Wheel stepper error data card 150i - Computers & Internet
Datacard 150i repair new york city
im looking for a datacard 150i repaired. contact me if you can do the job. thank you michaelwilliams175@ymail.com
Apr 30, 2014 | Office Equipment & Supplies
Que es error 5 tectrix personal climber
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Error 5, No Slack, Cybex/Tectrix Climbmax 2000/3000, 700S and 800S Steppers Probable Cause An error 5 on the Tectrix Climbmax models 2000 and 3000 as well as Cybex stepper models 700S and 800S indicates the following:
a) Test switch is in test mode.
b) Possible cut in display cable.
Corrective Action a) Adjust slack switch.
b) Inspect display cable; Replace cable if necessary.
Error 5 No Slack on Cybex and Tectrix Steppers Climbmax 2000 3000 700S 800S
Apr 10, 2014 | RTO Tectrix Personal Stair Climber
Screen shows error code 5
Feb 20, 2014 | RTO Tectrix Personal Stair Climber
Datacard 150i transport error
Hi If you Tel me the Serial Number of you Machine I probably will be able to help
Jan 19, 2013 | Datacard Group 150iDesktop Card...
What is the impedance of the mirage BPS-150i sub speakers?
The high Level inputs are suitable for an 8 ohm amplifer The low level inputs would be used to connect via your amplifer's pre amp output.
Jan 07, 2011 | Mirage BPS 150I Speaker
How do i get a personal support tech for datacard 150i?
I have a problem at work editing the project properties
From the menu bar, select Edit and then Production Form Properties. The Edit Production Form Properties dialog box opens.
data source for select OLE DB provider and source
when Click on the Choose button this message appears error occurred the selection or configuration of adata source
Oct 19, 2010 | Computers & Internet
Step motor error
One of the stepper motors has failed. The machine has two stepper motors: one that moves the needle back and forth and one that moves the feed. Take it to your dealer for an estimate.
Apr 02, 2009 | Elna Quilter's Dream 6003Q
Nikon LS-2000 scanner gives error 0x04620000
Stepper Motor Failures
Within the first 6 months of purchase I had to return the scanner twice to replace the stepper motor. The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
service required to fix stepper motor
Jan 07, 2009 | Nikon LS 2000 Film Scanner
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
