTION
Use extreme caution when operating the window with the door panel removed. The window regulator can cause severe personal injury if body parts become entangled in the mechanism.
5. Remove the window run channel.
6. Move window to the half down position.
7. Remove the window retaining nuts.
8. While holding onto the window, lower the regulator to the full down position.
9. Remove the window by sliding it towards the rear and rotating the front of the window upward.
To install:
10. Position the new window in the door.
11. While holding onto window move regulator to half up position.
12. Install the nuts. Roll the window to the full up position.
13. Install the rear run channel.
14. Install the plastic water deflector. If necessary, secure with waterproof adhesive
15. Install the door trim panel.
Window Regulator
See Figures 2 and 3
Fig. 2: Location of the front door window regulator-1995 vehicle shown
SEE ILLUSTRATION #2 BELOW
Fig. 3: Exploded view of the rear door window regulator-1995 vehicle shown.
SEE ILLUSTRATION #3 BELOW
2. Remove the plastic window deflector. Be careful not to tear the deflector when removing it from the door.
3. Remove the door window assembly.
4. Remove the bolts securing the regulator to the door.
5. Remove the nuts securing the upper regulator guide.
6. Using a 1/4 in. drill, drill out the regulator rivets.
7. If equipped with power windows, detach the electrical connector.
8. Remove the regulator through the large access hole in door.
To install.
9. Install the regulator to the door, and attach the electrical connector if equipped with power windows.
10. While holding the regulator to the inner door panel, insert the rivets, and secure them with a rivet tool.
11. Fasten the regulator bolts and upper guide nuts.
12. Install the door glass, and inside door plastic panel.
13. Install the inside door trim panel.
14. Install the plastic water deflector. If necessary, secure with waterproof adhesive.
Fig.1---------------------------------------------------------------------- Fig. 2
Fig. 3
Oct 03, 2011 | 1988 Oldsmobile Calais
OIL PUMP
This Depends on a 2 Details, ENGINE Size 4by4 or NOT. Most are Fairly Simple Once the Oil Pan has been Removed and the OIL PAN is Normaly the HARDEST Part of it
AFTER OIL PAN REMOVAL
  1. Remove the oil pump. Refer to Oil Pump, Pump Screen and Deflector Removal.
  2. A loose screen or pipe assembly can result in an air leak and loss of oil pressure. For more information, refer to Oil Pump Clean and Inspect.
INSTALLATION PROCEDURE
  1. Install the oil pump and the oil deflector. Do not reuse the oil pump drive shaft retainer (4). During assembly, install a NEW oil pump driveshaft retainer. Refer to Oil Pump, Pump Screen and Deflector Installation.
  2. Install the engine oil pan. Refer to Oil Pan Replacement
Dec 09, 2009 | 1999 Chevrolet Silverado 1500
How do I reset the outside temperture gauge
you can't reset it. Try replacing the sensor.
SECTION 412-04: Control Components 2002 Explorer/Mountaineer Workshop Manual
REMOVAL AND INSTALLATION Ambient Air Temperature Sensor Removal and Installation
  1. Remove the radiator grille. For additional information, refer to Section 501-08 .
  1. Remove the three upper pin-type retainers in the radiator air deflector.
  1. Position forward the air deflector.
  1. Remove the ambient air temperature sensor.
    1. Detach the pin-type retainer.
    1. Disconnect the electrical connector.
    • Remove the ambient air temperature sensor.
Nov 23, 2009 | 2002 Mercury Mountaineer
How to replace a heater core
Removal & Installation
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  1. Disconnect the negative battery cable and drain the cooling system.
  2. Raise and support the vehicle safely.
  3. If equipped, remove the rear lateral transaxle strut mount.
  4. Disconnect the drain tube from the heater case.
  5. Detach the heater hoses from the heater core.
  6. Carefully lower the vehicle.
  7. Remove the right and left sound insulators.
  8. Unfasten the steering column opening filler. Disconnect the heater outlet deflector (floor air outlet duct).
Disconnect the floor air outlet duct
Remove the heater core cover.
Unfasten the retaining bolts, then remove the heater core cover
Detach the heater core retaining straps (clamps), then remove the heater core.
Detach the retaining clamps or straps, then remove the heater core
To install:
  1. Install the heater core and retaining straps (clamps).
  2. Install the heater core cover.
  3. Reconnect the heater outlet deflector (floor air outlet duct).
  4. Install the right and left sound insulators. Install the steering column opening filler.
  5. Raise and support the vehicle safely.
  6. Connect the heater hoses (use new heater hose clamps if necessary) to the heater core.
  7. Connect the drain tube to heater case.
  8. Connect the rear lateral transaxle strut mount, if equipped.
  9. Lower the vehicle.
  10. Fill the cooling system and check for leaks. Check heater system for proper operation.
Nov 13, 2009 | 1994 Chevrolet Cavalier
Replace 1998 chevy lumina headlight assembly
Here are the steps:
  1. Raise the hood.
  2. Lift the flap on the appropriate end of the radiator upper air deflector.
  3. Separate the radiator side air baffle from the upper air deflector.
  4. Remove the fastener retaining the upper edge of the front bumper fascia to the headlamp bracket.
  5. Remove the two bolts retaining the headlamp assembly to the headlamp bracket.
  6. Slide the headlamp assembly slightly inboard to release the outboard retaining tabs.
  7. Carefully pull the upper edge of the front bumper fascia away from the inboard edge of the headlamp assembly, just enough to aid in headlamp removal.
  8. Carefully remove the headlamp assembly from the headlamp bracket.
  9. Disconnect the electrical connectors from the headlamp bulbs.
  10. Rotate the park/turn signal lamp socket counterclockwise to release.
  11. Remove the headlamp assembly.
Sep 06, 2009 | 1998 Chevrolet Lumina
Looking for a guide to install a driver side window motor
Good day
this going to be a long one I'll start with water deflector
WATER DEFLECTOR
1.remove trim panel
2.remove seat belt assembly
3. remove tape from deflector and door inner panel
4. remove deflector from inner door panel using a wide flat bladed tool to break the hot melt sealer bond
TRIM
1. remove the power door lock switch from the trim panel
2. remove lock knob and bezel
3. remove screw and reposition or remove the remote mirror bezel
LOCK KNOB AND BEZEL
1. remove cover
2. remove remote control bezel retaining screw
4. remove knob from lock rod by prying with a flat bladed tool
4. remove knob
5. remove bezel
SWITCH
1. remove switch from trim panel using a small flat bladed tool
2. disconnect wire connector from switch
POWER MOTOR
1. remove water deflector
2. raise window to fully up position and tape window to door frame using cloth backed body tape
3. punch out the center pins of the regulator rivets then drill out rivets using 1/4 inch drill bit
4. move regulator rearward and disconnect wire harness from motor disengage roller on regulator lift arm from window sash channel
5. remove regulator through rear access hole
6. secure regulator arm to regulator by inserting a bolt through holes in the regulator and sector gear then attach a nut to the bolt
7. using a 3/16" drill bit drill out motor attaching rivets and remove motor from regulator
INSTALLATION
1. install motor to regulator with 3/16" rivets or 3/16" nuts and bolts
2.remove nut and bolt securing regulator arm to regulator.
3. then install by repeating the removal
hope this helps it's not as hard as it reads
Cheers
Jul 13, 2009 | 1992 Chevrolet Cavalier
How do you replace the fog light bulbs on a 2004 buick regal?
Notes FOG LAMP BULB REPLACEMENT - FRONT
REMOVAL PROCEDURE
  1. Remove the front bumper fascia deflector.
  2. Disconnect the electrical connector from the front fog lamp bulb/socket. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Rotate the front fog lamp bulb/socket counterclockwise to release.
  2. Remove the fog lamp bulb/socket from the front fog lamp assembly.
  1. Install the fog lamp bulb/socket to the fog lamp rotating clockwise until fully seated. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Connect the electrical connector to the front fog lamp bulb/socket.
  2. Install the front bumper fascia deflector.
Jun 16, 2009 | Buick Regal Cars & Trucks
The turn on lights does not flash
Check out this recall below:
Bulletin No.: 04098A
SPECIAL POLICY
Subject:
04098 - Special Policy Adjustment - Turn Signal/Hazard Warning Flashers
Condition
Some customers of 1999-2002 Chevrolet Malibu, Oldsmobile Alero, Pontiac Grand Am, and 1999 Oldsmobile Cutlass may have turn signal/hazard flashers that become inoperative.
This special policy covers the condition described above for a period of 10 years or 150,000 miles (240,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership. The repairs will be made at no charge to the customer.
Good luck and hope this helps:
HAZARD WARNING SWITCH REPLACEMENT - ON VEHICLE
REMOVAL PROCEDURE
Remove the center air louver deflector. Refer to Air Deflector Louver Replacement - Center Vent.
Remove the instrument panel cluster.
Remove the hazard warning switch bezel from the instrument panel using a small-flat bladed tool to release the retainers.
Remove the left side bolt from the hazard warning switch through the instrument panel cluster pocket Remove the right side and center lower bolts from the hazard warning switch through the center air louver deflector pocket.
Reposition the hazard warning switch from the instrument panel to access the electrical connector.
Disconnect the electrical connectors from the hazard warning switch.
Remove the hazard warning switch from instrument panel.
Connect the electrical connectors to the hazard warning switch.
Position the hazard warning switch to the mounting points in the instrument panel. NOTE: Refer to Fastener Notice in Service Precautions.
Install the left side bolt to the hazard warning switch through the instrument panel cluster pocket. Tighten Tighten the left side hazard warning switch bolt to 3 N.m (27 lb in) .
Install the right side and center lower bolts to the hazard warning switch through the center air louver deflector pocket. Tighten Tighten the left side hazard warning switch bolt to 3 N.m (27 lb in) .
Install the hazard warning switch bezel to the instrument panel pressing into place until fully seated. Install the instrument panel cluster.
Install the center air louver deflector. Refer to Air Deflector Louver Replacement - Center Vent.
May 24, 2009 | 2000 Oldsmobile Alero
Husqvarna MZ5424SR 54 inch 24 HP Kawasaki Zero Turn Mower Logo
35 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
