I have a hinari refresher air PAC9200CSS the air conditioning unit doesn't seem to be working as its blowing out warmer air not cold. Plus it doesn't seem to be filling up with water
  • 8 Answers
SOURCE: fan blows.. no cold air... no hot air exhaust blowing
This sounds like you either need to clean or replace the filter, but if the filter is some what new you might want to take a look at the coils just past the filter, if the coils do not have a shine to them then you might want to buy some coil cleaner (i found simple green or formula 50 works great), then you will have to spray the coils with the cleaner, let sit about 10-15 min, then give it a very good rinse with warm water. After that it should work like it is brand new. Enjoy!
Posted on Mar 30, 2009
  • 340 Answers
SOURCE: swamp cooler is not blowing cold air. Water is
is the pump youll have to take off a panel make sure the pump has water. what is the relative humidity if it is high swampers don't work very well .Tom
Posted on Jun 26, 2009
  • 13 Answers
SOURCE: my air conditioning does not blow out cold air.
Have the gas checked, A/Cs work with refrigerating gas. This should be done by and A/C technician.
Posted on Jun 29, 2009
luker711
  • 91 Answers
SOURCE: My AC unit wont blow the cold air.
No, you probably have a bad evaporative fan motor, capacitor or switching. It usually takes a Pro 1/2 hour to track down such a problem with good training.
Posted on Jul 09, 2009
  • 30 Answers
SOURCE: panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Posted on Jul 18, 2009
A/c blowing hot air with low pressure
The first thing to do would be go to your local auto parts store and buy an air conditioning recharge kit. Provided your vehicle isn't too old, they sell recharge kits that require no tools.
If their is a leak anywhere while you recharge, you will know.
Try recharging the air conditioning first, it is very simple and the kits come with simple instructions.
If there are no leaks, your A\C will blow cold air again. As for the pressure, if it continues to slightly blow air you may be looking at a new air compressor unit or a vaccum line. A new unit will run you anywhere from $200-$2000 dollars plus labor depending on the vehicle.
If the recharge works, at least you will have slightly blowing cold air rather than hot and you can continue that way until the unit fails.
Jul 09, 2013 | Cars & Trucks
2000 pontiac bonneville blows hot and cold at the same time
Sounds like the blend door motor isn't working.
Jan 20, 2013 | 2000 Pontiac Bonneville
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
The freon is fully charged but the air keeps getting warmer until there is no longer any cold air. It still blows air but it's warm. Does this sound like the compressor is bad??
do you have to recharge it after it starts blown warm if so its just got a leak and leaking all your freon out if its holding all freon then compressor must be bad
Sep 14, 2012 | Air Conditioning and Heat for Isuzu Axiom
Air conditioning cycling on and off to fast, does not seem to know when to shut off, clicking or shut off sound when it wants to shut off but doesn't it keeps running. It is blowing ice cold air.
It sounds to me like the thermostat needs replaced. If what you hear clicking noise but the unit does not shut down that is probably the problem. Thank you.
Jul 25, 2011 | Dometic Rooftop RV Air Conditioner
My air conditioning united seems to be blowing cold air, but its not cooling down my room? Plus the temperature reading never lowers. Thank you in advance.
Sounds like the rear coil may be stopped up with dirt, etc. If it is, the unit will not cool properly. You may just be able to unplug it and wash it out with a hose and sprayer from the back of the unit. If its real dirty, you will have to pull the unit out of the window, take the case off and clean it real good. If you wash it out from the back, be sure you can do it when you can leave the unit off for an hour to dry. Let me know if I can help you any more of if this doesn't work. Stay cool. mark
Jul 10, 2011 | Haier HWR05XC7 Wall/Window Air Conditioner
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
I have a ''GE"heat &
Look at the wires that go to the compressor and make sure they are not burned off. Inspect the capacitor tops for swelling and loose or burnt wiring. Also check the connections coming from the controls. May have a wiring problem or even a bad compressor. How old is the unit?
May 17, 2011 | GE AJCQ06LCB Air Conditioner
Opperating an hinari refresh air pac9100c/fc air conditioning unit
Hi I have the Henari Refesh Air 3-in-1 and am having problems get the Dehumidifier only to work. I've done as above. There is a little pipe inside next to the water collector. This is inside. when i put the water collector tray in the machine switches off. I have switched it off and on and set it to dry but nothing is happening. If i take the water collector out then it switches on and u must unstop the pipe and ly it in a bucket. the machine then switches on and runs but the "water full" light then comes on and after running it for about half hour nothing seems to happen? Can you please help. I have a serious humid problem in my house.
Nov 25, 2010 | Heating & Cooling
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
